lg lh90 vs sony ex500 vs samsung c630 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 05-06-2010, 09:33 PM - Thread Starter
bballgms's Avatar
these tv's all fall in about the same price range.
and wanted to start a thread bc i know it would be usefull to many people and me
just want the opinions? color quality? postive reviews? negative asspects? high definition quality? standard definition quality? reliability?
anything really. it would really help if people could post their opinions especially if they have two of those tv's or more. if seen side by side.
thank you in advance. hopefully this will help a lot of people
bballgms is offline
post #2 of 12 Old 05-06-2010, 11:08 PM
satam55's Avatar
Quoted: 24 Post(s)
The LG LH90 Series is easily the Best HDTV that you listed.
The LG LH90 Series is LG's Top Flagship High End Model Series of 2009 and is a Back-Lit LED-LCD HDTV with local dimming.
While the Sony EX500 series and the Samsung C630 series are mid-range Regular LCD HDTV 2010 models.
The isn't even a good or fair comparison. The LG LH90 Series is easily the Best.
You have to compare the LG LH90 Series with the Sony Bravia XBR9 Series and the Samsung B8500 Series to make a fair comparison. Those are Sony's and Samsung's Top Flagship High End Model Series of 2009 and are also Back-Lit LED-LCD HDTVs with local dimming.
satam55 is offline
post #3 of 12 Old 05-06-2010, 11:28 PM - Thread Starter
bballgms's Avatar
how about the ex500 vs the c630?
bballgms is offline
post #4 of 12 Old 05-06-2010, 11:31 PM - Thread Starter
bballgms's Avatar
also how does the lg ld550 fall in this catagory?
bballgms is offline
post #5 of 12 Old 05-06-2010, 11:43 PM
satam55's Avatar
Quoted: 24 Post(s)
What does it matter? If I were you I would just go ahead order the LH90. It's a higher end HDTV than the other 3 you listed.
The LG LD550 is also a mid-range Regular LCD HDTV 2010 Model
But, If you wanna see how a model series compares within a manufacturer, view the links below:
LG: http://www.lcdtvbuyingguide.com/lg-lcd-tv/lg-lcd.html
Samsung: http://www.lcdtvbuyingguide.com/sams...msung-lcd.html
Sony: http://www.lcdtvbuyingguide.com/sony.../sony-lcd.html
satam55 is offline
post #6 of 12 Old 05-07-2010, 12:03 AM - Thread Starter
bballgms's Avatar
bc of the price i am looking to spend around 800. the lh90 is a bit out of my budget.
bballgms is offline
post #7 of 12 Old 05-07-2010, 12:16 AM
satam55's Avatar
Quoted: 24 Post(s)
If you can stretch your dollar a little bit, go to adorama.com. the have the 42LH90 on sale right now for under $900.
satam55 is offline
post #8 of 12 Old 05-07-2010, 05:56 AM
dsskid's Avatar
Quoted: 268 Post(s)
Liked: 257
Would a floor model LH90 47" for $800 be considered a good deal?
ISF Calibrator
Samsung PN64F8500
Pioneer Kuro Elite Pro-111FD
Pioneer Kuro BDP-320
Displays are like 100% cotton t-shirts. Always buy a size larger than you think you'll need, as they tend to shrink over time.
dsskid is offline
post #9 of 12 Old 05-07-2010, 05:59 AM
dsskid's Avatar
Quoted: 268 Post(s)
Liked: 257
Just a correction, the XBR9 is not a backlit LED, the XBR8 (2008 model) is.
ISF Calibrator
Samsung PN64F8500
dsskid is offline
post #10 of 12 Old 05-07-2010, 06:16 AM
BoilerJim's Avatar
Quoted: 55 Post(s)
Liked: 118
No, this thread will not help a lot of people and I'm just as sure that it won't help you. You started your first thread asking the same questions and you chose to ignore the advice that a lot of knowledgeable people took the time and effort to give you. Now you start another thread making your first one a slap in the face to those of us who tried to give you good advice.
Then, you list three TVs on this thread and when someone tells you which one is the best, you have the audacity to say the LH90 is "a bit out of my budget." Then why in the he!! did you make it one of your three choices to begin with?
What part of "it's time to quit bugging us and make up your own mind" do you not understand?
It's time to do your own research and then s&*t or get off the pot.
BoilerJim is offline
post #11 of 12 Old 05-07-2010, 03:04 PM
satam55's Avatar
Quoted: 24 Post(s)
I'd jump on that deal, If I had the money and space.
satam55 is offline
post #12 of 12 Old 05-08-2010, 09:11 AM - Thread Starter
bballgms's Avatar
sorry for miss clarification, the lh90 in stores is out of my budget online its 900, which is the same price as the ld550 and the c630 and the ex500. i am iffy on buying it online. i will go to a store soon. take my own dvd that i am familur with and see which one i like more.
so far i am definatly leaning towards the lh90, but if that doesnt work out it seems as the c630 would be the next in line.
bballgms is offline
Reply LCD Flat Panel Displays
