Samsung 52B750 and Directv HR20 Recevier IR remote conflict - AVS Forum | Home Theater Discussions And Reviews
Old 02-24-2010, 07:43 AM - Thread Starter
amcfarla's Avatar
Quoted: 68 Post(s)
Liked: 71
I just recently purchased the Samsung 52B750 and received it last week, I am using a Directv HR20 HD DVR which I was using with 46 Samsung DLP before and never had problems with the remote control not responding. I received the new tv(which swapped out the DLP set) on Friday and my directv receiver stopped responding to remote signals that day. All weekend long I have not been able to make heads or tails out of this since the remote control worked on another directv box without a problem. I was able to switch the remote to RF mode and it works without a problem in that state, but IR will not work. The problem with using RF is that I am using a harmony 880 remote to control everything and that will require a second remote to control my directv. Today I discovered that when the TV is off the Directv receiver responds to IR commands, but once the TV is turned on, IR commands stop working. I cannot be the only person who has had this issue since I have been looking on the forum board and cannot locate a post regarding this. If anyone has any suggestions on how to get the 52B750 and Directv HR20 to play together nicely using IR it would be much appreciated. Also if I have posted this on the wrong forum board by mistake I apologize, since I was not sure which board was appropriate for this issue. thank you.
amcfarla is offline
Old 02-24-2010, 09:58 AM - Thread Starter
amcfarla's Avatar
Quoted: 68 Post(s)
Liked: 71
Ok through experimenting, if I cover the screen with a blanket, the HR20 responds to remote signals, when i remove the blanket, it stops responding.
amcfarla is offline
Old 02-24-2010, 10:55 AM - Thread Starter
amcfarla's Avatar
Quoted: 68 Post(s)
Liked: 71
I think I have fixed it(think being the key word), changing the backlight setting to 5 seems to have resolved the remote issues. Makes zero sense on why that would control it, oh well it seems fixed so I am good with it.
amcfarla is offline
Old 02-24-2010, 12:08 PM
tecnico's Avatar
Use three or four layers of masking tape on the IR receptor of your HR20. You'll be surprised but thhat will fix your problem.
Good luck!
Tecnico
tecnico is offline
Old 02-24-2010, 06:06 PM - Thread Starter
amcfarla's Avatar
Quoted: 68 Post(s)
Liked: 71
Good luck!
Tecnico
Actually I used one layer of masking tape using a black sharpie and covered the IR's on all my devices which resolved the issue.
amcfarla is offline
