Official Samsung LNxxC530, LNxxC550 Owners Thread - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 246 Old 07-19-2010, 09:06 PM
TheKrayze's Avatar
I wanted to chime in on the issues. I just got a LN40C530. My panel is a CN03. Manuf: May 2010. Fair enough, this is only the second day i have owned the tv. my thoughts so far are great.
i turned off the eco setting and dynamic contrast for my bluray player. Now. i have tried an xbox 360 directly connected via HDMI and i have noticed NO motion blur, no ghosting, no issues. I have not heard any buzzing at all. I think the quality is outstanding. I have adjusted all the picture settings. it is set to standard, but i have adjusted the color, contact, brightness, etc...
i got a great deal at my local BB. open box unit that was on display. (on display for 1 day) it was $599. was going to get the sony 40EX400, but saw them both and thought this was a better quality picture. I will not comment on audio for this tv because anything i listen to for the bluray or xbox, will be played though my AVR. i agree with an earlier post where one setting is not going to cut it for audio. you will be friends with that audio adjustmen button.
I was happy for the PIP, but not a requirement. in all, i like the TV. time will tell, but i have a good feeling.
TheKrayze is offline
post #92 of 246 Old 07-19-2010, 09:24 PM
alysenne's Avatar
Is there a real difference in quality between the 5xx and 6xx models? Do the 6xx models get higher quality panels or does the panel lottery affect all models?
I want a 46" and the price difference between the 530 and 630 is more than $100. I don't need the DLNA since I'll be using a great HTPC with it. I'm not too sure about the difference between the 60hz and 120hz refresh.
alysenne is offline
post #93 of 246 Old 07-21-2010, 07:45 PM
Nifta's Avatar
So, I own an LN32C540, purchased from Futureshop in Canada. I'm liking it so far. A003 panel. Can't find any threads anywhere from other owners of a C540. Feature spec seems to place it somewhere between the C530 and C550. Has anyone heard of it? As it seems to be a Canadian Futureshop exclusive, and probably won't be widely supported, I was wondering if anyone knew of its closest brother, so I can keep an eye out for firmware updates / general discussion etc.
Nifta is offline
post #94 of 246 Old 07-22-2010, 08:48 PM
ragtop69gs's Avatar
The LN32C540 is not just canadian, I picked one up at CostCo in the US for $387 open box, today. So far i'm happy with the picture and sound. Now if I could only find some base calibration settings for it.
ragtop69gs is online now
post #95 of 246 Old 07-24-2010, 08:16 PM
Sesquipedalism's Avatar
I got an LN40C530 with an SQ06 panel about a month ago. The factory settings on this set are quite poor, but my panel has decent viewing angles and blacks.
Here are my settings, after two weeks of tinkering with several blu-rays and calibration disks, as well as Xbox 360 games (to check shadow detail and input lag). I also compared my results visually with Best Buy's calibration demo. They seem to be fairly close.
Mode: Movie
Backlight: 7
Contrast: 85
Brightness: 61
Sharpness: 0
Color: 52
Tint: 47/53
Eco Solution: Off
Advanced Settings
Black Tone: Off
Dynamics Contrast: Off
Shadow Detail: 0
Gamma: 0
RGB Mode: Off
Color Space: Auto
Flesh Tine: 0
Edge Enhancement: Off
White Balance
R-Off: 28
G-Off: 24
B-Off: 14
R-Gain: 28
G-Gain: 25
B-Gain: 15
Picture options
Color tone: Normal
Filters: Off
HDMI black level: Low
The main flaw I can find with these settings are that my black level isn't as deep as it could be. Shadow detail and color seem excellent, however.
Let me know what you guys think.
Sesquipedalism is offline
post #96 of 246 Old 07-25-2010, 11:43 AM
cjsiv's Avatar
Liked: 33
I purchased a LN32C550 from amazon a few weeks ago. Really didn't need the new tv, but the deal was too good to pass up. I got the tv and a new tivo premiere for $539. Mine has the AA panel. Looks great. The usb media player works great (since I only use mp4 and .avi files now this is great!). No buzzing. OTA hd looks great. I couldn't have asked for a better tv for the bedroom. And I got a new tivo for the living room for free.
cjsiv is offline
post #97 of 246 Old 07-27-2010, 05:18 AM
starbucks2010's Avatar
has anyone found any "official" settings (65k) from a testing forum for the 40C530?
thank you
starbucks2010 is offline
post #98 of 246 Old 07-28-2010, 04:31 PM
beksil's Avatar
I've a strange interaction between my PVR and my TV. When connected by HDMI, they someone interact.
1. I cannot turn off the PVR is the TV is off and even sometimes when it is on.
2. The PVR frequently goes into boot, usually about 2-3 min later, when I turn off the TV. Sometimes, the PVR just goes to boot for no apparent reason
3. The PVR clock seconds dots don't blink although the clock keeps time.
It is not the cable or the particular HDMI TV input. It does not happen with a composite connections. It is not the PVR, I've swapped it out twice for new ones.
Any ideas?
beksil is offline
post #99 of 246 Old 08-09-2010, 11:31 AM
longhorns's Avatar
Anyone wanna throw up some screenshots? I just got the 32c530, noticing some lag on MW2, but not on any other games which is somewhat odd. Been playing some .MKV files through my laptop connected to the tv w/ VGA cuz I had some issues with the USB input only able to play certain .MKV files, anyone know what's up with that? Also, used a mix of y'alls calibrations and it helped immensely with the ghosting/lag. Kind of curious as to how y'alls sets are looking compared to mine though so throw up some screens!
Absence of Evidence is not always Evidence of Absence
live together, die alone
Gamertag: Bigbev02-Tell me if you're from AVS.
Achievement Unlocked: You've found the red couch!
longhorns is offline
post #100 of 246 Old 08-10-2010, 02:55 PM
TheKrayze's Avatar
just wanted to give an update on my ln40c530.
almost a month and No problems. again, no motion lag, not wierd noises, etc...
I will go out on a limb and say i love this tv. I did get the extended warrenty from BB for 4 years. so no matter what, this will be covered. I dont usually get warrantys, but i felt this one time wont hurt.
I am going to use the AVCHD 709 disc tonight to calibrate it better. i have a habit of using a movie for calibrations. i used Transfomers 2. i have a feeling i will be twwking the bightness a bit.
i will post my setting when i can. it may just help some of you out there.
post #101 of 246 Old 08-13-2010, 12:51 PM
JMD1014's Avatar
TheKrayze, any news on the results you got when you used the AVCHD 709 disc? The settings I'm using now for my LN40C550 are pretty good but a little tweaking probably wouldn't hurt.
JMD1014 is offline
post #102 of 246 Old 08-16-2010, 07:37 PM
jerider00's Avatar
I just bought the 32" 530 and have had a few problems getting the picture settings just right. I have used DVE DVD to initially set it up but I think it is still off. Does anyone know what the picture settings should be? Especially for watching sports.
jerider00 is offline
post #103 of 246 Old 08-18-2010, 09:10 AM
gerryman's Avatar
Just purchased an LN32C550 on Amazon and it should be coming in tomorrow. I plan on trying to use it on my network to stream videos using the wired ethernet jack but does anyone know if the wireless Link Stick (WIS09ABGN)will work for network connectivity? I'd rather have wireless then wired because of my setup. Thanks in advance for your help.
gerryman is offline
post #104 of 246 Old 08-20-2010, 03:12 AM
hawkijustin's Avatar
I just bought the 46c530 and looking to see if anyone else had settings for us to try? I tried some of them on here and have yet to find one that looks good. Also my panel is AA01 i think.
hawkijustin is offline
post #105 of 246 Old 08-23-2010, 04:56 PM
roflc0pter's Avatar
Just bought a 32C550 to use as my PC Monitor. Got an AA01 panel. Having a hard time calibrating the settings. Any recommendations? Thanks
roflc0pter is offline
post #106 of 246 Old 08-24-2010, 01:23 PM
szymon247's Avatar
Hello.
Can anyone please do some input lag testing?
Because supposedly the C530 have only 14ms of lag in game mode according to this test:
http://www.hdtvtest.co.uk/news/samsu...0100813815.htm
Considering that this year's Samsungs aren't particularly known for low lag this sounds very good but kind of unlikely. Can anyone perform a test, please?
I'd be especially grateful for tests of a bigger set.
szymon247 is offline
post #107 of 246 Old 08-25-2010, 10:28 AM
caa100's Avatar
Originally Posted by szymon247 View Post
Hello.
I guess that's a UK model in that article. As near as I can tell, the US models do not have a Game mode. (Lame or otherwise)
I don't have a C530, but I do have a C550. I can give you the unscientific lag assessment of my teenage sons:
They say lack of game mode on the C550 does not to make a difference, when compared to our A750 with Game Mode turned on.
I guess the A750 normally does so much processing compared to the 550, that a game mode is needed.
If you are concerned about lag and already own the set, take it out of dynamic mode and turn off edge enhancement, noise reduction, dynamic contrast, etc. Any processing you can eliminate should help.
-Chris
caa100 is offline
post #108 of 246 Old 08-26-2010, 10:41 PM
Go into settings: setup: general, then you should see game mode.
post #109 of 246 Old 09-02-2010, 11:27 PM
jvl51294's Avatar
Can anyone confirm this? I'm really interested in hearing of what the input lag is!
jvl51294 is offline
post #110 of 246 Old 09-03-2010, 08:22 AM
caa100's Avatar
Hawkijustin is right, there is a game mode in the General menu.
Can't give you a test result because my laptop does not have HDMI out. (If it is like other Samsung sets, VGA connection has almost no processing and won't represent what you get with component or HDMI.)
My guess is VGA will be best, HDMI1 in "DVI PC" mode will be second best, and any other input on game mode will come in 3rd. These are just guesses based on other Samsung TV's -- hit the links above.
-Chris
caa100 is offline
post #111 of 246 Old 09-03-2010, 11:25 AM
caa100's Avatar
Noticed new firmware posted at Samsung US.
http://www.samsung.com/us/consumer/t...il&tab=support
Anyone try it?
Here are the release notes:
All OS
1014.1 / 2004.1
Upgrade File(USB type)
Sep 01, 2010
90.33
ENGLISH
T-TDT5AUSC_and_T-MSX5AUSC.exe
1. Title
Firmware version
- T-TDT5AUSC: 1014.1
- T-MSX5AUSC: 2004.1
2. Applicable Model
LCD TV
C450, C530, C540, C540, C550 Series
3. Carrier or Corporate Customer
All Customers
4. Description
This firmware prevents below problems
- Picture Noise on specific channels
- Stream made by BBY is distored while playing.
- Pre-channel exists for a while when changing channel from Cable 32-2(528x480) to 32-3(528x480).
-Chris
caa100 is offline
post #112 of 246 Old 09-03-2010, 03:46 PM
rdangel's Avatar
Hi Guys, I have a new 46" LN46C650 that we want to find a low profile mount for. I have an idea of the things I need for the TV but wanted a sanity check from the experts in this forum. Thanks in advance!
Is this mount ok?
Also I am going to be putting the cable box and bluray in a kitchen cabinet and am in need of an IR kit to send the signal to the boxes in the other room. What do you guys recommend?
Is this ok?
http://www.amazon.com/IR-Repeater-Sy.../dp/B0016PM63W
Lastly, What is the HDMI cables you use to run from the TV to the boxes? Monoprice has so many options. I guess I want the best cable as I will probably need to run 25-50' of cable.
Is this the right cable to get?
rdangel is offline
post #113 of 246 Old 09-04-2010, 08:36 AM
caa100's Avatar
Congrats on your TV.
This is the Series 5 (C550/540/530) thread. Thread for the Series 6 (C650) is over here: http://www.avsforum.com/avs-vb/showthread.php?t=1234637
Lots of talk about IR extenders in the remote control area, here: http://www.avsforum.com/avs-vb/forumdisplay.php?f=93
-Chris
caa100 is offline
post #114 of 246 Old 09-04-2010, 03:18 PM
kjlcm's Avatar
I recently purchased a LN40C530 and am having issues with the picture or parts of the picture temporarily freezing (under 1 sec.). We are running 1080 through HDMI from our cable box. I search around the forum a bit but did not find anyone discussing this particular issue. Any ideas? Our old TV was 720 running component and we never saw this issue. Any chance we do not have enough signal coming into the box? We get it both for live stuff and for DVR. TV will have to go back if I cannot figure out. Thanks for any suggestions!
kjlcm is offline
post #115 of 246 Old 09-05-2010, 10:18 AM
caa100's Avatar
Even though you did not have this problem with your old TV, it sounds like an issue with cable reception to me. Is it the same cable box as before? What is the operator/model?
-Chris
caa100 is offline
post #116 of 246 Old 09-08-2010, 04:40 AM
Ins
Ins's Avatar
Hi
Could someone tell me where exactly is panel sticker (LE32C530 or LE40C530)? Is it on the back of TV ? I called to the store and they could not find any information about panel type on the sticker located on the back of TV. Im going to buy probably LE40C530, but i need to be sure what panel is in the model I'm buying.
PS. Sorry for my english ;P
Ins is offline
post #117 of 246 Old 09-09-2010, 11:05 AM
New Account's Avatar
Hello, new member here.
Is LNxxC530 the same as LExxC530? I'm kinda stuck in the nomenclature of flatpanels.
New Account is offline
post #118 of 246 Old 09-09-2010, 02:06 PM
TheDaemon's Avatar
Hi there, me too :P
Essentially same TV.
The difference between the LN and LE in the model code is:
E - Europe
N - North America, Korea, South America
TheDaemon is offline
post #119 of 246 Old 09-09-2010, 03:11 PM
Cool, thanks for the reply. I expect to recieve my LE32C530 tomorrow, will post my experiences with it here. Since it's the first time I'm buying a non-CRT, it will probably be a newbie review
post #120 of 246 Old 09-09-2010, 03:21 PM
TheDaemon's Avatar
Good luck with it, I bought the LE46C530 earlier today myself
Reply LCD Flat Panel Displays
