Official LG 47LX9500 and 55LX9500 Thread - Page 90 - AVS Forum | Home Theater Discussions And Reviews
post #2671 of 2682 Old 09-16-2012, 01:30 PM
almalino's Avatar
1 year of usage. I have problem with some leds not working anymore, Check the picture - dark rectangle in the upper right corner. Applied fo a warranty. Let see how fast LG will fix it.
almalino is offline
post #2672 of 2682 Old 11-17-2012, 09:17 AM
EzRush's Avatar
All of sudden this morning I turn the TV on and there is a distinct split in the image, It's like the backlight is only working on one side. Now of course I have to wait until Monday to call it in.
EzRush is offline
post #2673 of 2682 Old 11-18-2012, 04:37 PM
YOPORTS's Avatar
Keep us posted
YOPORTS is offline
post #2674 of 2682 Old 11-18-2012, 09:06 PM
almalino's Avatar
Mine problem was solved. LG replaced the whole TV panel. In practice it means I got a new TV because TV panel is so tightly integrated that the only part that remained from my old TV is a metallic back cover smile.gif
Works well for now, hopefully new panel will survive longer then original one - 12 months smile.gif
almalino is offline
post #2675 of 2682 Old 10-06-2013, 07:12 PM
Morning5's Avatar
Quoted: 327 Post(s)
Liked: 108
Hi,
I have a LG LX9500 tv and need to disable Scanning Backlight because I cannot sit very far from the tv and the flicker's getting very annoying. The big problem is that the setting to disable it is located in the Service Menu.
So my question is which remote control would allow me to enter this menu.
Thanks a lot.
Morning5 is offline
post #2676 of 2682 Old 10-10-2013, 06:23 PM
EzRush's Avatar
If you have a harmony remote you could easily do this. If you search online for harmony lg service code you could put a command in the remote which will allow you to push a button instead of commands.
EzRush is offline
post #2677 of 2682 Old 10-26-2013, 11:10 AM
dp3dp's Avatar
Ok I cant figure this one out. Woke up this morning and the qife telling me the tv is not working. Come dowbstairs and its a white screen with a moving box across the top that says " power only v4.12.6". I was able to get the input to hdmi as it was on tv, and can get a poxture but this box remains and I cant figure out how to remove it. The tv is not in demo mode any help on how to remove this box would be appreciated.
dp3dp is offline
post #2678 of 2682 Old 11-11-2013, 04:19 PM
PRS4k's Avatar
PROBLEM AFTER 2 YEARS
Came back from a two week vacation and my LX9500 won't receive HDMI from my Denon AVR-1912. Very simple setup -- sources connected via HDMI to DENON, one HDMI out to LX9500
Checked Cables
Restored to Factory Defaults (Denon and LG)
Turned off and unplugged units for 24 hours
Nothing works, still get "NO PICTURE" but Audio on Denon
However -
Plugged sources directly to LG - WORKS
Plugged another smaller 22" panel to Denon HDMI out - WORKS
This has been a very static system for two years, I don't mess with stuff, and has worked fine.
Why would the LG and DENON stop 'HDMI SYNCHING" to each other as the the sources still connect directly, and I have proved the DENON HDMI OUT works fine because another TV plugged right in.
Thanks for the support.
PRS4k is offline
post #2679 of 2682 Old 11-12-2013, 12:50 AM
almalino's Avatar
I cannot really help you BUT I had kind of similar problem. I connect computer directly to LX9500 and there was a time when I connect it and it doesn't detect HDMI signal . I try all other HDMI inputs and nothing. I connected another computer and it works fine. Then I try again computer that didn't work initially and suddenly it works again and HDMI signal is detected.
So I recommend to tryt to connect , disconnect different devices till it start working with device you want. Not sure what causes that.
almalino is offline
post #2680 of 2682 Old 12-18-2013, 05:52 PM
Morning5's Avatar
Quoted: 327 Post(s)
Liked: 108
Hi,
I need to disable Scanning Backlight, because I find the flicker annoying, so I investigated in internet and some LG tvs have a Scanning B/L setting in Tool Option 5 inside Service Menu (I have attached a picture of a LG 65LW tv with the Scanning B/L setting in Tool Option 5).
So, I purchased an universal control remote and gained access into the Service Menu -EZ Adjust- of my LG 47LX9500, went inside Tool Option 5, but there wasn't a Scanning B/L setting. Then I went inside the other Tool Options, 1, 2, 3 and 4, but no Scanning B/L setting.
Please help me disable Scanning Backlight,
Morning5 is offline
post #2681 of 2682 Old 04-10-2015, 08:50 AM
Liked: 0
Protective glass of my 47LX9500 is cracked. I am going to dismount it. Is there any disadvantage using this TV without glass panel?
gbr73 is offline
post #2682 of 2682 Old 05-08-2015, 04:43 AM
somagiz's Avatar
Hi, Since a while, I was receiving a ''youtube device support'' warning video on my youtube application and yesterday my youtube application has stopped searching and playing, now what? My TV (LX9500-ZA) won't be supported anymore by LG? Appareantly there is no a new firmware currently, what do you think?
somagiz is offline
Reply LCD Flat Panel Displays
