Official KDL..EX500/501 Thread - Page 164 - AVS Forum | Home Theater Discussions And Reviews
 6Likes
post #4891 of 6235 Old 05-20-2011, 05:53 PM
serialmike's Avatar
serialmike is offline
post #4892 of 6235 Old 05-20-2011, 06:18 PM
RoyaleDuke's Avatar
So I gotta ask...how's gaming on this TV?
I've seen the TV in store, and I am pretty much in love with the TV but I am curious about its gaming performance and PQ.
Input lag doesn't bother me, but visual "ghosting" does.
RoyaleDuke is offline
post #4893 of 6235 Old 05-20-2011, 06:52 PM
serialmike's Avatar
Eye-One LT Meter with HCFR. AVSPatterns, THX patterns
Picture Mode- Custom
Backlight-Min
Picture-95
Brightness- 52
Color- 50
Hue- R1
Color Temp- Neutral
Sharpness- 1
Noise Reduction- Off
MPG Noise Red- Off
MotionFlow- Standard
Cinemotion- Off
Ambient Sensor- Off
Advanced Settings
Adv Contrast Enhancer-off
Black Corrector- off
Gamma- 0
Clear White- Off
Live Color- Off
White Balance-
RGain -4
GGain -3
BGain -26
RBias 0
GBias 1
BBias 2
Picture size-Full Pixel
Power Save-Off
Game Mode for Xbox Ps3 gaming. (Now metered and fully tested with patterns)
Picture Mode- Graphics
Backlight-1
Picture- 91
Brightness- 50
Color- 50
Hue- g1
Color Temp- Warm1
Sharpness- 1
MPG Noise Red- Off
MotionFlow- Off
Cinemotion- Off
Ambient Sensor- Off
New Alternate Game settings (slightly more lag but very playable)
Backlight-Min
Picture-95
Brightness- 52
Color- 50
Hue- G1
Color Temp- Nuetral
Sharpness- 1
MPG Noise Red- Off
MotionFlow- OFF
Cinemotion- Off
Ambient Sensor- Off
Advanced Settings
Gamma- 0
Clear White- Off
Live Color- Off
White Balance-
RGain -4
GGain -3
BGain -26
RBias 0
GBias 1
BBias 2
Power Save-Off
post #4894 of 6235 Old 05-20-2011, 07:43 PM
cburbs's Avatar
Quoted: 94 Post(s)
serialmike,
Can you post a HCFR pic of your first main settings and your new ones?
"You’re KILLIN’ ME Smalls! "
Sony 55EX500 Settings
cburbs is offline
post #4895 of 6235 Old 05-20-2011, 07:53 PM
StuBerger's Avatar
Originally Posted by serialmike View Post
Here are new settings for those who dare. They are HOT.
Backlight-1
Picture-89
Brightness- 52
Color- 50
Hue- 0
Color Temp- Warm2
Sharpness- 0
MPG Noise Red- Off
Cinemotion- Auto2
Ambient Sensor- Off
Advanced Settings
Adv Contrast Enhancer-Low
Black Corrector- OFF
Gamma- 0
Clear White- Off
Live Color- Off
White Balance-
RGain -12
GGain -3
BGain 0
RBias 0
GBias -3
BBias +8
Power Save-Off
Backlight-1
Picture- 91
Brightness- 50
Color- 50
Hue- 0
Color Temp- Warm1
Sharpness- 1
MPG Noise Red- Off
MotionFlow- Off
Cinemotion- Off
Ambient Sensor- Off
Darn it Mike, your at it again! How have you been my calibrating friend?
Again, this is for the 60EX correcto mundo? We are so close but I don't use ACE and I still have my WB at default on the 55EX.....
I've been thinking on a new set for our family room...it's about time to put the RP set to rest. Don't know which road to go on that one since I might even try to get a larger one for the current EX spot in our makeshift HT...and move the 55 to the family room...its a conundrum in the making.
Those are my principles, and if you don't like them... well, I have others.
StuBerger is offline
post #4896 of 6235 Old 05-20-2011, 08:44 PM
serialmike's Avatar
I learned (on my own) I had made a mistake. While resolving the mistake I learned a few things and applied the quirks of the white balance controls to my advantage.
Ive been watching all day and now Harry Potter weekend on abc familyyhd. So far the results are stunning. Incredibly filmlike look. Much like SXRD. Though sports and video broadcasts look bright and natural. Inccreased shadow detail and image depth.
post #4897 of 6235 Old 05-21-2011, 07:35 AM
nl5h's Avatar
would it be worth getting a 40" ex500 vs. a bx420 (32 or even 40"). it seems like the ex is the far superior model.
i'd just like to spend under 600$ if possible.
nl5h is offline
post #4898 of 6235 Old 05-21-2011, 10:15 AM
StuBerger's Avatar
I wish I could at least get a calibrated white balance in the 55....other than ACE and the white balance we are close to the same....
post #4899 of 6235 Old 05-21-2011, 12:26 PM
serialmike's Avatar
I thought cburbs or i forget his name back a page white balance was for 55
They are. they look good. Try em out
http://www.avsforum.com/avs-vb/showt...7#post20443877
post #4900 of 6235 Old 05-22-2011, 07:25 AM
nl5h's Avatar
I just bought an 32ex520 and I'm trying to calibrate it.
Are there any recommendations on how to do this calibration?
nl5h is offline
post #4901 of 6235 Old 05-22-2011, 08:10 AM
cburbs's Avatar
Quoted: 94 Post(s)
You can start here - Sony 32ex520
cburbs is offline
post #4902 of 6235 Old 05-22-2011, 09:42 AM
tuz
tuz's Avatar
Hello; I just bought a 32EX500 (Mpva panel, european model so bravia engine 3) to replace a good old 22inch crt pc monitor.
The tv is connected to a ATI 4890 via a dvi to hdmi cable.The problem is that I think I m suffering form the lack of 4:4:4 chroma subsampling support.
Most of the white or red text on black background create the appearance of some blue or purple pixel. This happens mostly for internet surfing and on some other software like speedcommander, notepad, paint...
For instance, I created in Paint.net a black document of 1920x1080. I wrote a line of I in Arial - 28 - red. Once this was done, I used the hand tool to quickly move this line. The blue and purple pixel appeared. So, now I am able to reproduce it at 100%.
Here is a screenshot:
I already tried VGA and it's the same problem.
I decided to buy this tv even if I was not sure that it support 4:4:4 (divergent opinion on the web).
Can someone try that at home and let me know if it happens also ?
Is there anything I can do to solve that ?
Is it really due to the lack of 4:4:4 support ?
tuz is offline
post #4903 of 6235 Old 05-22-2011, 01:35 PM
nl5h's Avatar
Cool, thanks! It was also nice to read a proper review on this TV. It will be a good TV for 2-4 years that I can give to my parents later.
nl5h is offline
post #4904 of 6235 Old 05-22-2011, 06:10 PM
vmammoliti's Avatar
Please Help!! 3 weeks ago I returned my first LCD an LG37ld450 because it buzzed quite loud when I reduced the backlight below 100. I now have a Panasonic 37u3 which also makes the dreaded buzzing sound when baclight is reduced. Do all F#$%ING LCD buzz when backlight is reduced?? Can anyone please tell me if the Sony 40EX500 buzzes when the backlight is reduced or is this just something that is inherent of CCFL based LCDs. Do LED based lcds buzz??? I will use this LCD for the bedroom and often have the volume relatively low, which means this buzz drives me crazy!
vmammoliti is offline
post #4905 of 6235 Old 05-22-2011, 06:28 PM
serialmike's Avatar
the ex5 series is silent
post #4906 of 6235 Old 05-23-2011, 06:47 AM
vmammoliti's Avatar
Thanks Mike. Is there anybody else who can verify this or is this "if I get lucky kind of thing." I'd hate to get the 40ex500 only to hear the same distracting buzz.
post #4907 of 6235 Old 05-23-2011, 08:09 AM
zip2play's Avatar
Serialmike,
I have the KDL-46EX501.
I would like to try out a set of settings that you recommend for MOVIES. I don't game on the main TV and so I don't need "HOT." Would you give me a link?
I'd have looked myself but since there are almost 5,000 posts in this thread it would take all week.
Thanx.
zip2play is offline
post #4908 of 6235 Old 05-23-2011, 08:18 AM
cburbs's Avatar
Quoted: 94 Post(s)
You can try mine which are for the 55" -
Otherwise Mikes - http://www.avsforum.com/avs-vb/showt...3#post18869413
cburbs is offline
post #4909 of 6235 Old 05-23-2011, 09:35 AM
StuBerger's Avatar
No buzz...none...nada...zilch....
post #4910 of 6235 Old 05-23-2011, 10:00 AM
serialmike's Avatar
furthermore there has never been one single buzz noise complaint in this thread.
post #4911 of 6235 Old 05-23-2011, 10:06 AM
hughh's Avatar
Quoted: 34 Post(s)
Liked: 39
Come to think about it, I haven't seen any "buzzing" complaints on any of the Sony topics on AVS...
hughh is offline
post #4912 of 6235 Old 05-23-2011, 12:21 PM
WaldorfSalad's Avatar
Me too!
WaldorfSalad is offline
post #4913 of 6235 Old 05-23-2011, 12:43 PM
weezntz's Avatar
None here what so ever
weezntz is offline
post #4914 of 6235 Old 05-23-2011, 02:10 PM
vmammoliti's Avatar
Thank you guys. I guess the Panny goes back and here comes the 40ex500. Guys are the blacks on the Sony ex500 noticeable deeper then IPS aplha of the Panansonic??
post #4915 of 6235 Old 05-23-2011, 07:23 PM
tomandbeth's Avatar
60EX500 here, and there's NO BUZZZ whatsoever.
I'm REAL picky about ground loop issues in audio. This set is dead silent between tracks.
Then again, my wife claims I'm deaf. It's a scientific fact that the high pitch of a women's voice is inaudible to a man who loves peace and quite for a few moments to enjoy all they worked for, Seriously.
tomandbeth is offline
post #4916 of 6235 Old 05-23-2011, 09:49 PM
gary cornell's Avatar
Replaced new Panasonic 46ST30 with sharper, more vibrant 46EX500. Not impressed with black level of Panasonic. My view is not to fall in love with 2011 models as 4k smaller size models are in the works.
gary cornell is offline
post #4917 of 6235 Old 05-24-2011, 11:10 AM
dm145's Avatar
Quoted: 75 Post(s)
Liked: 43
What mistake did you make? Quirks?
dm145 is offline
post #4918 of 6235 Old 05-24-2011, 11:56 AM
serialmike's Avatar
Patterns I used, That I made mind you. Were made with corel. They were made in RGB color. This is incorrect. I had no idea at the time when making greyscale that this would be off. They need to be made in sRGB.
I used AVS disc patterns. When I used these I also used thier excellent shadow detail pattern which really showed me what white balance is doing. Its not that white balance controls brightness in anyway. Interestingly very interestingly certain clicks of green biaas will KILL shadow detail. Not that these are exact examples but lets say -1 green shadow detail is there and proper still. -2 will make the lightest bar disappear (yeah really) then -3 it will be back (yeah wth).
Good news is that it doesnt matter because it can be calibrated fine if you know what your looking for and your going back and checking everything.
Also of note, the old calibration that I had up forever is still not bad at all. Just off a little bit.
post #4919 of 6235 Old 05-24-2011, 12:22 PM
dm145's Avatar
Quoted: 75 Post(s)
Liked: 43
how did it effect you metered results?
dm145 is offline
post #4920 of 6235 Old 05-24-2011, 12:55 PM
serialmike's Avatar
on the red side of things
Reply LCD Flat Panel Displays
Sony Bravia 60 Inch Lcd Hdtv Kdl 60ex500 , Sony Bravia V Series Kdl 52v5100 52 Inch 1080p 120hz Lcd Hdtv Black
