I have a Fix for LG TV's that won't turn on - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 93 Old 10-27-2015, 07:21 PM
Liked: 0
My lg tv has sound but no picture. when i turn it on it blinks blue and turns black. Is there any part i can replace to fix it i have already tried putting new power supply board.
Deep Patel is offline
post #92 of 93 Old 03-15-2017, 07:20 PM
Liked: 0
Does this fox work for OLED 4k TV's?
Monty4G63 is offline
post #93 of 93 Old 03-19-2017, 03:59 AM
sharfixit's Avatar
sorry I have no idea. I would have thought that replacing the power supply board would have fixed it. Perhaps you should check the serviceability of the power supply board you used as a replacement, if thats ok recheck that you assembled all the plugs and socket properly into their correct places. You really need to find someone who fixes LG panels for a living. I could not find one myself. The work around on mine worked for a good amount of time then I managed to find another power supply board online.
sharfixit is offline
Reply LCD Flat Panel Displays
Lg 47lg90 47 Inch Led Backlit 1080p 120 Hz Hdtv Gloss Piano Black With Blue
