VIZIO INTERNET APPS (VIA) Enabled LCD's Thread - Page 22 - AVS Forum | Home Theater Discussions And Reviews
post #631 of 737 Old 08-25-2011, 02:28 PM
mrtanner98's Avatar
I received a usb key for the firmware update, and then I received 2 more , so I now have 3 but, updated all and now have 20 pages of apps, but am wondering if anyone knows what the media app is suppose to do ? all it says is that , no media is found ? Is it to finally use one of the usb connections ?
mrtanner98 is offline
post #632 of 737 Old 08-25-2011, 04:01 PM
ThunderPants's Avatar
Yes you can use that "app" to view pictures or listen to mp3s but no movies.
ThunderPants is offline
post #633 of 737 Old 08-28-2011, 08:13 PM
redgtxdi's Avatar
And S-T-I-L-L no YouTube app!!!
I finally rec'd my update yesterday morning but didn't get a chance to fiddle with it 'til today. (sigh). Again.......99% worthless but then I remembered........."Oh ya, we've been waiting all these months for the YouTube app so it should be there by now, right? WRONG!!"
You can take all of the other apps away. Gone! Don't need 'em. There's YouTube, then there's everything else. They've been promising since CES.....LAST YEAR!!!
On a positive note, I now have a cool new Transformers logo on the bootup screen. OOooooooh....Aaaaaaaah!!
redgtxdi is offline
post #634 of 737 Old 08-29-2011, 03:34 PM
phobos512's Avatar
So I've got a 552, purchased it right when it came out and haven't had any problems until the other day when I got a new Wi-Fi router (I picked up a Vizio XWR100 to replace a D-Link DIR-655 that had become very unreliable - it's working great). While I was putting the settings into the TV I noticed that my widgets had disappeared much like people on here have noted. I don't really use them as I cancelled Netflix and we typically get movies from Redbox but I thought it was odd.
It sounds like I need to contact Vizio and obtain one of these firmware USB keys - is that accurate? Or will one just "show up" magically at some point?
phobos512 is offline
post #635 of 737 Old 08-29-2011, 04:19 PM
Burnerbum's Avatar
Mine dissappeared one day and then were back the next day or 2.
Burnerbum is offline
post #636 of 737 Old 09-06-2011, 03:27 PM
smitty1258's Avatar
anything new going on with the via apps yet? Like the ability to watch movies via usb? youtube?
anything new? or just junk?
smitty1258 is offline
post #637 of 737 Old 09-13-2011, 07:59 PM
marknga's Avatar
I've got a E322VL and last night I noticed that I'd lost all my widgets. I unplugged the tv this morning and plugged it back in this evening but no change.
I can't get into profile, I can't find the widget gallery.
I sent an email to Vizio Service but am open to any and all suggestions. I really like the Netflix and Pandora app's.
marknga is offline
post #638 of 737 Old 09-14-2011, 06:51 AM
Burnerbum's Avatar
This has happened to me and they came back in a day or so. Don't know what causes it. But they should come back.
post #639 of 737 Old 09-14-2011, 10:37 AM
marknga's Avatar
Thanks for the reply.
Here is the email I just received from Vizio. I will give this a try tonight when I get home.
"I apologize to hear you are having difficulties with your VIZIO TV.
Here at VIZIO we offer best in class technical support.
I would recommend performing a power cycle on your TV. Please follow the steps in this order:
1- Power off TV
2- Unplug TV from outlet
3- Press and hold in the power button on the TV for 30 seconds (while it is unplugged from the wall)
4- Release the power button
5- Plug in the TV into a different outlet
6- Power the TV back on
There is also a factory reset option in your menu under the SETUP or HELP section.
It will say either "reset all settings" or "system reset". If your TV is internet enabled, you will see Clear Memory. Please select this.
You will need a parental code override. "0000" or "1234" are the default codes.
By doing this, you will need to complete the initial set-up of your product.
If this does not resolve your problem please contact our technical support when you are in front of the TV and are able to further troubleshoot. You may contact us at 1-888-849-4623 or chat with us at chat.vizio.com
Thanks and have a great day!"
marknga is offline
post #640 of 737 Old 09-15-2011, 04:59 AM
marknga's Avatar
This reset worked.
Hope this info may help someone else in the future.
Mark
marknga is offline
post #641 of 737 Old 10-02-2011, 03:38 PM
cowboyz's Avatar
Has anyone found the iPhone app for the Vizio Remote? I saw the January 2010 demo of it online, but cannot find the Vizio IPhone Remote App anywhere...
Also, has anyone found a way to watch MPEG via the apps?
cowboyz is offline
post #642 of 737 Old 10-03-2011, 08:00 AM
DAVIDGR's Avatar
There is a Vizio Remote app on iTunes, but it requires additional hardware to work. http://itunes.apple.com/us/app/iwavi...420660167?mt=8
It may be easier to control your TV thru the set top box. For instance, I have FIOS TV and can use the FIOS Remote app on my iphone. Works great!
DAVIDGR is offline
post #643 of 737 Old 10-17-2011, 09:32 PM
umenon's Avatar
Quoted: 613 Post(s)
Liked: 194
I am Vizio VIA noob ..
How does one skip to the next web video? The only thing I was able to do is press STOP and return to the main layout and select the next video. There does not appear to be way to skip to the next video.
umenon is offline
post #644 of 737 Old 10-28-2011, 12:05 PM
gadzookz's Avatar
marknga - I have that model and I lost all my widgets last month, too. However, I could access the widget gallery. Since I primarily just use netlflix on that TV, I added back that app manually. Still haven't gone back through and added back all the widgets I liked. What a PITA.
gadzookz is offline
post #645 of 737 Old 11-06-2011, 10:37 PM
OncleJulien's Avatar
has anyone had any luck using a usb card reader to display images from an sd card via the media app?
OncleJulien is offline
post #646 of 737 Old 12-06-2011, 06:21 PM
TvTinker's Avatar
I'm putting together a widget that you can stream video from your computer to your TV. It should work on Vizio Tv's.
Anybody interested when it becomes available?
TvTinker is offline
post #647 of 737 Old 12-06-2011, 06:34 PM
Burnerbum's Avatar
Certainly, I would be happy to try it.
post #648 of 737 Old 12-07-2011, 02:40 AM
amarksp's Avatar
Yes, I would be interested. Currently I am using fling desktop from Github:
https://github.com/Flingo/Flingo
Would be great if your widget could also fling mp3 files as well as MP4 and other video files.
amarksp is offline
post #649 of 737 Old 12-07-2011, 03:46 AM
Burnerbum's Avatar
Yes, it would be great. But how do you manually install a Widget on the TV?
Also, if it works, maybe you (guy developing it) could sell it to Vizio and bring them up to speed with other TV mfgrs.
post #650 of 737 Old 12-07-2011, 05:18 AM
TvTinker's Avatar
It will require you to run some sort of web server on your computer, like some sort of DLNA... Yahoo widgets can only communicate via http, so direct network connection is not possible (from my research so far). Streaming of video occurs via that web server.
But for most part all other things are working already! Version #1 will do video files only, but I'm looking into pics and mp3 as well.. So say goodbye to the USB!
I'm thinking of getting 2-3 guys as beta testers. Then, possibility try to put it out for some nominal $ amount. Beta guys get free lifetime updates. :-)
TvTinker is offline
post #651 of 737 Old 12-07-2011, 05:20 AM
TvTinker's Avatar
They have an app for that... lol.
They have a "developer" install mode to test your widgets... We can start with that.
TvTinker is offline
post #652 of 737 Old 12-07-2011, 08:59 AM
TvTinker's Avatar
yea.. it plays mp3 fine...
TvTinker is offline
post #653 of 737 Old 12-07-2011, 10:42 AM
wookatok's Avatar
I am interested. Let me know if you need some beta testing.
wookatok is offline
post #654 of 737 Old 12-07-2011, 12:03 PM
Mandrake2003's Avatar
How do you go about developing VIA apps?
I am a programmer but not in this type widget thing.
I would be interested in getting/developing a widget for Squeezebox.
Mandrake2003 is offline
post #655 of 737 Old 12-07-2011, 01:01 PM
TvTinker's Avatar
This is where you start:
http://developer.yahoo.com/connectedtv/
You have to know about : Ubuntu, VMWare, Javascript, JSON, OO; if not it will be a rough start.
TvTinker is offline
post #656 of 737 Old 12-08-2011, 02:16 AM
amarksp's Avatar
You may want to take a look at the Github link I posted for fling:
http://github.com/Flingo/Flingo
The Flingo(R) desktop application flings to and remote controls TVs and other connected devices. Flingo is released on the GNU Public License (GPL) v2.
You can download this source code for free and then modify and extend. Even if you choose not to use the existing source code, the Readme section will likely be useful to you.
Good luck, and I would be happy to beta test your code, especially if it can fling MP3 files.
amarksp is offline
post #657 of 737 Old 12-08-2011, 10:32 AM
TvTinker's Avatar
Yes, Flingo seems as a very interesting solution, but I want to stream/fling(o) my own content from my own computer. Flingo v0.2 beta, installs on my win7 x64 but does not do anything when I run it...? Any of the flingo users out there any suggestions....
Does anyone know how flingo streams the video on a local LAN? Does it have to point back to their server?
Fling MP3's? How about define playlists and play those... ?
TvTinker is offline
post #658 of 737 Old 12-12-2011, 11:19 AM
TvTinker's Avatar
Hi guys!
I have a version of the widget working! However, it does require some setup on your computer. You will need to run a webserver, that can locally serve up the video/audio content on your LAN. Vizo and Yahoo apps/widgets only use HTTP protocol, so no direct server access is possible.
So the first 2 beta testers get into the test team! If you are interested contact me at: my gmail account: tvtinker2 AT gmail DOT com.
Looking forward to hear from you.
TvTinker is offline
post #659 of 737 Old 12-19-2011, 02:04 PM
DAVIDGR's Avatar
My Vizio 552 rebooted yesterday afternoon after downloading a new firmware update. And now I have Youtube and Skype apps!
Youtube works really well. Haven't tried Skype yet. Not sure how I'll use it since I don't have a microphone or video cameras connected.
DAVIDGR is offline
post #660 of 737 Old 12-20-2011, 11:18 AM
Originally Posted by lokilarry View Post
Mine just updated about an hour ago. I'm hoping that is why my 552 experienced the RVR over the weekend.
are you guys on sets that run via or via plus?
Reply LCD Flat Panel Displays
