the "help me choose an LCD" thread - Page 248 - AVS Forum | Home Theater Discussions And Reviews
post #7411 of 7414 Old 08-31-2015, 08:41 PM
golfster's Avatar
Quoted: 68 Post(s)
Liked: 44
If you are a Costco member the LG 65UF7690 - 65" 4k is on sale for $2100. The 65" Vizio M-series is on sale for $1449 and if you only need 1080p the E-series is a whopping bargain at $879.
golfster is offline
post #7412 of 7414 Old 08-31-2015, 08:43 PM
dalto's Avatar
Quoted: 930 Post(s)
Liked: 501
I think that particular LG uses a VA panel as well, doesn't it?
dalto is online now
post #7413 of 7414 Old Yesterday, 09:20 AM
golfster's Avatar
Quoted: 68 Post(s)
Liked: 44
You may be correct. LG does not list it either way, but the 65UF7700 does for $1800 at Best Buy.
golfster is offline
post #7414 of 7414 Old Today, 06:20 AM
Guitar Ed's Avatar
I am looking for a new television and any help would be greatly appreciated.
1. Budget is under $2500 (certainly under $3000 if the right set is available). Could be talked into under $2K if right set.
2. Viewing area has 2 couches and a large chair in a U shape with large couch facing television and smaller couch at 90 degrees and chair at 45 degrees to TV. The center of the main sofa is12 feet away and directly in front of television. The side couch and chair on the opposite sides roughly 7 feet from the television and 5.5 feet off the center of the Entertainment Center. Picture quality is more important to me and I sit in the main sofa directly in front of the TV. This is less important for my wife.
3. Television will go in a large entertainment system, which can easily handle a 65" television up to 37.5" tall. 70" will be too big and wife will veto as well.
4. Source will be Cable/Sat, BluRay, and Netflix/Amazon Prime.
Sports-Primarily Golf and Football.
Movies-all kinds
My wife watches HDTV and such stations 24/7 (seems like it).
This television will almost certainly never be used to play games.
5. Television sits in a living room with windows on both sides. Bright environment during the day.
Will add a sound bar from simplicity purposes and better audio (use Yamaha A3000 surround sound for movies) over television speakers.
Thanks, again. Ed
Guitar Ed is online now
Reply LCD Flat Panel Displays
Lcd Hdtv , Samsung 55 Inch Led Hdtv Un55b8500 , Samsung Un55b8000 55 Inch 1080p 240 Hz Led Hdtv , Lg 55lh40 55 Inch Lcd Hdtv , Toshiba , Cables Interconnects
