Official Samsung LNXXC630/C650 Owners Thread - Page 208 - AVS Forum | Home Theater Discussions And Reviews
post #6211 of 6239 Old 06-25-2013, 05:57 PM
esk1's Avatar
Originally Posted by Faluzure View Post
I can't find it at the moment, but I distinctly remember reading about this either on this thread/forum or some other forum (maybe CNet). I had the exact same problem as you and I don't know if there's any merit to it, but it seems to have fixed the problem (for me).
I was told to put any gaming console on the 1st input. You know how there's 3/4 different HDMI inputs? Supposedly the 1st one has "less lag" than the others. That in combination with Game mode supposedly fixes the problem.
Again, I can't find where I read it at the moment, but that fixed my lag issue. Maybe try that.
Game mode brought it down under 50ms, but PC mode got it to 0. These measurements were taken using guitar hero so its not entirely accurate. To put it into PC mode I had to rename the 1st input to PC and then when you go into the game mode option it is greyed out, but you lose a lot of the customization options. I'm going to buy a hdmi switch so I can put my 360 and ps3 on the same input and not have to deal with this again.
Blucliff likes this.
esk1 is offline
post #6212 of 6239 Old 07-28-2013, 01:07 PM
sbenson's Avatar
Hey all,
I just received my new Google Chromecast dongle and plugged it into the HDMI 4 slot on the side of the TV, but the video quality is terrible. In my three years owning this TV, I've never used the HDMI 4 slot, so I never noticed any issues.
I pulled the Chromecast out and plugged it into one of the back HDMI slots and everything looks amazing. Netflix, Youtube and everything else is crisp and in beautiful HD. Just being curious, I then plugged my DVD player into HDMI 4 (normally in HDMI 1) and it now looks terrible.
It seems as though something is wrong with HDMI 4. The picture looks terrible all around and I have the soap opera effect. However HDMI 1, 2, 3 look great. 1 has my DVD player, 2 has my Tivo and 3 has my Xbox.
Anyway, sorry for the overkill of info, I'm just trying to get to the bottom of this. I'm curious if I need to reset the tv and start from scratch re-calibrating everything.
Thanks in advance!
sbenson is offline
post #6213 of 6239 Old 08-08-2013, 10:29 AM
batu's Avatar
Have you tried to rename the input? (it changes some settings). Select PC for name of input for HDMI4. Also try 'Screen Fit' (picture size), it corrects over scanning shown when 16x9 is selected. Looking forward to Google restocking Chromecast.
batu is offline
post #6214 of 6239 Old 08-16-2013, 08:37 AM
MRXPT's Avatar
Good afternoon.
I come here to talk about the problem that is happening with my LE37 C650.
For some time now I have noticed that the TV emits a buzzing sound in dark scenes, or when the backlight is less than 20/20.
I know it is a very recurrent problem in this model, so if possible like to hear your opinion.
Is there any solution that you can try at home??
Thanks and greetings from Portugal.
PS: My firmware is the 3018.1 (http://www.samsung.com/pt/support/mo...WXXC-downloads)
MRXPT is offline
post #6215 of 6239 Old 08-25-2013, 04:56 PM
snicker110's Avatar
Does anyone know good settings for a Samsung LN46D630 for gaming? Game mode isn't doing it for me:/? Help anyone?
snicker110 is offline
post #6216 of 6239 Old 11-08-2013, 06:07 PM
JohnnyGalaga's Avatar
Hello,
I've had the LN40C630 for about 3 years now and just started having a new problem. After hitting the INFO button on the remote, I can see the guide information with the time and name of what's currently on. But hitting the right arrow button no longer shows what's on in the future hours. I used to be able to hit the right arrow after the INFO button and scroll through the upcoming show titles to see what's on next. This is on free over-the-air TV with an outdoor antenna.
Now, when I hit the right arrow, nothing happens. The info guide just keeps just showing the current show title and time. I know the right arrow button works cos I can navigate with it in the Menu. So what could be causing this? Have all the networks stopped broadcasting future show schedule info, or do I have a setting or something messed up on the TV?
JohnnyGalaga. Setting the standard in galactic excellence.
JohnnyGalaga is offline
post #6217 of 6239 Old 11-13-2013, 05:58 AM
Bruno Rua's Avatar
Hello,
I have the flickering problem in my LE40C630
anyone pls can tell me what jumper to cut in this model?
i attach a photo of the panel.
txs a lot for any possible help
best regards
Bruno
Bruno Rua is offline
post #6218 of 6239 Old 11-13-2013, 06:14 AM
TeeJay1952's Avatar
Quoted: 135 Post(s)
Liked: 133
http://www.avsforum.com/t/1340774/samsung-lcd-tv-flashing-blinking-like-a-strobe-light/90#post_23942822
Don't know if that is what you want. But it was what I noticed in another thread.
TeeJay1952 is offline
post #6219 of 6239 Old 11-13-2013, 06:22 AM
Bruno Rua's Avatar
txs a lot for fast response...
problem is my powersupply is diferent...
i had found a J852 jumper... maybe i try cut that... is broken anyway... getting desperate... Samsung asked me 450€ to fix
They told was panel... so i'm not sure problem is the same
post #6220 of 6239 Old 11-16-2013, 04:14 PM
Bruno Rua's Avatar
Hello,
cutting j852 didnt worked...
i tested with a friend, replacing all parts, that has a LE40C650 (mine is LE40C630) and i found out the problem is the T-CON part...
whith his T-CON part my TV works great.
i'm having problem trying to find what T-CONS i can buy (part number???)
any info on what the compatible T-CONS compatible and where to buy?
the only reference i have now is S120APM4C4LV0.4 and not sure if its correct
many txs for any help
post #6221 of 6239 Old 11-27-2013, 08:41 AM
ace5000's Avatar
Quoted: 44 Post(s)
My Brother's set also has the same vertical lines when powered on. They go away when wiggling the audio cable on the back as shown. It is out of warranty - and yes, I know it needs servicing... Model LN46C650 L1FXZA
Is there a DIY fix for these vertical lines yet? What part or board is it?
Many thanks in advance.
ace5000 is offline
post #6222 of 6239 Old 11-30-2013, 10:27 AM
ace5000's Avatar
Quoted: 44 Post(s)
Anyone?
Also, the model number is LN46C650 L1FXZA.
What is the correct p/n for the main board if I need one?
ace5000 is offline
post #6223 of 6239 Old 11-30-2013, 11:49 PM
fyparr's Avatar
^Looks just like my LN55C630K1F.  Most times they are there, sometimes they change to a blacked out column of pixels between every 3 columns, and very rarely, the picture is totally normal.  Would love to hear the experts' opinions on this.
T-con board? Main board? Panel? Something else?
fyparr is offline
post #6224 of 6239 Old 12-01-2013, 01:18 PM
fyparr's Avatar
ace5000,
I discovered this thread, demonstrating a fix for our symptoms:
http://www.avsforum.com/t/1492931/samsung-ln55c650-colored-vertical-lines-issues-resolved-loose-connector-save-yourself-1237
I noticed when I tap the input area the symptoms change and/or disappear.  So I followed the directions with my ln55c630 and it appears to have resolved the issue with my set.  Best of luck!
fyparr is offline
post #6225 of 6239 Old 12-11-2013, 09:10 PM
stubblejumper9's Avatar
This tv - LN46C650 - is driving me insane. Hoping somebody has had this problem. I've had it for 2.5 years.. no warranty at this point. It's been a great tv until now. A few days ago, like a light switch the picture went all RED.. and I mean ALL RED. Occasionally I get some horizontal lines, but not often and it's only for a few seconds. The picture has also gone very very dark. No setting change seems to fix this. I reset back to factory and played with everything I can see, but nothing seems to help. I noticed the last couple of days after abut 30mins of being turned on, the RED dissipates a little bit and it's somewhat watchable ...well certain programs anyway. Hockey..not so much. The ice is very polarized. Both sides of the tv I can also see the flaring of light, not "bad" but in dark scenes..it's pretty noticeable. It wasn't like this before. Even playing with the settings, it seems to magically change on it's own after a period of time. But the red is very saturated. DVD player, Xbox all the same.
Any ideas are appreciated before i take an axe to it! This is my 3rd Samsung Tv in the last 8 years....and it will be my last.
Thank you
stubblejumper9 is offline
post #6226 of 6239 Old 12-29-2013, 12:33 PM
dolph44's Avatar
I have the 46" 630 series. I loved the picture so much when I saw it I bought it. Just two years into it my screen went pink. Took it to the repair shop, the guy says that's a common problem with Samsung TV's. He says I have 50 Samsung input boards, I will have your board. Oh wait a minute , that tv is new and is not suppose to have that problem...It has been at the repair shop for a month now. He also says that if it was under warranty Samsung calls him every day to make sure he got the part (whici they ship express) and the repair is being made promptly. He says you will be waiting a long time for this repair because you are out of warranty. They will send the part ground and no follow up will be made. 6-8 weeks he figures. Depressing indeed.
dolph44 is offline
post #6227 of 6239 Old 01-01-2014, 08:53 AM
I took it into the repair shop just before Christmas.  Waiting for an estimate.  I'm out of warranty so if it's more than $200 to fix, it's going to meet my sledge hammer.  I think I'll send all the bitty pieces back to samsung.
post #6228 of 6239 Old 01-01-2014, 12:02 PM
dolph44's Avatar
update,
Got tired of waiting for repair so I picked up the TV and figured I would at least watch it with the cable directly into the TV which worked fine. I decided to try the HDMI input, The TV worked fine, but the HDMI quality is crappy on Samsung TV's. So I tried 1 more time to use the rogers cables which do have a better picture. TV worked fine, so I proceeded to take the HDMI cable off, and to my surprise the TV didn't work again. So I tried the HDMI and the rogers cables and it works fine. So this worked for me. To clarify use both the HDMI and the Rogers cables and you may be fine. I did notice however that the inputs didn't seem correct but i don't care as long as I have my picture back.  Last Samsung anything!!!
dolph44 is offline
post #6229 of 6239 Old 01-07-2014, 07:08 PM
Just to close this off, I just heard back from the repair shop.  They tell me it's the LCD panel and would cost more to repair than a new tv.  I hate you Samsung.  Pretty pathetic when the batteries in the remote last longer than the tv.  Samsung <> Quality.
post #6230 of 6239 Old 01-23-2014, 10:49 AM
Max Headroom's Avatar
Hi,
I have a LE40C650 and I'd like to know if there's a way to listen, at the same time, both at the speakers and at pair of Sennheiser headphones I also have. Whenever I connect the headphones, the speakers are automatically muted.
Edit: As I found earlier, using an adaptor to connect the headphones to SCART 1, does output audio from the speakers and headphones. Unfortunately it's not much help to me, because it only works with broadcasts, while I mostly use the integrated media player (via USB)...
Carpe Diem
Max Headroom is offline
post #6231 of 6239 Old 04-10-2014, 05:22 AM
M. Brown's Avatar
I'm sorry to hear the problems you guys are having. I've had mine for over two years now and haven't had any issues. That being said, I probably just jinxed myself by saying that. I have a LN46C630 BTW.
M. Brown is offline
post #6232 of 6239 Old 04-27-2014, 11:42 AM
chicu1981's Avatar
Hi
I have Ln46C650. I have set the region to US. Is there any way i can get Amazon Instant Video app on this panel?
chicu1981 is offline
post #6233 of 6239 Old 05-10-2014, 09:24 PM
nateseattle's Avatar
    I have a Samsung LN46C650 with both problems. Strobe/fast flickering and rainbow lines, intermittent for both at different times.
Just tried the JP852 clipping and so far so good to stop the strobe/flickering effect.
I'll definitely update if any problems occur!
    For the rainbow horizontal lines, this is where I've isolated it to:
try gently wiggling the square shaped "audio out" port located directly above the square "digital audio out" port. This should cause the rainbows to come in and out. It seems to add pressure on the video card - I also lightly wedged a small thin piece of plastic (cut off the tips of a disposable fork for mine) to brace the port against the metal tv frame on the back.
nateseattle is offline
post #6234 of 6239 Old 05-19-2015, 09:18 AM
Psyclox's Avatar
Anyone have their tv just shut off and never able to turn on again? First the picture went out but I could hear it, then about 5 seconds later the sound went out and all power was gone. nothing turns it back on. I was thinking it was the power board needs to be replaced? Id hate to spend that money and that not be it, but I cant think of anything else. It doesn't light up when plugged in. Seems that no power is getting through. Any help is appreciated although I see that the last post here was a year ago so just hoping for advice.
Psyclox is offline
post #6235 of 6239 Old 05-30-2015, 06:24 PM
Is there any way to manually add a channel to your channel list for over-the-air channels after you've done a scan? It seems like the only way to add channels is to do a scan. But that's a problem if you're using an outdoor TV antenna with a rotor.
post #6236 of 6239 Old 06-05-2015, 07:22 PM
lionelhuts's Avatar
Quoted: 17 Post(s)
I think I remember reading about someone else with a similar issue and the problem was a blown capacitor on the logic board. Of course, this TV is so old now, it's entirely possible I'm conflating this issue with a different model.
lionelhuts is offline
post #6237 of 6239 Old 02-18-2016, 06:46 PM
Ravenzero's Avatar
Liked: 0
Originally Posted by pufft View Post
Does anyone know how to fix the following problem with my LN46C630? Image of a portion of the screen below.
When I first turn on the tv, there are evenly spaced thin black bars across the whole screen. Once the tv has been on for a few minutes, the lines either go away by themselves or with a little bit of jiggling of the hdmi cable. Very rarely, but only when the vertical lines are present, the screen will also flash with either pink or white tint. You can still see the video image, it is just overlayed with a pinkish or white cast. Love the tv, but I'm disappointed that it hasn't even lasted 2.5 years.
I have this same problem on mine, Ended up buying a new Sony TV. Never going samsung again.
Did you ever fix yours?
Ravenzero is offline
post #6238 of 6239 Old 03-22-2016, 04:42 PM
Liked: 0
Hi, my LN46C630 is currently facing the issue in the link below.
www youtube com/watch?v=qn1StUKlhkI
Does anyone know what this issue is called, or know how to fix it?
I've already tried cutting the jumper cable jp852, but it didn't do anything.
jimmyreese is offline
post #6239 of 6239 Old 09-05-2016, 09:51 AM
wild bill2's Avatar
Liked: 0
intermittent image problem
We have two Samsung LN55C630 that are experiencing intermittent image problems. The image has fine black horizontal and vertical lines, like looking thru a window screen, and the colors blur and washout. This happens predominately on set 1, but I have also seen it twice on set 2, but not both at the same time. Our source is Dish using HDMI. I have tried switching cables and different HDMI ports and also using composite cables. If I remove the HDMI cable and reinsert it, the screen clears. Both sets are well past the warranty. I have been searching the web and have not found anything similar.
Is there a name for this condition?
What would be the best way to isolate the problem since it is intermittent? We are going to take the receiver for set 1 on vacation with us, so I will be able to confirm if that is the source of the problem.
wild bill2 is offline
Reply LCD Flat Panel Displays
