the "help me choose an LCD" thread - Page 191 - AVS Forum
post #5701 of 5702 Old Yesterday, 03:44 PM
Liked: 0
W800b
I am looking to buy the Sony 50W800B but seems like the stocks aren't available widely on Amazon and Best Buy Stores. Amazon mentioned they don't know when it will be restocked and Best Buy mentioned they are being discontinued.
So, wanted to check if W800B is being discontinued or its just a temporary availability problem?
sharathontherun is offline
post #5702 of 5702 Old Today, 03:06 AM
LeahOlin's Avatar
Quoted: 13 Post(s)
Originally Posted by DevonJD View Post
Moving into new house and have been researching new 60" tvs, but its driving me bonkers with reviews all over the place. Any help would really be appreciated. TV will be wall mounted in a fairly well lit living room.
Budget: Don't want to spend more than $1500
Brand: Doesn't matter
Size: 60" maybe 65"
Extras: wifi is a plus, smart features/3d not necessary.
Other than that, don't care all that much. Will be hooked up to cable box and probably an apple tv. We are upgrading from a 47" Vizio (e3d470vx).
$1300 for a higher mid range samsung 60 inch LED tv
http://www.amazon.com/Samsung-UN60H6350-60-Inch-1080p-120Hz/dp/B00ID2HGQ8/
LeahOlin is offline
Reply LCD Flat Panel Displays
Lcd Hdtv , Samsung 55 Inch Led Hdtv Un55b8500 , Samsung Un55b8000 55 Inch 1080p 240 Hz Led Hdtv , Lg 55lh40 55 Inch Lcd Hdtv , Toshiba , Cables Interconnects
