the "help me choose an LCD" thread - Page 351 - AVS Forum | Home Theater Discussions And Reviews
 276Likes
post #10501 of 10501 Old Today, 07:08 PM
Quoted: 954 Post(s)
Liked: 501
Thinking about a new TV, though I don't need one. Is the Vizio 65" currently on sale at Costco the current best deal if one wants
-A 4k TV with minimal bezel width that is no bigger than 62" wide and 36" high when wall mounted
-Turns on and off reliably with a Harmony remote (I don't expect to use any other internal functions)
-Doesn't spy on you
-Isn't Samsung (don't like the brand)
Or to use the thread format:
1. Budget
N/A; potential impulse-ish buy.
2. Seating distance
About 13-14'.
3. Size/placement limitations
Mounted above fireplace;
Maximum width 62" and maximum height 36"
Ideally lower weight than current LCD (~70lbs) and fits on same mounting bracket.
4. Uses and sources
All external sources (cable, Roku, AppleTV, Oppo) running through AVR; no interest in internal sources.
5. Room lighting
Well lit living room.
"In many cases there aren’t two sides unless one side is 'reality' and the other is 'nonsense.'" - Phil Plait
Serious Audio Blog
DS-21 is offline
Reply LCD Flat Panel Displays
Lcd Hdtv , Samsung 55 Inch Led Hdtv Un55b8500 , Samsung Un55b8000 55 Inch 1080p 240 Hz Led Hdtv , Lg 55lh40 55 Inch Lcd Hdtv , Toshiba , Cables Interconnects
