the "help me choose an LCD" thread - Page 10 - AVS Forum | Home Theater Discussions And Reviews
 250Likes
Old 04-04-2010, 10:36 AM
BiscoJosh's Avatar
Hey all. New to the forum. Could def use some help.
1. Budget - approx 800ish (I have 1200 total for TV and home theater system)
2. Seating distance - approx 6ish
3. Size/placement limitations - im thinking that due to the distance 40/42 is my best bet
4. Uses and sources - HDTV, occassional XBX and PC monitor
I have done a ton of research. However, I am having difficulty pulling the trigger. According to consumer reports the sony KDL-40EV5 seems to be my best option in terms of price (800). But I have not been able to find them live in person anywhere, just online. Also, I missed out on a great deal on the Samsung LN40B750 which I could have gotten for 830, but it is sold out. Anyone have any ideas/advise? Also, if you have any input with the home theater system, that'd be great too. I have been looking at the sony home theater in a box ones (I think its the 587W or something like that). But, those dont have blu ray players. I guess it does not really matter w/ the blue ray since I dont own any blu ray dvds anyway. haha.
Thanks in advance for the help!
5. Room lighting
BiscoJosh is offline
Old 04-04-2010, 12:57 PM
Kaabik's Avatar
Hi I need some help choosing a lcd. I have gone through two led's one lcd and two plasma's and I am not happy at all. The main problem with the plasma's have been the burn in that I have been having. (samsung 850 and the panasonic v10) I had the samsung 6000 led but had problems with weird blur around things, so i took that one back and i had the sharp 700n led and had terrible motion blur. I also tried the sony ve5 which wasnt bad, but the motion blur was there a bit.
1. Budget: Less than 2,000
2. Seating distance: looking for a 46" -50" tv
4. Uses and sources: mainly for gaming/sports/movies/blu ray/hd tv/standard definition
5. Room lighting: the room does get some light on it, but nothing directly on the face of the tv.
Anyways please help me find a lcd with the least amount of blur for sports/video games. I have gone through a ton of tv's and I can't find the one that is right for me.
Kaabik is offline
Old 04-04-2010, 04:25 PM
Solid555's Avatar
  1. Budget: around $1,000
  2. Seating distance: 7' - 10'
  3. Use: TV and DVDs
  4. Room lighting: a ton of windows; none directly on the screen but I have white walls
I have settled on a 46"-47". My main concern is how much light the room gets. I have a bunch of floor to ceiling windows, so I want a matte screen. I was considering:
  • Samsung LN46C530
  • Sony KDL-60EX400
I have reservations about the Samsung, since people seem to have had problems with service/reliability. However, I think the Sony may have a more reflective screen.
  • Which of these should I get?
  • Any other models I should consider?
I could spend more if people think it would make a big difference. But since I am coming from a 15 year old CRT, I think I'll be happy with a low end model. Thanks for any help.
Solid555 is offline
Old 04-05-2010, 01:14 AM
xorbe's Avatar
Originally Posted by mattkillahd View Post
i dont believe any company has full led under 42 inches. lg is the only company i know of that has full led at 42 all other companies is 46" and up. and its the lg 42lh90. but it does have the glossy bezel.
Sharp has white led backlit with glossy frame/screen at 40". 42" is darn close to 40" so I'll check out that LG. I've got to get something *sigh*
xorbe is offline
Old 04-05-2010, 07:19 AM
jonglover's Avatar
1. Budget: $550-ish
2. Seating distance: 3 feet
3. Uses and sources: Video games, DVD/BD, some television
4. Room lighting: Windows (with curtains) directly behind the television but I'm moving soon anyway, so...
I've been leaning towards the smaller Samsungs, in the UN26C4000 and the LN26C450. I don't know a lot of television tech, however I think that the smaller LED's actually aren't completely LED backlit, correct? That said, aesthetics are big for the GF and I, and we like the look of the LED line. I'm just wondering if there are any problems with these lower end LEDs that I should be wary of, or a reason I should absolutely go with the LCD (we will be doing a lot of gaming on this) over the LED? Thank you!
jonglover is offline
Old 04-05-2010, 12:22 PM
kmil's Avatar
Guys and Gals: Help me choose between a Sony KDL 52EX700 (701) 52 incher OR a Vizio XVT472SV a 47 incher (NOT interested in internet apps) just the biggest bang for the proverbial buck. My entertainment center is exactly 50 inches wide (of course it has shelves on each side so I must stick with only 50 inches of space (the Sony EX 700)has a width of 49.38 inches; would there be a problem with that fitting in. It appears to me that the Vizio my have more bang for the buck (features etc.) than the Sony and Sony's service, IMHO, leaves more than a bit to be desired.
What say you? Please reply at your earliest convenience to: kmil123@msn.com
Thanks!!!
kmil is offline
Old 04-05-2010, 12:56 PM
Teh Roach's Avatar
Just bought a new Sony bravia kdl40v5810, It cost £550.00 with a 5year warrenty, We spent much discussion deciding between that T.V and the Samsung LE40B550/LE40B530 (couldnt see much difference except the contrast ratio?). Decided on the Bravia as it had PiP but didnt realise you had to use the freeview picture so its no use to us. We have 90days to return the T.V for any reason so are considering replacing it with the Samsung, what are your thoughts on this? Or any other T.V you would reccomend for £400.00-£550.00 37-40inch. Thanks for any help.
Edit: and were not bothered in the internet apps/widgets, just picture.
Teh Roach is offline
Old 04-05-2010, 06:33 PM
BiscoJosh's Avatar
5. Room lighting
anyone? please?!
Old 04-06-2010, 05:20 PM
csjunkie18's Avatar
Hello everyone, I am new to the forums and I am in the market for a new TV. Ideally, I would like to keep my spending between $2,500 and $3,200. I have been searching high and wide for TVs and have bought and returned a few, but I just cant seem to find "The ONE" (TV wise). I am turning to you all, becuase I have read around the forums and you all seem to know alot of the TV tech.
I am looking for a 50-60 Inch HDTV. I am not bias against one particular technology, but if you read below I have some of the models I have purchased and what I disliked about them.
Previous Purchases...
PN50b650 -> terrible buzzing
UN55c6300 -> blacks were too grey and shadow detail was awful.
LN52B750 -> probably should have kept this one, but I wanted to go with newer tech/bigger screen
I am currently with a LG 55lh90, which is not bad but feature wise it does not prepare me for the future of TV tech and there is no way to upgrade the firmware unless you call LG (lame), as well as LGs poor 240hz processing. I bought this one at Costco so I have almost 3 months to make up my mind TV wise and find a new one.
So... with all that said, what TV can I get around that price range that will produce the best possible picture?
I am currently looking at the UN55C8000 (I wish I got the UN55B8500!), but I dunno about the new dimming tech and its zone features.
I could really use all of your knowledge and helpful advice in this area... I feel like I am about to pull my hair out when it comes to trying to find the perfect TV.
csjunkie18 is offline
Old 04-06-2010, 05:49 PM
dabeastro's Avatar
Looking for 32-37" 720P plasma or LCD for use in small dark bedroom. Suggestions?
dabeastro is offline
Old 04-06-2010, 06:16 PM
jsntrmn's Avatar
1. Budget
$1,000 - $1,500 USD (i would prefer to stay toward the lower end of my budget so that i might use the leftover money to put toward some audio equipment.)
2. Seating distance
9 - 10 feet
i have a very large stand or could alternatively wall mount, so i don't suppose i have any real limitations other than my wallet.
4. Uses and sources
hd cable - primary day to day viewing will be via a comcast hd stb.
blu-ray - i will certainly be getting a blu-ray player shortly after i get the tv.
htpc - my htpc usage will be rather frequent, the source being hdmi passed from a radeon hd 5770. a lot of movie watching and also some gaming.
console gaming - xbox360 and wii
5. Room lighting
the room is quite dark no matter the time of day with very, very little natural light. the incandescent lighting is generally kept on the dim side, too.
i'm simply overwhelmed with the array of choices in the hdtv market these days. i don't even know where to begin. i have looked over the seating distance charts and used the calculator linked from the opening of this thread. i've also considered my viewing distance in terms of resolution, and if i understand the data correctly, at my distance of 9 to 10 feet i should stick to a 720p set. i don't believe i can afford the screen size necessary to take full advantage of 1080p. please correct me if i'm wrong on that point, though.
as for the dizzying amount of features available from set to set, again, i'm not sure where to begin. with my lighting, i'm under the impression that perhaps a plasma would be a better choice, but then i start reading about all this burn-in business, not to mention it seems as though manufacturers are abandoning plasma technology. so if someone could at least confirm to me that lcd is a good choice, i would very much appreciate it.
beyond that, i'm open to any and all suggestions. this will be a big investment for me. i'm going to be putting a majority of my tax return into this tv, and i'm not the sort to continually go out and buy the latest and greatest (can't afford it, hah), so i want a set that will last and give me plenty of enjoyment for some time to come.
jsntrmn is offline
Old 04-08-2010, 05:56 AM
OJmobileII's Avatar
1. Budget
Approx. $1000 US
2. Seating distance
10 feet
Larger than current 42". I am looking at 46" Samsung C630 & Sony EX500
4. Uses and sources
HD Satelite for sports & tv shows. No blu ray or external audio in immediate future. I would like to run content from my computer to tv. No gaming, really.
5. Room lighting
A wall of floor-to-ceiling north facing windows perpendicular to TV screen. TV is replacing 42" single pane panasonic plasma which glares too much during daytime.
I want 120hz. I am basically deciding between Samsung C630 & Sony EX500 at this point. I foolishly started my own thread (http://www.avsforum.com/avs-vb/showthread.php?t=1241175) before posting here. I saw some opinions on page 8, but was hoping for more.
OJmobileII is offline
Old 04-09-2010, 11:09 AM
bsummmit's Avatar
Looking for some help. Thought I was going to get a Panasonic G10 until i was reading reviews about how the black color starts to crap the bed after 1500 hours.
Budget 1000
Uses PS3
Please Help.
bsummmit is offline
Old 04-09-2010, 12:17 PM
rrajasekar's Avatar
I have been waiting a long to get a HDTV. I have read a decent number of reviews. I'm still a bit confused.
My requirement is a latest Samsung LED TV, 46" and best in all other features like (local dimming, 240Hz, contrast ratio etc). I'm not interested in 3D.
Considering all that, is B8500 the best option for me? Or put it other way, is B8500 the best 2D tv in Samsung?
Thanks very much!!
rrajasekar is offline
Old 04-11-2010, 01:58 PM
thecolonel's Avatar
1. Budget
$1500
2. Seating distance
8-10ft
40-42" only
4. Uses and sources
bedroom tv, HD cable, SD cable, Blu Ray, some xbox360
5. Room lighting
bedroom with two windows on wall behind tv, but lighting is controlled
Denon 3808ci
Definitive Technology BP7002
Definitive Technology CLR 2002
(4) Definitive Technology BPX
(2) Definitive Technology BP1.2X
thecolonel is offline
Old 04-14-2010, 04:44 AM
desiking911's Avatar
1. Budget
$200 to $350
2. Seating distance
8-10ft
22-26" only
4. Uses and sources
bedroom tv, dish network 311 receiver using RCA-type audio/video outputs . xbox 360 . PC .PS3. PS2 . Wii . Xbox. western digital media player
5. Room lighting
bedroom with one windows on wall behind tv, lighting is controlled
thank you all for the help
desiking911 is offline
Old 04-14-2010, 02:25 PM
Max Patlick's Avatar
1. Budget
$5-600
30-40"
4. Uses and sources
mostly gaming, Super Street Fighter 4 to be specific.. Input lag is my primary concern.
Are there any available sets with exemplary performance in the category of input lag? 2 weeks ago, I tried to purchase a panasonic TC-L32X1, only to later receive an email that it was out of stock. Whats the next best thing? I've been poking around the many input lag threads, I guess what I want is an IPS panel right? It seems like everything that's been recommended is sold out/been updated to a newer model that doesn't perform as well.
Max Patlick is offline
Old 04-14-2010, 04:02 PM
cpc
cpc's Avatar
I figure a 46" 1080p is plenty for the small space I have. Is a 46" 1080p a good size for 6 to 7 feet? I figure 40 or 42" is probably ok, but I do like a big screen, but figured 50" or larger a bit too big for smaller bedroom and also more $$...thoughts?
Also, in particular, I was thinking of the LC46E77UN for the bedroom. Any issues with this model? Banding etc? Or do I need to find a 700 series to be free of banding? (actually can't find a 700 series Sharp 46")
1. Budget
<$1500
2. Seating distance
6-7 ft
40-50" ...think 46" best for bedroom?
4. Uses and sources
bedroom tv, HD cable, SD cable, Blu Ray & DVD
5. Room lighting
small bedroom with one window on wall to the right of tv, but lighting can be controlled (window blocked/shaded)
cpc is offline
Old 04-15-2010, 08:20 AM
dmk1974's Avatar
1. Budget
$500-$700
2. Seating distance
~10ft (bed)
On a stand a few feet past foot of bed.
4. Uses and sources
Comcast, DVD, BD
5. Room lighting
Bedroom with window on adjacent wall. Usually night-stand lamp lighting.
My In-Laws went over to Abt yesterday to look at TVs. They are planning to put it in their bedroom and feel that a 32" is a suitable size. The two in the link below are the ones they were looking at. They are leaning towards the LED model, but I was wondering why that would be a better choice compared to the LCD model that I also linked to compare? I mean, shouldn't they go for 1080p instead of 720p (even if it is LED backlit)? Thanks!
http://www.abt.com/scripts/site/site...e_chk_45081=on
dmk1974 is offline
Old 04-15-2010, 08:21 AM
yumms's Avatar
Anyone have opinions on this tv? - Panasonic TC-L32C22? http://www2.panasonic.com/consumer-e...702#tabsection
It has an IPS panel and its a decent price ($400) - Not sure about and blurring or ghosting though. Need a tv for gaming and general tv watching.
yumms is offline
Old 04-15-2010, 10:51 AM
kemetblk's Avatar
Quoted: 13 Post(s)
1. Budget
<$3000
2. Seating distance
8-12 ft
On a stand or possibly wall mounted, eye level while seated.
4. Uses and sources
HD Cable, HD-DVD, Blu-ray, Xbox 360, HTPC (maybe)
5. Room lighting
Controlled. Large window facing tv, but curtains stay closed.
Looking into getting a new tv. Minimum size would be 55", but I would prefer 58"-65". I am replacing a Samsung HL-S6187 DLP and think I have narrowed it down to the Panasonic 58V10 or the Sharp LC-60LE810UN. has anyone had any experience with the new Quattron displays? No store around here has one on display, but I can order one at the big box.
HD-DVD: 55 / Blu-ray: 97
newest: Brotherhood of the Wolf / Kingsmen, How to Train your Dragon
AVR: Marantz SR6006
F/C/R: Polk RTi A9's / CSi A6 / Speakercraft AIMWIDE 3 / Sub: SVS PB12-NSD
SonyXBR-75X940D Samsung BD-P2550, Toshiba HD-A30, Nvidia Shield TV (2015), Xbox360 Elite, PS3, WDTV Live
kemetblk is offline
Old 04-16-2010, 12:34 AM
pattirose4's Avatar
I thought I could do this by myself but after looking at tv's today and reading even more posts tonight I can see I definitely need help. I was all set to get a Sony Bravia KDL46W5100, then today I compared the Sony KDL 46EX400 and the Sony KDL 40SL150 to a Sharp LC46SB57U and a Sharp LC52SB57U and both Sharp sets looked much much better, they had on a Disney animated dvd, I don't know how much of a difference that would make but the Sharp picture was much clearer and the Sonys actually looked blurry around the edges.
I was leaning towards the Sony because of the USB port and the dolby digital, but today I see both Sharps also have dolby digital so now I am even more confused. They did have a Sony that looked fabulous but they don't sell that model nor could I find out what it was as the clerk told me that it was a special display screen that Sony had given them. That was at Superstore, I plan to go to FS next and do some comparing there.
I am wondering if I should just go with what looks best to me or go by the specs and the recommendations? Will adjusting the settings on the tvs make THAT much difference and is there alot of difference between what is being watched, animation, action movie, blueray or network tv? What about dolby? Isn't that about the best factory sound I can get included with a tv?
I don't want a tv that I will have to take back and forth to the store, I want to buy a reliable one that will last a few years with no issues.
I need decent audio quality as I don't want to have to purchase speakers.
I have a separate tv in the bedroom for gaming so that is not an issue.
Viewing will be 6-8 feet from the screen in a somewhat bright room (patio doors with sheers but no sun hitting the screen) and I like to watch movies/tv in the dark in the evening, I don't watch alot in the daytime.
I have no blueray movies so that isn't an issue and neither are sports, just mainly movies and a little network tv.
I want to be able to watch movies from my laptop on the tv - USB port? And being able to use a thumb drive/memory stick would be awesome also.
I have read so much about the issues with the flashlighting, heat, cloudiness, nasty burning smells, VA panels vs IPS panels, buzzing sounds at high altitudes, problems with pixels etc etc, my head is buzzing!
My budget - less than $1500 but $1000 would be better, I can also wait for a sale, I am in Canada.
Any thoughts by anyone would be greatly appreciated and thank you for taking the time to read this.
pattirose4 is offline
Old 04-17-2010, 08:13 AM
kibokun's Avatar
1. Budget: $450-500
2. Seating distance: 5-7 feet
3. Uses and sources: Video games primarily. We want to be comfortable with 4 people playing split-screen. Squeezing people onto my 19" monitor in my room is hell. Movies would be coming from a laptop and PROBABLY streaming megavideo or something, so quality isn't a huge concern here. It will suck no matter what.
4. Room lighting: Not sure yet, since we're moving, but not a huge concern for me.
kibokun is offline
Old 04-17-2010, 08:28 AM
cpc
cpc's Avatar
I have read that the 240 Hz feature is not one that most feel is essential or a major benefit over the 120 Hz feature. I could be mistaken. It may be possible that the 240 Hz sets are much better with sports and fast motion and have reduced motion blur, but, I read at least one instance that people find 240 Hz can be weird. From what I understand, 120 Hz is good enough for movies and tv because 120 Hz is high enough and an even multiple of both 30 fields per second tv video (30 x 4) and 24 frames per second film (24 x 5).
I'd be interested to know what people think of the 46 to 52" LCD sets and which is prefered.
Thanks very much!!
cpc is offline
Old 04-17-2010, 06:43 PM
Xpred's Avatar
1. Budget = around $600 for each TV (2 total)
2. Seating distance = It doesn't matter in this case as the two TVs would be place in a restaurant.
3. Size/placement limitations = We are planning one TV to be angled in the corner tilted slightly downwards so the customers either far or near the table can view them. The other TV would be placed flat against the wall.
4. Uses and sources = They will be placed in a restaurant environment. We are going to run them for a few hours a day. Depending on how many customers, we may choose to turn them off or leave them on straight for a few hours.
5. Room lighting = During the day, we usually shield our customers from sunlight, so normal light just shining upon the shades is the lighting condition. However, at night, the environment is lit up with ample lighting. This shouldn't be a problem.
Hey everyone. Glad to see this thread here. I need some major help. I'm trying to purchase 2 TVs (most likely the same ones) for my parents' restaurant. I have been looking at 40"-42" LCD TVs in the $600 price range. I manage to find these ones at different retailers. They were roughly similar in price (give or take):
Samsung LN40C550
Toshiba 40XV645U
Sony KDL-40EX400
I believe the Samsung & Sony's are only 60 Hz while the Toshiba is 120 Hz.
There's also another TV I managed to find. It is the Toshiba 40E200U, which I am not sure at all about the specs. It just says "Black Gloss."
Which TV should I get? Or is there another TV in the similar price & size range that would do just fine?
I do not know much about LCD HDTVs and recommendations about one. In fact, I have never bought any myself. Usually my brother, who is more TV savy, buys them. Please advise. Thank you very much!
Xpred is offline
Old 04-17-2010, 09:00 PM
yumms's Avatar
Budget= less than $500
Seating distance = 7-10 feet
Uses and sources = HD gaming and SD tv watching
So far I've been looking at these models. Which you guys go for?
Panasonic TC-L32X2
LG 32LD350
Sony BRAVIA EX308
Any others to look at?
yumms is offline
Old 04-18-2010, 06:13 PM
obi1234's Avatar
I almost drove myself crazy with specs & comparisons. It is a big investment and it's easy to become too paralyzed to choose, for fear of making a costly mistake.
  1. Relax - you can't make a "perfect" choice there's always bigger & better.
  2. Costco, Sam's Club, etc have great return policies and sell extended warranties.
  3. You want a matte finish screen - glare kills viewing enjoyment.
  4. Make sure it has the right inputs for what you own and will be getting.
  5. Only research the models within your budget - don't overload on info.
  6. Consider the source - SD doesn't look so hot on most HDTVs.
  7. Size matters. Few people wish they had bought a smaller set.
If you want something that looks great right out of the box, with lots of inputs, and excellent bang for your buck - check out the Vizio brand. Customer service reps are pleasant and located in US.
I own the Vizio 55 inch model and recommend it. I made the transition to HD - including 5 year extended warranty and a new blu-ray player for thousands less than just a TV of another brand. I also have lots of friends with various size Vizio models and they are all happy.
I don't work for Vizio by the way. I'm just a fan of their products and pricing.
obi1234 is offline
Old 04-19-2010, 02:50 PM
Guibs's Avatar
First post as well. I'd like some recommandation for a new TV.
1. Budget: 2000$ give or take.
2. Seating distance: 8 feet
3. Uses and sources: Video games (xbox 360), regular HD signal for TV, Watch DVD and hopefully Blu rays soon.
4. Room lighting: it's a basement, 2 windows in the back of the couch, so in front of the TV at about 10 feet but I have curtains that I could close to close the light during the day.
I have right now a Samsung 32" 720P. I'm finding it too small and want to upgrade. 3D movie would be nice but not mandatory. I want great picture and contrast. Need good response time because of video gaming. I'm looking toward either another Samsung or a Sony but open for other option.
Note, I'm from Canada in case that changes something.
My problem is everytime I think I found something that could be could, I make the mistake of reading too much this forum and read about all of these "flaws" and how the next model corrects this, etc... and I never end up buying. I can't wait a few more months in case waiting for 2010 models makes sense.
Guibs is offline
Old 04-19-2010, 03:47 PM
travs69's Avatar
I currently have a Toshiba 62HMX DLP that I believe the light engine is going out on. I'm going to repair it, and as much as I like the TV the PQ on it does not compare to the newer TV's. Especially the blacks compared to newer LCD/LED's.
I am not sure if I should be going towards LCD, LED, or Plasma.
The TV is used a lot, kids watch it in the morning while eating breakfast, I normally have it on while I'm working, and the wife watches it at night. When we watch movies we usually dim all the lights and we watch a lot of Sci-Fi
1. Budget - < $4000 preferably
2. Seating distance - ~10 - 15ft depending on where you are sitting in my living room.
3. I really don't want to go smaller than a 60.
4. I listed some of uses above, I run HD directv, dvd, blu-ray (via ps3), and a wii through it. I have hooked my pc up to it in the past.
5. I have a large window that sits beside/behind the tv and a door the opens about 20 feet to the right of it that creates a horrible glare if it is open to far. I also have a lamp that I normally won't leave it on because it creates a glare for the people viewing on the other side of the room from the lamp.
My biggest concern is if I am picking the correct technology (LCD) or if I should be open minded (LED or Plasma?). When I bought my DLP i couldn't find better blacks, since then almost everything I have seen has blow it away. My receiver doesn't have HDMI inputs but my current TV has 2 of them. I'd minimally like the new TV to have at least 4 if not 6 and to have some kind of digital output to run back to my receiver.
Thanks in advance..
Travis
Edit to add 2 TV's I am reviewing
Sharp 60LE810UN
Sony KDL60EX700
Trying to find a 60in LCD TV with LED local dimming at 240hz seems to be impossible..
travs69 is offline
Old 04-20-2010, 02:15 PM
shamoo1's Avatar
This TV is for light use in the bedroom. Family room has PRO 151FD so I already know this TV will be inferior, but the main restriction is size since it's going in an armoir. It can accomodate a sony nx700 40" with about .5-1" to spare.
1. Budget: flexible
2. Seating distance: 10-12 feet
3. Uses and sources: HD satellite, blu ray, internet stream
4. Room lighting: minimal ambient light and sitting within armoir.
Looking for best overall TV... serious movie watching etc is done on my Elite plasma so I'm not looking for a jaw dropper, just something that fits the bill and has convenience features. Curious how comparable LG, Sharp and Sammy compares, all reviews I've read seem biased and knock the Sony on its PQ... as long as PQ isn't absolute bunk I don't mind some irregularity.
shamoo1 is offline
Lcd Hdtv , Samsung 55 Inch Led Hdtv Un55b8500 , Samsung Un55b8000 55 Inch 1080p 240 Hz Led Hdtv , Lg 55lh40 55 Inch Lcd Hdtv , Toshiba , Cables Interconnects
