The Official KDL....EX700 Thread - Page 123 - AVS Forum | Home Theater Discussions And Reviews
post #3661 of 3687 Old 03-18-2013, 06:53 AM
JoeKustra's Avatar
Quoted: 714 Post(s)
Liked: 292
I wish I knew the best place to post this, but nothing seems to fit. Since my hardware is the 32EX700, I thought I would give it a shot here.
I have enabled TVGOS over the internet for program source in the past but found it would corrupt something that would kill Favorites or other function. A month ago I did a factory reset and scrubbed the TV.
I have cable only but no PSIP. My channels are vsb (2-25), clear QAM 26.0 through 128.1. 105.1 through 109.2 are HD locals.
On the info box, I see several vsb (analog) channels sometimes have the program name and even the running time. The time is blue. My time can still be set manually but it is also blue. No time set has happened because I have set it two minutes slow.
My query: what causes the program name? When should time update? Is there a better place to post this? I'm talking about analog channels. Is this a mistake by my cable company, SCTE-127, or just unknown?
JoeKustra is online now
post #3662 of 3687 Old 04-21-2013, 04:12 PM
jpenright's Avatar
Hi all, I used to be able to get 5.1 audio from my KDL-EX700 on the optical outputs when I streamed Amazon on Demand movies that supported 5.1. I've noticed that sometime over the past few months, that I no longer get 5.1 from the optical outputs (down to 2.0). Was this feature disabled in a recent version of the firmware?
Right now I have the internet connected to my Bravia and feed the optical output into my 5.1 receiver.
Is anyone else able to stream Amazon on Demand into their TV and use the optical output to pass through the 5.1 audio stream right now?
Thanks in advance for the help.
JP
jpenright is offline
post #3663 of 3687 Old 04-21-2013, 04:45 PM
JoeKustra's Avatar
Quoted: 714 Post(s)
Liked: 292
JP
Does audio from the tuner still come through in 5.1? When tuned to a network like CBS I show 5.1 from the optical. There are plenty of Amazon problem threads on the forum. I'm running the latest (114AAL) firmware.
post #3664 of 3687 Old 04-21-2013, 04:57 PM
JacobC1983's Avatar
Test it by hooking HDMI from a bluray player to the TV and run the optical from the TV to your receiver and see how that works
My Home Theater
JacobC1983 is offline
post #3665 of 3687 Old 04-25-2013, 03:58 PM
zoran0909's Avatar
Ah, input lag.
Been reading this thread for 2 hours, searching up and down, googling and what not.
Still haven't found any conclusive info on the input lag?
I see some folks were very happy after a firmware update, and it got good marks for the input lag on iffy review sites (testing input lag with 2 lcds is stupid and pointless).
Can someone point me to some proper tests?
zoran0909 is offline
post #3666 of 3687 Old 04-25-2013, 04:27 PM
JoeKustra's Avatar
Quoted: 714 Post(s)
Liked: 292
Originally Posted by zoran0909 View Post
Ah, input lag.
Could you be more specific and/or define your "input lag"?
post #3667 of 3687 Old 04-25-2013, 11:39 PM
zoran0909's Avatar
Seriously?
"My" input lag = is the time from a picture is generated by the source to the picture appearing on the screen. As CRTs don't have input lag, the easy way to measure it is by outputting a test to both CRT and the LCD simultaneously, and recording the dime difference. One could also use the Leo Bodnar’s Lag Tester, but CRTs are a bit easier to source.
As I was saying, I could not find hard data on the Ex700, just opinions.
What was the point of the exercise Joe, as I doubt that after 5.5k posts here you have trouble understanding me.
post #3668 of 3687 Old 04-25-2013, 11:48 PM
morpapagan's Avatar
morpapagan is offline
post #3669 of 3687 Old 04-25-2013, 11:50 PM
zoran0909's Avatar
Originally Posted by morpapagan View Post
71x, 72x use Samsung s-PVA panels so they don't have much in common with ex70x series.
post #3670 of 3687 Old 04-26-2013, 05:45 AM
JoeKustra's Avatar
Quoted: 714 Post(s)
Liked: 292
Seriously?
I understand now. You were posting a game question. I have never done that (except at Vegas). I'm sorry, I never would have responded if I knew it was about playing games.
post #3671 of 3687 Old 05-04-2013, 09:50 PM
jpenright's Avatar
Fine idea...tonight I just gave that a try and I do get 5.1 from the TV optical out into my receiver while using the TV cable tuner input. So it can pass 5.1 from the cable input. I did try to see if I could find another internet based video source from the TV that would send 5.1, which would allow me to see if it is an Amazon problem or if it is a Sony problem/limitation sending 5.1 from an internet source. I had a hard time finding any other internet video sources with 5.1 that I could test with. Does anyone know of any internet video source that I could use that would send 5.1?
I do know that for an extended period of time (at least a year) Amazon on Demand did work for me with 5.1 sound on movies that had it. Does anyone have the TV sending 5.1 on the optical output working with Amazon or Netflix?
JP
post #3672 of 3687 Old 05-05-2013, 05:14 AM
JoeKustra's Avatar
Quoted: 714 Post(s)
Liked: 292
JP
You might find this helpful. Last post especially.
http://answers.microsoft.com/en-us/windows/forum/windows_7-pictures/how-do-i-enable-51-surround-sound-when-watching/78b170a5-4e67-4271-bc51-ebf64144a24c
post #3673 of 3687 Old 05-11-2013, 07:27 AM
jpenright's Avatar
Ah, thank you for sharing that. So it is possible that Amazon is no longer passing 5.1 in its movie streams--that is good to know. I'm going to see what I can find out on that one. I agree with the thread--we just need a method to select the proper audio stream.
JPE
post #3674 of 3687 Old 05-23-2013, 03:39 AM
Jim2K's Avatar
Just got some sandisk cruzer blade 16GB usb flash drives and they are
not recognized by the ex700 TV. Is there a maximum size for flash drives
and the ex700. Has anyone found a 16GB or larger usb flash
drives that works, I tried an 8Gb awhile back and it worked fine...
Thanx
Jim2K is offline
post #3675 of 3687 Old 05-23-2013, 05:09 AM
JoeKustra's Avatar
Quoted: 714 Post(s)
Liked: 292
Thanx
Excuse me for stating the obvious, but they are FAT32? I have the USB internet adapter so I never used a flash drive.
post #3676 of 3687 Old 06-11-2013, 11:13 AM
Jim2K's Avatar
Thanks, too bad fat32e doesn't work because of the fat32 file size limit
Jim2K is offline
post #3677 of 3687 Old 07-27-2013, 06:35 AM
JacobC1983's Avatar
I noticed the Sony KDL-60EX645 was on sale at best buy today for $999 and was wondering if you thought that the picture quality was a reasonable upgrade from my KDL-60EX700
What do you think?
My Home Theater
post #3678 of 3687 Old 07-27-2013, 08:17 AM
JoeKustra's Avatar
Quoted: 714 Post(s)
Liked: 292
What do you think?
I think I would rather die than give up my presence sensor. But that is a good price. Best Buy will probably ship it free if you can't go to the store. I don't expect them to stay in business much longer. I have never had a problem with their sales or service.
post #3679 of 3687 Old 07-27-2013, 08:21 AM
steve ans's Avatar
Looks like a nice middle of the road set. Cheap enough. All these flat panel TVs still do not have the durability of the CRT beasts of the past that refused to die. it's a crap shoot. i have a Sony KDL-52EX700 (2009) that's still fine (always had some light leaks) and a KDL-55HX729 perfect set (2011)...fingers crossed.
Sony KDL-55HX729, Sony STR-DH820 Receiver, Sony BDP-S590 BD Player, Sony SA-W2500 subs, Sony, SS-CN5000 center channel, Sony SS-F6000 left and right front speakers, Sony 3D Glasses: TDG BR-750 & TDG-BR250, Apple TV, APC Back Up UPS XS1500, Apple Airport Extreme.
steve ans is offline
post #3680 of 3687 Old 09-29-2013, 04:29 PM
Ryan L's Avatar
Quoted: 18 Post(s)
JP
I stopped by here for some other issues/questions, but saw your post. I noticed the exact same thing you mentioned recently last time I rented a movie from Amazon and know for a fact that I used to get 5.1 from their HD streams. Did you ever figure out what the culprit was; firmware downgrade on our end or is it Amazon skimping on the audio? Either way I probably wont be renting anything else if there's no surround sound from their movies. Redbox is right down the street and their rental fees are much lower for the real deal. Never really understood why these instant videos are as expensive as they are anyway.
Moving on to the question I had before I forget to ask it altogether; has there been a recent firmware updates (maybe within the last week or two)? I just love how they give you the firmware revision but no date along with it. Anyway, the issue that just sprung up is related to HDMI control and audio. The TV used to play nice with my Marantz NR1601 (95% of the time), but know it's misbehaving. I could turn on the TV and it would power up the receiver and pass audio to it. Now I have to go into the TV's settings and switch it from TV speakers to audio system and also add my receiver to the device list. What's more frustrating is that I have to reboot my HTPC also as it sees my TV as the audio destination (I can't select 5.1 in the audio options in the pc until a reboot with the correct settings on the TV). BTW, the current firmware revision is PKG4.117AAL .Like I said, no clue if it's new or not just that everything seemed to work fine until I turned it on one day. And nothing else has been changed (nothing new connected to the receiver or TV). If it is a firmware issue is there anyway to even roll it back on our TVs? TIA
Ryan L is offline
post #3681 of 3687 Old 09-29-2013, 05:40 PM
lengyans's Avatar
Right,basically everything cranked to make the TV have visual pop under the harsh lighting of a big box store like BB.
lengyans is offline
post #3682 of 3687 Old 10-06-2013, 03:17 PM
jpenright's Avatar
Hi Ryan, I never figured out what the root caused was on this. I was able to verify that I can pass 5.1 through the TV optical out by tuning in an OTA channel and seeing/hearing 5.1 on my receiver. Either Amazon is skimping on the audio or Sony firmware is blocking 5.1 from the ethernet stream.
JP
post #3683 of 3687 Old 09-24-2014, 12:52 PM
SL600's Avatar
Quoted: 106 Post(s)
Liked: 58
Anyone upgraded from a KDL60EX700 to a 2014 4K SONY XBR65X850B?
Has anyone on this thread upgraded from a KDL60EX700 to a 2014 4K SONY XBR65X850B? Please let me know. Thanks.
SL600 is offline
post #3684 of 3687 Old 09-26-2014, 07:21 AM
JoeKustra's Avatar
Quoted: 714 Post(s)
Liked: 292
My EX700 needs a Doctor
Here are my symptoms:
1. Presence sensor does not function
2. All internet interface items are gone - only refresh icon displayed and it doesn't work.
3. No issue with inputs or channels (cable - clear QAM 120 channels)
4. Normal power off then on has no effect and the network "USB Device Found" blinks once, no click of the relay
5. Vampire power switch clears all the above but loses the clock (manually set) and I can then refresh internet content.
Everything works normally for a few days then, I use the remote to turn it on, and no relay click. Or I wake up and the set has not shut off. So...
Any ideas. I would have upgraded long ago but I love the presence sensor. I don't use ARC and only one HDMI input from my AVR. Thanks.
post #3685 of 3687 Old 12-25-2014, 05:27 AM
andyross63's Avatar
Quoted: 131 Post(s)
Liked: 49
Saw that there is a firmware update as of September. The only update is to improve the stability of Internet streaming.
Need help with your Motorola DVR? Check the Wikibook: How to use a Motorola DVR
andyross63 is offline
post #3686 of 3687 Old 02-18-2015, 06:57 AM
dm145's Avatar
Quoted: 58 Post(s)
Liked: 40
New firmware update 1/13/15 v4.131
http://esupport.sony.com/US/p/swu-do...os_group_id=18
dm145 is offline
post #3687 of 3687 Old 08-01-2015, 08:13 PM
Windows X's Avatar
I've been checking out this thread from time to time to find better calibration with my 60EX700. I'd like to share my calibration that should work with most Sony LED TV models based on my 60EX700.
Backlight: Min (For night view so raise it if you need more backlight on day time)
Picture: Max (Kinda agree with Chad B to keep Picture at max)
Brightness: 44 (To keep effective depth without reducing gamma)
Colour: 52 (You can raise to 56 if you want a bit more colorful)
Hue: 0
Colour Temp: Warm2
Sharpness: Min
Noise Reduction :Off
MPEG Noise Reduction: Off
Motionflow: Off
Film Mode: Auto2
Black Corrector: Off
Adv. Contrast Enhancer: Off
Gamma: 0
Auto Light Limiter: Off
Clear White: Off
Live Color: Off
White Balance
RGain: -8
GGain: -2
BGain: 0
RBias: -2
GBias: 0
GBias: +2
May not be perfect calibration but privide wide color range in 6500K temperature with good depth and looks good on both movies and games.
Windows X is offline
Reply LCD Flat Panel Displays
Sony Bravia Ex 700 Series 32 Inch Led Tv Black Kdl 32ex700 , Sony Bravia 40 Inch Kdl40nx700 Led Hdtv , Sony Bravia Ex700 Series 60 Inch Lcd With Led Back Lighting Hdtv Kdl 60ex700
taboola here
