Official Sony KDL-xxHX800 Owners Thread - Page 16 - AVS Forum | Home Theater Discussions And Reviews
Old 09-03-2010, 08:21 PM
kriegs's Avatar
Originally Posted by jsl10 View Post
For folks that bought the HX800... what made you buy this set over others? What was the deciding factor? Also, which ones were close runner-ups? Thanks!
Sony handles motion and and compressed signals from cable providers better than all. The Samsung C6500 drove me crazy with its glare, clouds, light leakage, and jittery picture. The LG 5400 was a dull matt screen but pretty solid. In the end, I wanted a good looking (thin) LCD that did 2d really well and had an ethernet port. I have heard good things about the C8000, but I believe it will still have a stutter during some panning scenes and dont like to deal with the panel lottery. Try one and return it if you dont like it.
I am beyond thrilled with my 55HX800
kriegs is offline
Old 09-04-2010, 08:51 AM
geezin's Avatar
Originally Posted by amatot View Post
Looks like Sony pushed a new update overnight.
Previous F/W PKG4.065AAT
New F/W PKG4.070AAT
No mention of it on the Sony site so I can't tell you what's been changed.
It's up now.
http://esupport.sony.com/US/perl/swu...mdl=KDL55HX800
geezin is offline
Old 09-04-2010, 09:08 AM
Ignores Mother Hens
amatot's Avatar
Quoted: 28 Post(s)
Liked: 65
Originally Posted by geezin View Post
It's up now.
Cool, thanks.
What's lame about this version is that it's a complete duplicate (from a description point of view) of what they listed out for the 4.065 release a few weeks back. I suppose they found something still goofed up.
A couple things we did notice is that our sound settings reverted back to defaults. All the picture, power and network settings stayed set as before but the sound settings rolled back to Dynamic with surround and steady settings set to off. We're noticing the sets volume levels have gained up a bit from before too, where we are not having to turn it up as much when watching Comcast. And before anyone asks, no, the volume offset is still at a default setting of zero.
/ Yamaha RX-A3060 / LG 65EG9600 /Def Tech Mythos / B&W CCM685 / Oppo Darbee Edition / ELAC ATMOS / Velodyne /
amatot is offline
Old 09-05-2010, 02:12 PM
Virgilen's Avatar
Hi Guys
Just got my 40HX800.
How do I enter the picture settings menu in HDMI 1, 2, 3 ect?
Thank you
Virgilen is offline
Old 09-05-2010, 03:08 PM
Ignores Mother Hens
amatot's Avatar
Quoted: 28 Post(s)
Liked: 65
Originally Posted by Virgilen View Post
Hi Guys
Thank you
Just select any of the inputs one at a time, and while you're viewing whatever hit the Options button on the remote and go into the Picture Settings or use the Home button instead and enter the XMB menus & slide over to the picture setup that way, making whatever adjustments you want. The TV stores unique settings individually for each input automatically and if you're lazy, you can select Common settings at the top of the item list and it will make them "common", copying to all - which is pretty handy.
Enjoy!
amatot is offline
Old 09-05-2010, 06:39 PM
jsl10's Avatar
Does the HX800 have discrete source inputs (i.e. not having to cycle through them all to change from one source to another)? Thanks!
jsl10 is offline
Old 09-06-2010, 02:32 AM
Virgilen's Avatar
Enjoy!
Thanks but have already tried this since I had the z5500 before this one, and it worked in the same way. I'll try again tonight.
Virgilen is offline
Old 09-06-2010, 07:16 AM
kriegs's Avatar
Dont ask, but for some reason Monster's Screen Clean(No alcohol) was sprayed on my new HX800 to clean some smudges. DO NOT EVER USE ANYTHING BUT A MILD SOAP AND WATER TO CLEAN. I am sure most of you know that, but I felt it might help someone avoid a colossal mistake.
There was residue, blotches and streaks all over the TV. It was like this for over 24 hours as I researched what to do
Solution - After letting the TV cool down, I used a slightly damp with Distilled water Sham wow to massage the spots and streaks and them buffed gently with a dry Shamwow.
The TV was less than 10 days old and I was so angry, but it is all better now.
Phew...
kriegs is offline
Old 09-06-2010, 09:38 AM
Ignores Mother Hens
amatot's Avatar
Quoted: 28 Post(s)
Liked: 65
Phew...
That Monster spray is a garbage product; the residue it leaves behind is simply astounding. Distilled water and a micro-fiber cloth is the only way to go!
amatot is offline
Old 09-06-2010, 11:15 AM
jobbie69's Avatar
I just pulled the trigger on this set and have a couple of stand questions. What is a good stand? I really liked the BDIs they had in the sony store, but is there something a little less pricey?
jobbie69 is offline
Old 09-07-2010, 01:14 PM
stuup1dmofo's Avatar
Quoted: 14 Post(s)
Liked: 24
Any stand that goes with your furniture will do. Just make sure there is room for the base of the tv and you're set. Also make sure it can support the weight.
stuup1dmofo is offline
Old 09-10-2010, 11:45 PM
Ignores Mother Hens
amatot's Avatar
Quoted: 28 Post(s)
Liked: 65
Scene Mode : General
Picture Mode : Standard
Backlight : 5
Picture : 90
Brightness : 50
Color : 50
Hue : 0
Color Temp : Neutral
Sharpness : 5
Noise Reduction : Off
MPEG Noise Reduction : Off
Motion Flow : Standard
Cinemotion : Off
Black Corrector : Medium
Adv Contrast Enhancer : Medium
Gamma : 0
LED Dynamic Control : Standard
Auto Light Limiter : Medium
Clear White : Off
Live Color : Medium
White Balance Factory Default
R-Gain 0
G-Gain 0
B-Gain 0
R-Bias 0
G-Bias 0
B-Bias 0
Color Matrix : Auto
RGB Dynamic Range : Auto
Eco : On
Power Save : Low
Ambient Light Sensor : Off
PS3 Display Settings
RGB Range : Full
Super White : On
Deep Color : Automatic
So after watching a few of our reference flix and then noting what I thought could be improved upon I went back to the D-V-E HD Basics disks and proceeded to go through the advanced test patterns. One thing I'll mention is my approach of not changing too many things at one time during the process of getting to know the set. What I mean by this is, I made a conscious decision to not spend too much time futsing around with two key parameters: Sharpness and Backlight. I treated fleshtones the same way when I was first getting acquainted with the set and getting things dialed in for Comcast. I left it for last.
Tonite I decided to see if I could take some of the edge off of bluray movies by revisiting the D-V-E Overscan pattern and studying it for edge noise as a result of sharpness control. What I saw was a distinct addition of edge noise to the Overscan grid so I started to tweak it downward until I was satisfied I had removed that additional noise - something I totally bypassed up until this point in time. What I found is that at "0", the pattern turned ever-so soft or blurry. To my eyes, the proper setting is somewhere between 1 and 5 for bluray feeds. I'm leaving it at 5 until we can roll through some more movies.
The other thing I am still trying to avoid is adjusting the backlighting from a centerline setting of 5. There's a lot of varying posts where people say you should drive that number down as far as you can get it before you experience too much shadow crush or lack of top end brightness. I don't disagree with this approach but I haven't wanted to introduce a third global variable to the brightness and contrast equation. Reducing the background light output level on a global level, in conjuntion with dynamic light controls enabled AND brightness & contrast settings (which control the pixel twist dynamic range) seems a bit too complicated. So in a nutshell, I think it's wise to save the ultimate backlight level tweaking once you've gained some good experience with sliding around the other controls to your liking.
One last thing worth noting. I scored one of those "sweet deal" Sony BDP-S1000ES bluray players for a secondary setup but I have it connected to this TV thru my Pio 94TXH for some A/B testing. I'm happy to report that this unit kicks some serious a$$ and the picture quality mimics that of the PS3 - with these Rev 1 settings - which in the digital domain, it how it's suppose to work. For the record, I turned off all the DSP crap in the 1000ES that's provided to smooth and refine the picture. I saw no need for it. I did force a 4:4:4 color space though.
amatot is offline
Old 09-11-2010, 09:23 PM
Quoted: 14 Post(s)
Liked: 24
A few more days...
Old 09-12-2010, 07:21 PM
Alexx1's Avatar
Does anyone here have their HX800 connected to Direct TV's 3D Channels?
If so, how good is the Direct TV 3D on the HX800?
Alexx1 is offline
Old 09-12-2010, 09:47 PM
Alexx1's Avatar
Originally Posted by stuup1dmofo View Post
A few more days...
Same here. I'll be receiving a Bravia KDL40HX800 in a couple of days.
There's a really great review on this Bravia 3D 40" at cnet. 9/10 and they even dare to call it one of the best 3D TV's of the year.
http://www.cnet.com.au/sony-bravia-k...-339303819.htm
Just not sure if the HX800 models are compatible with Direct TV's 3D Channels.
Alexx1 is offline
Old 09-13-2010, 03:23 AM
geezin's Avatar
Have a 46" and 55". Both work fine with DirecTV.
The 3D channels look great.
geezin is offline
Old 09-13-2010, 10:31 AM
Alexx1's Avatar
Fantastic! Thanks, geezin.
Alexx1 is offline
Old 09-14-2010, 01:28 AM
mattberlin's Avatar
Interesting settings amatot.
When you compare your settings with the "theatre" settings from sony, what difference do you see?
Some of your settings i use with SD Content.
But when i look BD i have deaktivated all picture optimizer.
Only MF clear is activated, i like it. It looks better to me than standard.
Your opinion to the sharpness is very informatic. I change often between sharpness min and 3 or 4. Depending on the contend i think the soft or the sharp version is better. I never had this effect before with my former Sony.
mattberlin is offline
Old 09-14-2010, 08:41 AM
Ignores Mother Hens
amatot's Avatar
Quoted: 28 Post(s)
Liked: 65
Theater mode drives the picture to much to the reds/yellows because of the inherent warm color temp selection, with the white purity really suffering. Black levels come up too much and the picture becomes sort of soft in my view. Like all the other memory setting spaces this one can also be customized so I think the real value in the Theater mode button is it's ability to become a one touch "alternate" setting option, but it's defaults look way off to me. If somehow this mode is supposed to mimic the Theater experience then I don't see it unless we are talking a theater with a projector lamp that is aging and film stock that is turning yellow.
I've tried going with Clear1 on the motionflow but I keep going back to standard as a personal preference. I find the difference between going from Standard to Clear1 much smaller than say going from Standard to Smooth.
amatot is offline
Old 09-14-2010, 10:15 AM
jsl10's Avatar
Yay... I went for the 55HX800. It is due for delivery tomorrow! I'm really excited. Nothing short of a fantastic price too! Now I guess I'll be joining you all trying various settings to get the most out of the set. I am no expert when it comes to adjusting a TV like this so I'll be looking at and trying the various ideas/settings you guys post. So the work you all do to fine tune your sets and posting here helps a great deal so thanks and keep it up!
jsl10 is offline
Old 09-14-2010, 10:33 AM
Ignores Mother Hens
amatot's Avatar
Quoted: 28 Post(s)
Liked: 65
Congrats! Did you score a bundled deal or just the set?
amatot is offline
Old 09-14-2010, 10:56 AM
jsl10's Avatar
A great price AND the bundle. I've read dozens of user's comments about this set at several reseller sites. Everyone gives the set 5 stars except a few that gave lower because 3D was not included. But since the bundle included it, I look at this set as a full 3D rather than 3D ready. I'm going to sell the blue ray HT system that comes with it (since I already have a sound system and I purchased a PS3 for blue rays). So in my mind, I'm deducting what money I will get realistically get for that. Forum rules don't allow me to post what my deal was but I'm VERY happy with it. Now, I hope I'll be just as happy with the actual set when it comes! I saw this set in person at only one store and was impressed with how well it held color off angle (even though official reviews of this set said off angle was poor). Hopefully my set will be the same and the good performance of the one I saw wasn't just a fluke. I'll find out tomorrow! :^)
jsl10 is offline
Old 09-14-2010, 11:05 AM
Ignores Mother Hens
amatot's Avatar
Quoted: 28 Post(s)
Liked: 65
Cool!
And yes, I found the more official looking reviews to be a bit off in terms of their subjective evaluation of this series, with viewing angles being far greater than expected and not seeing the "blue-ish" blacks frequently talked about.
Good luck and Enjoy!
amatot is offline
Old 09-14-2010, 02:12 PM
fl0po's Avatar
hello guys.
i'm a sony hx800 owner and i have a really big problem. i really cannot make it work in 3d with powerdvd10. the tv is conected to a HTPC via HDMI v.1.4 cable. i bought powerdvd 10, applied mark II patch. My HTPC configuration is i3 530 cpu, ati hd5600 1gb ddr5. can anyoane give an advise?
thanx in advance.
fl0po is offline
Old 09-14-2010, 03:08 PM
Alexx1's Avatar
Just received my 40HX800. Really great quality TV.
Great 3D. No ghost effects and Direct TV's 3D channels also look fantastic!
Now all we need is MORE 3D CONTENT.
But still great!
Alexx1 is offline
Old 09-14-2010, 04:20 PM
Ignores Mother Hens
amatot's Avatar
Quoted: 28 Post(s)
Liked: 65
But still great!
Congrats!
I'm going for the forty on a second setup/360 gaming rig very soon.
Glad to hear you're happy. Enjoy that beast.
amatot is offline
Old 09-14-2010, 11:54 PM
Ignores Mother Hens
amatot's Avatar
Quoted: 28 Post(s)
Liked: 65
We enabled Netflix this evening and I'm happy to report it works like a champ!
It's nice not having to fire up that power sink of a PS3 just to watch the Instant Queue. We were a tad bit skeptical going into it but the loading performance and playback was indeed snappy.
amatot is offline
Old 09-15-2010, 08:15 AM
Ignores Mother Hens
amatot's Avatar
Quoted: 28 Post(s)
Liked: 65
Originally Posted by fl0po View Post
hello guys.
thanx in advance.
Cyberlink just released an update to PowerDVD 10 yesterday,
http://www.cyberlink.com/downloads/s...es_en_US.html#
Maybe this will solve you problem.
amatot is offline
Old 09-15-2010, 12:32 PM
Alexx1's Avatar
Congrats!
Thanks, amatot.
Yeah, these Sony Bravia's are simply amazing TV sets. My 3rd Sony so far with this latest one in 3D. Great quality. I once owned a Panasonic Plasma a while back and while the picture quality was just as great, the electrical bills weren't. Along side the fact that plasmas can also make any small room feel like a oven.
Had enough of plasma and went with the best LCD makers, Sony. Not only do they rock in LCD but now they also rock in 3D. I would highly recomend these 3D HX800 series to anyone. Plasma HD & 3D quality at half the LCD HD & 3D price.
Sony should rename the Bravia to Bravo!
Alexx1 is offline
Old 09-15-2010, 08:12 PM
DaveDubya's Avatar
Here is a link to a new set, but just for the Japanese market. This is from the "Sony Insider" web site. Looks good for them. Haven't posted to this board in years, but these new sets look good and it might be time for an upgrade!
http://www.sonyinsider.com/2010/08/3...dvd-500gb-dvr/
Hope it works.
Davedubya
DaveDubya is offline
