Anyway to Set HDMI as startup channel for TV? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 02-07-2010, 10:02 AM - Thread Starter
ckjordan6's Avatar
Just got a Samsung LN37B650 and it is Great!
I am really pleased with the Picture Quality and the price.
Is there a way to set the HDMI 1 input as the primary start channel for the TV?
When I turn the TV on, it goes to Cable(RF) mode = static. I am not using the RF input, I need for the set to go directly to HDMI 1 on startup.
ckjordan6 is offline
post #2 of 7 Old 02-07-2010, 10:12 AM
sharkcohen's Avatar
It should be on whatever input you last had it on. Are all of your settings resetting, too?
sharkcohen is offline
post #3 of 7 Old 02-07-2010, 10:44 AM - Thread Starter
ckjordan6's Avatar
I believe it goes back to the RF input (Cable). I'll check it again today and post my results.
All of the settings seem to be hold. Thx
post #4 of 7 Old 02-07-2010, 11:06 AM
frito's Avatar
yeah it should stay on whatever input it was left on when you turned it off
you are using the TV to turn it off and not something external like a home automation or some sort of switch right?
If you're a gamer or interested in using an LCD TV as a primary monitor take a look at my thread on Input Lag
frito is offline
post #5 of 7 Old 02-07-2010, 04:43 PM
MrBobb's Avatar
Quoted: 164 Post(s)
Liked: 63
It is possible that when TV doesn't detect HDMI signal (so turn on source b4r TV), it defaults to RF.
MrBobb is offline
post #6 of 7 Old 02-08-2010, 04:04 AM - Thread Starter
ckjordan6's Avatar
Thanks for your replies!
My girlfriend solved the problem. It looks like it you turn the TV on firdt, then the cable box, the TV recognizes the signal and switches to the HDMI input!
Thanks Samsung!
post #7 of 7 Old 02-08-2010, 07:53 AM
sitlet's Avatar
either way, your tv should stay on the same input that it was on when it gets turned off. if it doesnt do this, want to call samsung and see if there is something wrong with the tv
sitlet is offline
Reply LCD Flat Panel Displays
