the "help me choose an LCD" thread - Page 225 - AVS | Home Theater Discussions And Reviews
post #6721 of 6724 Unread Yesterday, 07:09 AM
Brahmzy's Avatar
Quoted: 234 Post(s)
Liked: 155
I use the curved JU7500 40" as my main monitor - it's fantastic.
Full 4K 60hz 4:4:4 support. You need an nVidia 9-series card to go with it.
As far as TV size, ALWAYS go as big as you can afford. The bigger the better. My 70" is too dang small. Looking to get a Sharp 80 UH30 when they come out.
HTPC | 12TB NAS | DENON 2809ci | Sharp 70
Klipsch RF-7II,RC-64II,CDT-5650-CII | SVS SB-2000 x2
Brahmzy is online now
post #6722 of 6724 Unread Yesterday, 10:04 AM
sigs21's Avatar
Hi - all given this size of the room below.. I don't have the actually size of the Fire place with me.. and the brightness of the room.. looking at a 65LED or above- what would you recommend to mount on the fire place we don't want to keep the TV where it is currently at- looking at the js8500 samsung- or may just go with a non 4k set. and would that mounting have to much neck strain..
ID:	730450   Click image for larger version
sigs21 is offline
post #6723 of 6724 Unread Today, 01:53 AM
Liked: 0
Hi everyone, first time poster requesting unusual advice.
I have a brightly lit family room with Glass Sliding Doors all around. I would like to do a setup with 4 TVs forming a video wall. Seating distance is about 10'.
Bezel size is a consideration for this application and so is picture quality. TVs will be used to watch regular TV shows and movies. No gaming or any other special needs.
I can use 55" or 60" TVs in the space to form the video wall and not look too overwhelming in the room.
I have been looking at the 2015 Vizio M or the Samsung UN H7150 for this application based on reviews I have been reading online.
One is a 4k set and the other is a 1080P. Any suggestions regarding these 2 units or some other options to consider?
Fred
FredBMOC is offline
post #6724 of 6724 Unread Today, 08:09 AM
proceedputty's Avatar
Hello,
Looking to replace my Samsung 63" plasma, the 7000 series. It's starting to get the pink bars on a full white screen, plus I need something bigger. Bottom line though I can wait if the 'right" TV for me is just around the corner. Unfortunately projection is not an option. My setup:
1. Budget - $10k, although I would much prefer to spend less.
2. Seating distance - 15 feet. Room really won't allow for me to sit closer.
3. Size/placement limitations - None, except I have to wall mount.
4. Uses and sources - 50/50 Fios TV and an Oppo 103D.
5. Room lighting - I can control light in the room.
I have my eyes set on the Samsung 85" 8550, but those are at the top of my price range and don't seem to have a newer model coming. Plus they don't look like they will support the newer specs coming out. Any advice is appreciated. Thanks.
Putty
proceedputty is online now
Reply LCD Flat Panel Displays
Lcd Hdtv , Samsung 55 Inch Led Hdtv Un55b8500 , Samsung Un55b8000 55 Inch 1080p 240 Hz Led Hdtv , Lg 55lh40 55 Inch Lcd Hdtv , Toshiba , Cables Interconnects
