Help me find a TV, combine OTA + Cable - AVS Forum | Home Theater Discussions And Reviews
Old 06-23-2010, 11:29 AM - Thread Starter
ppaauull's Avatar
Looking for a TV that will allow me to combine OTA HD channels and cable (very basic Comcast cable, no box).
Either a tv with 2 coax inputs, or a tv that will distinguish OTA and cable signals with reverse splitter?
Don't want to use a STB or a A/B switch.
Preferably LCD, but plasma is ok. 40-50
Been searching, but haven't found a definitive answer. Hopefully you guys can help.
recommendations?
ppaauull is offline
Old 06-23-2010, 11:42 AM
omeletpants's Avatar
You can't run HD cable over coax. You need component or HDMI. Any TV allows you to combine input sources. BTW, these type of help me choose threads are supposed to go in the "help me find an LCD" master thread
http://www.avsforum.com/avs-vb/showthread.php?t=1230050
omeletpants is offline
Old 06-23-2010, 11:45 AM - Thread Starter
ppaauull's Avatar
got it. will move there.
ppaauull is offline
Old 06-23-2010, 12:13 PM
BTW, you will still need a decoder box or cable card from the cable company to decode HD channels. You won't need a splitter because the TV has multiple input sources that will combine the cable and OTA and display it in your guide
