Proper way to strip/terminate RG6? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 05-06-2010, 05:32 AM - Thread Starter
sofakng's Avatar
Quoted: 30 Post(s)
I never seem to be able to strip and terminate RG6 properly. (eg. my connectors are very loose, fall off, etc)
I'm not sure if it's my tools but here's what I'm using:
IDEAL Coaxial Stripper, 3-Step
and
IDEAL Economy Compression Tool
I've read two methods for stripping the cable:
1) Remove outer jacket, outer braid, and outer foil. Fold inner braid down around jacket and leave inner foil in contact with dielectric.
2) Remove outer jacket, leave outer braid, and remove outer foil. Folder both outer and inner braid down around jacket and leave inner foil in contact with dielectric.
Which is correct? I've also heard of removing the inner foil and/or folding it against the jacket along with the braid.
Also, is my compression tool compatible with both RG-6 and RG-6 Quad?
Thanks so much...
sofakng is offline
post #2 of 11 Old 05-06-2010, 07:36 AM
abierce's Avatar
I have the same stripper tool and it works flawlessly, I don't want to insult you but are using it correctly? Mine does have an image of which way to place the coax into the tool before you spin it to cut and trim. My compression tool is a little different model but I found that you really need to make sure you apply some pressure to hold the cable from backing out when the compression is actually being done.
abierce is offline
post #3 of 11 Old 05-06-2010, 08:28 AM
topr's Avatar
You can strip it down to the dielectric and it still should work fine as long as the connector is shoved on there good. As far as being loose... double check that you are not stripping RG59
topr is offline
post #4 of 11 Old 05-06-2010, 08:30 AM - Thread Starter
sofakng's Avatar
Quoted: 30 Post(s)
@abierce: No offense taken at all. I am probably using it wrong which is why I'm posting here
@topr: I'm sure it's RG-6 but I don't know if it's quad shielded or not so maybe that's my problem.
I'm just not sure which braiding/foil to leave on and if it needs to be folded back before inserting it into the connector, etc.
sofakng is offline
post #5 of 11 Old 05-06-2010, 08:47 AM
topr's Avatar
All the foil and braid are electrically the same. Are you doing F-connectors because sometimes they can be a bugger to push on there far enough. If the white dielectric isn't almost butted up to the opening at the other end you probably don't have it pushed on far enough.
topr is offline
post #6 of 11 Old 05-06-2010, 10:24 AM - Thread Starter
sofakng's Avatar
Quoted: 30 Post(s)
Yeah, that's what I read... (eg. the braid and foil are electrically "common" but they work together to block out most interference, etc)
Should the dielectric be pushed through the hole a tiny bit before I compress it, flush with the opening, or slightly outside of it? (the compression will move the cable, I think...)
sofakng is offline
post #7 of 11 Old 05-06-2010, 10:54 AM
ES_Revenge's Avatar
Quoted: 411 Post(s)
Liked: 133
Isn't this better asked in the installer/installation forum?
ES_Revenge is offline
post #8 of 11 Old 05-06-2010, 01:36 PM
Polydorus's Avatar
I always push it through.
Polydorus is offline
post #9 of 11 Old 05-06-2010, 02:40 PM
abierce's Avatar
that little stripper tool should have a couple of blades in that will will leave everything correct for you after its used, I am away from home at present but if you can wait until the weekend I can probably make you a little video that will show you
abierce is offline
post #10 of 11 Old 05-06-2010, 04:14 PM
topr's Avatar
If you go to youtube and type in F connector their are quite few.
topr is offline
post #11 of 11 Old 05-06-2010, 05:19 PM
Speedskater's Avatar
Quoted: 20 Post(s)
One big problem with all IDEAL tools is that the instructions suck!
Kevin
Speedskater is offline
Reply LCD Flat Panel Displays
