Official 2010 Sony ...HX701 Owners Calibration thread - Page 17 - AVS Forum | Home Theater Discussions And Reviews
Old 08-19-2010, 07:03 AM
whscott's Avatar
Originally Posted by Granto86 View Post
I have a question, I currently have my cable box, ps3, and xbox hooked up to HDMI through my Denon receiver, but I noticed when I try to stream pandora or netflix from the TV menu, the sound does not come out the speakers but the TV itself. Is there anyway to change this so I can use my surround speakers with the tv menu?
Connect your tv audio out by optical(toslink) cable to an optical input on the receiver and switch audio inputs when watching netflix, etc.
whscott is offline
Old 08-19-2010, 08:14 AM
Guibs's Avatar
Originally Posted by johanverschuren View Post
hughh: HDTVTest.co.uk have tested the KDL-40EX703 and they say that the KDL40EX703 is also the first Sony-branded HDTV they have reviewed that uses a Sharp UV2A panel, rather than the Super PVA type which Sony has been manufacturing with Samsung for half a decade now.
http://www.hdtvtest.co.uk/news/sony-...0100724786.htm
So your not correct that only the 60" panels have the Sharp UV2A LCD panel. So it is logical that Sony uses also for the HX700 series the Sharp UV2A (deep black) panel. Having said this, most manufactures are not so keen to give information about the source of the LCD panels they use.
hristolav2 did a post in the ex500 topic and info shows the 700 line will have sharp UV2A panels, ex700, nx700 and hx700 all use the same panels.
http://www.avforums.com/forums/11914018-post101.html
If I am not mistaken, either in the ex500 or this thread, someone took a micro shot of the pannel of the HX701 and it's the same pannel as the ex500, which is a samsung PVA pannel and not Sharp's UV2A.
Guibs is offline
Old 08-19-2010, 01:34 PM
hughh's Avatar
Quoted: 35 Post(s)
Liked: 39
hughh: HDTVTest.co.uk have tested the KDL-40EX703 and they say that the KDL40EX703 is also the first Sony-branded HDTV they have reviewed that uses a Sharp UV2A panel, rather than the Super PVA type which Sony has been manufacturing with Samsung for half a decade now.>>>
Johan, noted! Thanks for the information. Also, thanks for providing a link to the test. Overall, great information!
BTW - For those wondering, the reviewed Sony TV corresponds to the US 40EX700.
hughh is offline
Old 08-19-2010, 03:52 PM
johanverschuren's Avatar
I found a review of the KDL-40HX700 and it is in the French language so use Google to translate.
http://www.lesnumeriques.com/sony-br...3_8420_16.html
They say that the default setting (5) for the backlight is too high and recommend 2 as setting. With the lower setting it also lowers the power consumption.
johanverschuren is offline
Old 08-19-2010, 04:05 PM
hughh's Avatar
Quoted: 35 Post(s)
Liked: 39
I keep mine usually at 3. It all depends on how bright your living room is. On a completely dark room, it's still possible to go down to 1 and still get enough brightness. Another advantage is deeper
blacks.
Ooops - My TV is the EX700 and not the HX700. Sorry...
hughh is offline
Old 08-19-2010, 04:10 PM
kyoto's Avatar
My 46HX701 receives automatic updates from Sony. Last night the TV was upgrade to software version PKG4.068AAL. This is the third upgrade I've received and Sony usually lists on their website what was included in the update. Sony hasn't listed on their website what improvements/fixes were included in the new update and still lists the previous version 4.054.
Does anybody know what's new in 4.068?
kyoto is offline
Old 08-19-2010, 07:18 PM
marldonnaharris's Avatar
Picked up my 55HX701 from Costco last Sunday. Yes I became a Costco member just to buy this TV.
I really could not be any more happy! Thanks for the reviews and information concerning this model.
marldonnaharris is offline
Old 08-19-2010, 08:01 PM
Judy52's Avatar
It really is a nice set and Costco is great. I hope you like your set as much as I like mine.
Judy52 is offline
Old 08-21-2010, 04:15 AM
Toski's Avatar
I returned my 40EX500 and bought the 40HX701 at Sam's Club, and I'm kinda dissapointed in that this uses the same sub-pixel structure as the EX500 in the 40". I'm also shocked that it is 240hz with the same sub-pixel structure as a 120hz tv. I was kinda hoping for the B750/XBR9 sub-pixels or the new type of S-PVA sub-pixels, or a Sharp made panel. I wonder if this set can do "Deep Color" as it claims because it would have to be 10-bit, but this same sub-pixel structure is in the EX500 and Samsung C630 (maybe the C650 too) which are rated at 8-bit to my knowledge.
I also have a lot of clouding on my set, and the fact the "Deep Black Panel" is a misnomer doesn't really help. Even with the Backlight set on Min, the set is too bright in a dark room. I don't want to use the Eco features but maybe I should...
Enough with the griping though . The Monolith Design looks great and for some reason the tv seems sharper than my EX500 or C630. I also like that the 240hz seems to have improved the gray-to-gray response time to be near unnoticable.
Toski is offline
Old 08-21-2010, 11:47 AM
HagiGS's Avatar
Just a quick question.
I purchased a 52" EX701 last week and now they got the 55" HX701 at the same price. Should I go and exchange it?
I'm assuming the picture and the audio quality is the exact same, but how is the screen compare as the HX701 is made of glass?
Thanks for any reply guys
HagiGS is offline
Old 08-21-2010, 12:02 PM
Guibs's Avatar
the Ex701 is a LED tv with 120hz with Bravia Engine 2. the HX701 is a CCFL LCD with 240hz and Bravia Engine 3. The HX701 also share the new monolith design while the ex701 does not.
It's hard to just both screen. the ex701 since it's a led is subject to clouding although the HX701 is also the same for some reason.
Guibs is offline
Old 08-21-2010, 12:15 PM
HagiGS's Avatar
So as far as quality wise which one would you or anyone pick? I don't really care about it being LED or LCD nor the 3" advantage over the my 52" EX701.Since all I care about is quality, especially the details when watching a soccer game
HagiGS is offline
Old 08-21-2010, 01:46 PM
hughh's Avatar
Quoted: 35 Post(s)
Liked: 39
Literature on my EX700 (EX701 at Costco) indicates Bravia Engine 3.
hughh is offline
Old 08-21-2010, 01:53 PM
Guibs's Avatar
If you don't mind about not getting the "slim" tv, because the led is slimer, I'd go with the hx701.
Guibs is offline
Old 08-21-2010, 02:04 PM
hughh's Avatar
Quoted: 35 Post(s)
Liked: 39
That's difficult to answer and something you would have to decide for yourself. I have the 60EX700 in a very bright living room and the TV excels, especially in sports. I have only seen the HX701 at Costco and due to the bright living room, the first thing I look for is reflection problems. This HX tv has big problems with refections as seen at Costco. However, if your viewing environment is different than mine, you may find this TV to be sensational, as many people here have stated.
Johaveschuren in a post a few places before yours has a French language review of the HX:
Pro-
- Very good contrast and black level - Monolithic design aesthetically pleasing - Colorimetry faithful DeltaE average below 2 - Good sound quality -
Motionflow 200Hz effective
Against -
- Viewing angles reduced - Subject to glossy reflections and fingerprints - Media Player poor - Remote fairly average
The clouding is a phenomenon affecting the non-uniform brightness LCD panels. It is an anomaly encountered when the backlight is not uniform. This is especially noticeable on dark images or totally black. As you can see in the picture above, some areas of the image appear more clear (lighter) than others.
However, this defect is only visible on a totally black image. We did not feel any discomfort when viewing different scenes from our movies.
hughh is offline
Old 08-23-2010, 11:14 PM
natess's Avatar
quick question..
which picture mode do most of you use? or is there a (for the most part) agreed upon custom set up, if so which is it?
thanks a lot!
natess is offline
Old 08-24-2010, 09:44 AM
For TV content I use the standard settings and for DVD and Blu-ray I use the theater mode. For the settings of your HX700 you can use the settings of HDTVtest.co.uk for the EX700 because the HX700 uses also the Sharp UV2A LCD panel. The backlight setting should be lowered to 3. The default setting for the backlight is 5 which is a bit too bright.
http://www.avsforum.com/avs-vb/showt...9#post18975239
Old 08-25-2010, 01:05 AM
Toski's Avatar
I think the HX701 uses Samsung panels, not Sharp. This post on avforums list most the panels for 2010.
http://www.avforums.com/forums/lcd-l...ls-placed.html
Toski is offline
Old 08-26-2010, 04:47 AM
hx701's Avatar
Has anyone seen any more test reviews or calibration info for the KDL**HX701 or the KDL**HX703 (Aussie model) besides those posted here?
hx701 is offline
Old 08-27-2010, 04:49 AM
Toski: hristolav2 did a post in the ex500 topic and info shows the 700 line will have sharp UV2A panels, ex700, nx700 and hx700 all use the same panels. This is the same post as you mentioned.
Old 08-27-2010, 07:16 AM
Toski's Avatar
I tried looking for that post but couldn't find it. I know my 40HX701 has a Samsung panel because I see the <<< centers of the partially-lit sub-pixels. This is the same sub-pixel structure used in the 40EX500 and Samsung 40C630.
Also, people have said the monolith has "smoked glass" but mine is clear as day.
Toski is offline
Old 08-29-2010, 12:47 AM
kochuvavachan's Avatar
Thanks for all the valuable information - I pulled the plug 2 days back and brought the 55HX701 home I was looking to buy a plasma (54G25), but after I saw the 701 @ Costco, I was blown away! Excellent PQ and blacks!!!
kochuvavachan is offline
Old 08-29-2010, 09:29 AM
jca2112's Avatar
Just picked up the 46HX701 at Costco. (Grabbed the last one they had.) So far we are happy with it -- this is our first HDTV. We've been trying to hold out for DirecTV to release their new DirecTV HD with Tivo receiver before buying a new TV, but our old SD TV finally died yesterday.
Does anyone know if the KDL-46HX701 can use Yahoo Widgets? (For weather, etc.)? There is an option to link the TV to Yahoo via the Sony Essentials account website, but I see no Yahoo widgets on the TV, just the Yahoo Video link in the video menu. (Even after "refreshing internet content".)
Appreciate any help/info.
jca2112 is offline
Old 08-29-2010, 02:46 PM
hughh's Avatar
Quoted: 35 Post(s)
Liked: 39
On my 60EX700, only Yahoo video is available, no weather or any other Yahoo activities.
hughh is offline
Old 09-01-2010, 12:49 AM
hecz's Avatar
hi guys I got a question.
I wil exchange a samsung lnxxb610 for a sony bravia hx701
is that a good deal?
also important can anybody check if the bravia can accept 720 on vga ?
cuz I own a hdfury adpter and without 720 Its useless. thanx!!!!
hecz is offline
Old 09-01-2010, 01:48 AM
More news on panel switching Sony TVs. There is a sequence on the remote control to get into the service mode. There you can find the parts.
http://www.digitalversus.com/news-pa...ews-15489.html
Specification HX700 LCD Panels:
* 40" (40HX700) : PVA (Samsung, panel number: LTY 400HL01)
* 46" (46HX700) : PVA (Samsung, panel number: LTY 460HQ02)
Old 09-01-2010, 06:27 AM
skwieradee's Avatar
Hi Guys, could somebody advice me what is the best way to clean front screen to not scratch it? Thanks a lot
P.S. I cleaned very gently a stand with moist cotton cloth and unfortunately it left scratches on back part of it what means that plastic used is poor quality...
skwieradee is offline
Old 09-01-2010, 06:43 AM
Use dish washing soap and water to clean the surface of your tv. Do not use alcohol or any other aggressive cleaning product.
Old 09-01-2010, 10:08 PM
hecz's Avatar
anybody?
hecz is offline
Old 09-02-2010, 12:46 AM
A review of the Sony Bravia KDL-40HX703 and Sony Bravia KDL-46HX703:
http://www.digitalversus.com/sony-br...4_8540_16.html
http://www.digitalversus.com/sony-br...4_8547_16.html
Pluses:
-Excellent contrast with very deep blacks
-Very attractive Monolithic design
-Accurate colours: average deltaE is below 2
-Good quality audio
-Effective Motionflow 200 Hz system
Minuses:
-Narrow viewing angles
-Glossy screen susceptible to reflections and greasy fingerprints
-Mediocre multimedia player
-Average remote
