Official KDL..EX500/501 Thread - Page 163 - AVS Forum | Home Theater Discussions And Reviews
 6Likes
post #4861 of 6235 Old 05-14-2011, 01:50 PM
vasupilla's Avatar
Originally Posted by serialmike View Post
Its a little hard to compare due to overseas versions having bravia3 which makes the ace work differently and worse as you can see fluctuation. Ace on makes our ex5's much better. Another thing I see is thier greyscale is way worse than what I got. Though I know exactly why. Mine used to look that way. Then I realized other tweaks that I could do to the white balance to get mine where it is.
He does seem to have a better gamma than mine but gamma really isnt an issue unless your way out.
Not to be cocky but looking at it, I know more about the set than he does when it comes to calibrating it. The reason is I spent alot more time. But I can tell there are things he doesnt realize about how the settings work. Normal white balance doesnt effect other things so he just did what you normally would do when calibrating. I found out the the white balance does effect things it shouldnt and I compensated and utilized these type of things when calibrating the set.
Thanks Mike, Well you have made your case as to why your settings are accurate. I will adopt them as they are the only ones in this thread that are industry standard and also among professional reviewers as well.
vasupilla is offline
post #4862 of 6235 Old 05-14-2011, 07:49 PM
Foques's Avatar
Greetings!
I just bought this TV today...and having a hell of a time getting greens and reds to populate properly so far..
more so, the TV is cropping too much (when, say, I play COD, I can not see the "bonus" that you get for getting a certain number of kills. both - xbox and tv are set to 1080p.. any solution to this? thanks in advance. (nvm, figured it out)... working on settings now. sorry.
Foques is offline
post #4863 of 6235 Old 05-15-2011, 05:33 AM
Elux's Avatar
I would be very interested in knowing your settings once you've become situated. I am desperate at this point.
Elux is offline
post #4864 of 6235 Old 05-15-2011, 12:40 PM
FrostyCollects's Avatar
Hi everyone,
Let me apologize in advance for not wanting to spend hours of reading this massive thread for specific answers. I'm considering to get an EX500 but I need to get confirmation from you owners on something...does this model exclude the all-too-common auto-dimming issue you see during dark scenes? I have a Samsung LN46D630 which has that issue unfortunately (which is odd because its 2-years-older B630 model didn't have that issue in Movie mode).
Please let me know soon and thanks in advance.
FrostyCollects is offline
post #4865 of 6235 Old 05-15-2011, 01:14 PM
StuBerger's Avatar
Originally Posted by FrostyCollects View Post
Hi everyone,
Your safe from that with the EX line...
Those are my principles, and if you don't like them... well, I have others.
StuBerger is offline
post #4866 of 6235 Old 05-15-2011, 07:43 PM
Jackboot's Avatar
If someone could post the original box dimensions I will be extremely grateful. I need the dimensions so that I can create a UPS shipping label. I know the shipping weight is 31 lbs (as per Amazon).
BTW, I'm assuming that shipping in the original box/packaging is safe enough? Or am I about to make a big mistake?
Thanks for any help
Jackboot is offline
post #4867 of 6235 Old 05-15-2011, 08:16 PM
uncynd's Avatar
Thanks for any help
Hey man just measured for you, 7.5" x 29.5" x 52.5"
glgl
uncynd is offline
post #4868 of 6235 Old 05-16-2011, 09:27 AM
cburbs's Avatar
Quoted: 94 Post(s)
Ok I did some readings last night -
Eye-One LT Meter with AVSHD - 55EX500 set
SerialMike Settings
My settings -
My settings are serialmike old settings plus a few changes in white balance -
Picture Mode- Custom
Backlight-1
Picture-90
Brightness- 50
Color- 50
Hue- 0
Color Temp- Warm2
Sharpness- 0
Noise Reduction- Off
MPG Noise Red- Off
MotionFlow- Standard
Cinemotion- Auto2
Ambient Sensor- Off
Advanced Settings
Adv Contrast Enhancer-Low
Black Corrector- OFF
Gamma- 0
Clear White- Off
Live Color- Off
White Balance-
RR-Gain: -1
G-Gain: 0
B-Gain: 0
R-Bias: -1
G-Bias: -3
B-Bias: 7
Picture size-Full Pixel
Power Save-Off
Newest settings based off of Mikes last ones - 9-28-11
Gray scale(Average Gamma:2.23, contrast: 1798:1)
Eye-One LT Meter with HCFR. AVSPatterns
Backlight-1
Picture-82
Brightness- 50
Color- 50
Hue- G1
Color Temp- Nuetral
Sharpness- 1
MPG Noise Red- Off
Cinemotion- Off
Ambient Sensor- Off
Advanced Settings
Adv Contrast Enhancer-off
Black Corrector- off
Gamma- 0
Clear White- Off
Live Color- Off
White Balance-
RGain -2
GGain -3
BGain -39
RBias -1
GBias -2
BBias -1
Power Save-Off
Luminance -
Gamma
RGB
Color temp
CIE Chart
"You’re KILLIN’ ME Smalls! "
Sony 55EX500 Settings
cburbs is offline
post #4869 of 6235 Old 05-16-2011, 09:53 AM
serialmike's Avatar
SerialMike Settings
My settings -
My settings are serialmike settings plus a few changes -
R-Gain: -1
G-Gain: 0
B-Gain: 0
R-Bias: -1
G-Bias: -3
B-Bias: 7
Are you saying thats what you got with my custom mode calibrated settings plugged in your set?
Doesnt make sense. The difference in the settings would require you to take red up in order to make up the difference in the red and not by a little bit. Pretty much by 3 bias and gain or more. Due to the other colors being closer.
Something there doesnt add up.
Also for info sake. What size set are you running?
serialmike is offline
post #4870 of 6235 Old 05-16-2011, 10:14 AM
Jackboot's Avatar
glgl
Thanks, but I just realised I'm an idiot
I'm requesting dimensions for the 32EX500 box! I didn't specify that in my last post.
So...32EX500 box dimensions, anyone?
Jackboot is offline
post #4871 of 6235 Old 05-16-2011, 11:03 AM
dm145's Avatar
Quoted: 75 Post(s)
Liked: 43
just go to any electronics store with a tape measure
they have 32 inchers all over the floor
dm145 is offline
post #4872 of 6235 Old 05-16-2011, 11:12 AM
cburbs's Avatar
Quoted: 94 Post(s)
I have the 55". I used your settings and tweaked from there. It makes sense because you have red at -8 and I brought it up to -1 so that is a +7 difference am I not correct?
cburbs is offline
post #4873 of 6235 Old 05-16-2011, 11:55 AM
serialmike's Avatar
Oh yeah yeah, I see it. I looked at it before coffee. some how saw that reversed. Yeah makes perfect sense in my mind. Interesting. Looks proof positive that the sets are different. Odd in the way that they are. Looks also like its proof that the ex5 line has blue low for all the sets as I suspected. Because people were complaining of to reddish or orange. Also interesting that lowering red wasnt needed on yours.
Looks good though.
As a side I just no more than 5 min ago went back and looked at mine real quick since its been many months. Still the same cant get more perfect than the settings posted for my 60ex5.
post #4874 of 6235 Old 05-16-2011, 01:59 PM
cburbs's Avatar
Quoted: 94 Post(s)
The Cnet settings are tweakable and after a few changes get good results as well.
cburbs is offline
post #4875 of 6235 Old 05-16-2011, 03:32 PM
Elux's Avatar
cburbs, can you post your settings?
Elux is offline
post #4876 of 6235 Old 05-16-2011, 03:40 PM
cburbs's Avatar
Quoted: 94 Post(s)
Same as serialmikes besides the few changes mentioned a few posts above everything else is the same.
cburbs is offline
post #4877 of 6235 Old 05-16-2011, 10:01 PM
Zebas_'s Avatar
hi everyone in ps3 the way to go is limited rgb ?? and caibration for limited rgb
Zebas_ is offline
post #4878 of 6235 Old 05-17-2011, 08:44 AM
gary cornell's Avatar
cburbs, just tryed your settings on my 46EX500, nice picture. Will compare to calibrated settings using a Klein K10 later this month.
gary cornell is offline
post #4879 of 6235 Old 05-18-2011, 06:15 PM
DaBargainHunta's Avatar
Quick question about the KDL55EX500 (Sony BRAVIA 55")
One of the reviews on BestBuy.com lists this as a gripe:
· When using an HDMI connection you are not allowed to change the "wide" mode to "normal". Meaning if you are trying to watch something that is in 4:3 aspect ratio it will stretch the image forcing you to use a component connection to achieve "normal" viewing mode. Totally bogus considering older SONY TV's have this functionality.
Can anyone verify if this is actually the case? Thanks.
DaBargainHunta is offline
post #4880 of 6235 Old 05-18-2011, 11:45 PM
Torqdog's Avatar
Quoted: 106 Post(s)
Liked: 200
I run HDMI exclusively and haven't found this to be a problem at all. If the content is 4:3, it displays with bars on the sides. No streching here!
Torqdog is offline
post #4881 of 6235 Old 05-19-2011, 01:38 AM
GTOne's Avatar
That is not the case, I can switch it to 4:3 when it's called for anytime. It will default to wide when you come off HD content or switch channels back and forth, however. It takes a couple pushes of the remote's wide button to go back to 4:3.
GTOne is offline
post #4882 of 6235 Old 05-19-2011, 08:09 AM
dm145's Avatar
Quoted: 75 Post(s)
Liked: 43
or just change Auto Wide to Off under Screen settings
dm145 is offline
post #4883 of 6235 Old 05-19-2011, 01:06 PM
DocuMaker's Avatar
When I hit the menu button on the remote, the menu comes up defaulting to pictures. I have to hit the up/down button just to get to the settings.
This is very annoying.
Does it have to be this way? Tell me it aint so!
What a bunch of Sony baloney!
DocuMaker is offline
post #4884 of 6235 Old 05-19-2011, 01:08 PM
StuBerger's Avatar
Yep...that's how Sony setup their home menu screen...damn, it's sooooo sad you have to press the down arrow 3 times to enter the settings...I would return it....sheeeesh
post #4885 of 6235 Old 05-19-2011, 01:27 PM
Torqdog's Avatar
Quoted: 106 Post(s)
Liked: 200
........ or press the button once in the "up" direction. Yep, Sony baloney fer shure! Return it immediately before it causes you any more un-needed stress.
Torqdog is offline
post #4886 of 6235 Old 05-19-2011, 01:46 PM
DocuMaker's Avatar
Damn straight! Dumping this crap and going back to Samsung. At least Samsung gives you a backlit remote on their 120hz comparable model. Tired of fumbling around in the dark.
Sony baloney indeed!
post #4887 of 6235 Old 05-19-2011, 02:14 PM
StuBerger's Avatar
Adios
post #4888 of 6235 Old 05-19-2011, 02:16 PM
StuBerger's Avatar
WOW, there you go....only a short distance to nirvana
post #4889 of 6235 Old 05-19-2011, 03:11 PM
ZedPlane's Avatar
Try pressing the Tools button & see if that is any more to your liking ?
ZedPlane is offline
post #4890 of 6235 Old 05-19-2011, 03:55 PM
serialmike's Avatar
Really isn't hard at all to run the menus. In fact its easy fast and my 10 yr old has no issue whatsoever. Its ten times more responsive than the samdung system.
If your complaint a bout a tv is getting thru the menus you probaby didnt want it anyway. You set the thing up then honestly and hardly use the dam menus anyway. Other than changing inputs.
I could really care less as long as the menu function gets the job done. Panny menus are garbage always have been. Alot worse than any sony Ivee ever used. The image is where its all about.
Reply LCD Flat Panel Displays
Sony Bravia 60 Inch Lcd Hdtv Kdl 60ex500 , Sony Bravia V Series Kdl 52v5100 52 Inch 1080p 120hz Lcd Hdtv Black
