the "help me choose an LCD" thread - Page 353 - AVS Forum | Home Theater Discussions And Reviews
 283Likes
post #10561 of 10568 Old 05-23-2017, 09:32 AM
VA_DaveB's Avatar
Quoted: 344 Post(s)
Liked: 108
Originally Posted by illusio26 View Post
Although the one thing I don't like about Vizios are the smartcast features. I can get by without the Tv Tuner, but I'd rather have apps on the TV than have to stream to it from a device.
That's what they're changing for 2017 - using a standard remote with the menus on the TV. No more tablet.
VA_DaveB is online now
post #10562 of 10568 Old 05-23-2017, 01:11 PM
Liked: 0
Originally Posted by top_down View Post
Hi All,
I'm looking at Costco's current offerings and wondered what you all recommended for a 70-75" set to replace a 9(?) year old 67" Samsung DLP. I'm hoping I can get at least as much life out of this next tv.
Big room, lots of light through a 12' arcadia door on the north side of the room. 70% OTA, 25% Netflix and 5% DVDs. TV is on east wall and is 13' from the east facing sofa. There is another sofa facing north that is 90 degrees to the TV. Needless to say the DLP is barely watchable from this sofa during the day and I expect that will change with even the lowest cost LCD.
Looking at the $2000-3500 range. I'd prefer to buy it at Costco because they are close and I think it will be relatively easy to deal with them if there is a problem. So I think that leaves me with:
Vizio P75-C1
Vizio E75-E3
LG 75UJ657A
Samsung UN75JU7100
I might consider the Vizio E80 if they still have them at the online price - says it ended 4 days ago. It's a bit of a stretch price wise. I'd love to hear the P75 vs E80 argument since there is not much price difference.
Let me know what you think of these and if I missed anything at the store or online that I should consider. The Samsung looked good in the store but the reviews are concerning. Not crazy about the brushed gray bezel on the LG.
I'm not a purist. I simply want something bigger, brighter, sharper and with better off axis viewing in a bright room. I would hope that it will last 9 years like the DLP did. I think just about any of these will work, I just don't want to miss a key feature or end up with something that dies on me in a year or two or has some crazy lines or backlighting issues. I guess I will also need a recommendation on an OTA tuner since I gather that none of these have one.
I'm in the same 75-inch market. Looked at the Costo options last weekend.
LG - I thought the picture was muddy and low-contrast compared to others. It's edge-lit.
Vizio M70 - Good picture but only comes in 70-inch at Costco. You can't find a 2016 model M75 anywhere. The 2017 M75 will be out soon but at around $3000.
Vizio P75 - Costco has the 2016 model, and the soon-to-appear 2017 model will be exactly the same except it won't ship with the remote. The 2016 model will get a software upgrade this summer that will improve HDR and will put the apps on-screen like the 2017. The 2017 will probably sell for $4000 or so.
Vizio E75 - With a 60-hz refresh rate and other lower-end specs I did not consider it.
So I'm going with the 2016 P75, but not from Costco, which would charge me tax. Vizio is offering 5% off if you buy direct from them and they still have 2016's in stock. And at least where I live they would not charge tax and shipping is free. That saves me $280.
Doug P is offline
post #10563 of 10568 Old Yesterday, 04:01 PM
dangerfar's Avatar
Hi Everyone,
I had my Panasonic P50G20 crap out on me, so I'm in the market for a new TV. Basically I'm trying to find something that will get me 80-90% of the way to a LG B6 OLED for a greater chunk of the price cheaper. Obviously gauging 80-90% of picture quality is a difficult task, but I figured this'd be the place to find the folks to do it :-).
To answer the questions in the OP:
1. Budget: <$1500 (since the B6 is $2k if I go too much above $1500 seems like I might as well go for that).
2. Seating distance: ~10 feet or so
3. Size/placement limitations: 55" on a TV stand
4. Uses and sources: Gaming (PS4), Movies (Netflix, Hulu, Amazon Prime, HBO Go, Blu-Ray, Plex), Sports (Digital Over air), and TV (same as movies).
5. Room lighting: Controlled. Should be able to block most light and most use will be at night anyway. During the day may be some glare to the side.
Picture quality is important to me, but I'm not as discriminating as my taste would suggest I don't think. For instance when gaming I can't see much difference in most games between 30 and 60 fps, and I've never cared for any effect I did see from 120hz+ (never noticed anything with normal settings, and I hate interpolation) nor have I ever noticed any ghosting (I actually still don't even know what that means because of this) on a set w/ 8ms response time (never tried higher than that). 4K doesn't seem terribly important as content appears to be lacking, and I can do most all streaming above via the PS4 so the smart-ness of the TV isn't that important either. HDR, and contrast and color correctness, are the most important things to me by a wide margin (hence my plasma from before and leaning toward the OLED if I can't find a better bargain).
Also if it's helpful I'm a Costco member and live in a metro area where I have easy access to most any big box store (including things like MicroCenter, Fry's, Brandsmart, etc), and am looking to ideally get it this weekend when Memorial Day sales are on.
I'm leaning somewhat in the direction of the Samsung UN55MU7000FXZA (or 6000) since it's about a grand cheaper and seems pretty solid, but what other deals/sets should I consider, or if anyone thinks nothing will come close to my vague 80-90% of the B6 for the budget given let me know that too.
dangerfar is online now
post #10564 of 10568 Old Yesterday, 05:12 PM
VA_DaveB's Avatar
Quoted: 344 Post(s)
Liked: 108
Originally Posted by dangerfar View Post
Hi Everyone,
I posted the info below in another thread. You can get the LG B6 OLED with a sound system for $1,700 all in.
At BuyDig via Techbargains.com get the LG OLED55C6P 55" Curved 4K Ultra HD 3D TV + LG SJ8 300W 4.1ch WiFi Slim Sound Bar with Wireless Subwoofer for $1,694 with free shipping.
post #10565 of 10568 Old Today, 04:17 AM
VA_DaveB's Avatar
Quoted: 344 Post(s)
Liked: 108
Originally Posted by preetyjess01 View Post
Hey, I want to buy a new HDTV. But, I'm confused in LCD tv and LED tv. So, please give me some suggestions.
What is your budget? What size are you interested in? Any significant viewing angles in the room?
post #10566 of 10568 Old Today, 08:07 AM
dangerfar's Avatar
Nice thanks for the heads up! I don't really want a curved screen, but depending on the quality of that sound bar may be worth it. Are there any other differences between the B6 and C6 besides the curved screen?
Still though, if I can get a high quality flat screen that has good black level and HDR performance for under $1500 that may be a better ticket. I also realized I should have noted I do want a TV tuner (seemingly eliminating the Vizio's from contention unfortunately) since I do want to use basic cable that won't have a box.
post #10567 of 10568 Old Today, 10:03 AM
VA_DaveB's Avatar
Quoted: 344 Post(s)
Liked: 108
Then you should look at the Sony XBR55X900E, which is the best in that price range, and is currently going for $1,400. It's a much better set than that Samsung UN55MU7000 you're thinking about.
dangerfar likes this.
post #10568 of 10568 Old Today, 01:43 PM
dangerfar's Avatar
How would that compare to the KS8000 (which from reading here seems much better than this year's models) for $1k?
Reply LCD Flat Panel Displays
Lcd Hdtv , Samsung 55 Inch Led Hdtv Un55b8500 , Samsung Un55b8000 55 Inch 1080p 240 Hz Led Hdtv , Lg 55lh40 55 Inch Lcd Hdtv , Toshiba , Cables Interconnects
