Need HELP: looking for the best gaming tv - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 05-04-2010, 02:24 AM - Thread Starter
PussyVampire's Avatar
hello everyone
I'm looking for a good gaming tv , to me this means no or very little jaggy edges on games. Lag is a minor issue anything under 1 is fine and I need at least a 46 inch. Money limit it $1800 before tax. I'm using a xbox 360. And I need to buy the tv from best buy.
Now I have tried a samsung 6000 series led it had major major flashlight/clouding issues
also tried the Sony led 700, same issues as samsung
I tried the Sony hx701 and even it has some clouding/flashlight issues but the HDTV cable picture is amazing, however the gaming picture is bad
jaggy edges and the corners are a dark blue or black depending on the game
If anyone can offer me any suggestions that would be great.
Thanks everyone
Jukebox360 does NOT own a g20/25. Please disregard all his settings/comments on the g20.
PussyVampire is offline
post #2 of 10 Old 05-04-2010, 02:51 AM
XciteMe83's Avatar
Quoted: 93 Post(s)
Best. User name. Ever.
XciteMe83 is offline
post #3 of 10 Old 05-04-2010, 10:36 AM - Thread Starter
thanks LOL. It was my poker name.
Anyway I might also add I like semi matte or glossy screens only.
post #4 of 10 Old 05-04-2010, 03:29 PM - Thread Starter
I might try the sharp quatro 46
post #5 of 10 Old 05-04-2010, 04:51 PM
chaz01's Avatar
Originally Posted by PussyVampire View Post
... Lag is a minor issue anything under 1 is fine..
I'm no expert, but if it needs to be under one, it's more than a minor issue.
Have you read through the lag thread?
chaz01 is offline
post #6 of 10 Old 05-04-2010, 05:17 PM - Thread Starter
Well the quatro is said to be .30 so that's .70 under 1
maybe I am saying it wrong
post #7 of 10 Old 05-04-2010, 05:42 PM
chaz01's Avatar
No, I am. I was thinking in terms of milliseconds.
chaz01 is offline
post #8 of 10 Old 10-13-2010, 05:09 AM
charlesdavidoff's Avatar
Hi all.
So what are you talking about exactly?
@PussyVampire: do you mean, everything below 100ms of input lag is no problem for you? Or what unit of measurement do you mean when talking about "under 1"
100ms of input lag is really laggy and not really playable!
charlesdavidoff is offline
post #9 of 10 Old 10-13-2010, 05:44 AM
Guibs's Avatar
hello everyone
Thanks everyone
You need to help us define the "under 1" for imput lag. Is it 1 frame or 1 ms? In both cases, these numbers are far, far from being minor. 1 frame lost is about 15-16ms and in modern TV, espicially at 46", it's almost impossible to find. The closest thing would either be a panasonic plasma (if you don't mind image retention) or a Sharp TV. Both are about 2 frames lag (30ms) which is still considered great.
After this there are a few tv that falls withing the 30ms to 50ms range, I believe the Sony HX701 falls into that category. I am personaly considering buying back the HX701. I return mine due to clouding but I might take my changes and go buy it back again.
Guibs is offline
post #10 of 10 Old 10-13-2010, 06:16 AM
Needanewbewbtube's Avatar
I didn't notice any lag on the 52810UN, but I did notice clouding and motion blur. I'm interested to see how the 925 does, but haven't really seen anything on it yet. For 100% gaming I'm seriously considering DLP. Why can't they just make plasmas that are immune to IR
Needanewbewbtube is offline
Reply LCD Flat Panel Displays
