Vizio 47 1080p/120Hz LCD HDTV E470VL - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 06-28-2010, 12:00 PM - Thread Starter
TDK1044's Avatar
Hi Guys,
I'm new here. Having looked at many LCD HD TVs in my price range, I think I've decided to purchase a Vizio E470VL. I have a question regarding the factory default settings on Vizio TVs.
On my current HDTV, I have my DirecTV box set to 'Pillar Box' so that any 16:9 HD shows are viewed full frame, and any 4:3 shows are viewed with black bars to the left and right. I prefer that to stretching the pictures.
With my Vizio, would I set it to 'Normal' or 'Wide' in order to achieve the same result? Also, what is the factory default setting for the smooth motion effect? I have a feeling that Low or Medium will look better than High?
Terry
TDK1044 is offline
post #2 of 8 Old 06-28-2010, 01:41 PM
RichBenn's Avatar
Originally Posted by TDK1044 View Post
Hi Guys,
Terry
Since I'm looking at the same TV...
I looked at the manual for this and it looked like the best thing for smooth motion was to choose the smooth motion demo to see if your setting works well. As I understand it, it's not so good for some material and you'd want it off. Maybe a low or medium for sports?
AFAIK, "NORMAL" is what you want for the aspect ratio, assuming I understand how your DirectTV works (never had one).
BTW, please post your experiences with this set. There is another thread not far down that people are starting to post info in. I'd like to know about how good the blacks are, glare, how much banding, any stuck pixels, and anything else you discover. No TV is perfect, but it's a matter of how much value is there, IMHO.
Rich
- Rich
RichBenn is offline
post #3 of 8 Old 06-28-2010, 10:07 PM
SLUDGE's Avatar
Hi
Im glad you bought this TV. Can you post a review in the below listed thread. Trying to create one thread for this series.
http://www.avsforum.com/avs-vb/showthread.php?t=1255470
Enjoy your TV !!
SLUDGE is offline
post #4 of 8 Old 07-13-2010, 07:57 PM
dpacattack's Avatar
i just bought the Vizio E470VL yesterday from Walmart also. It looks very good straight out of the box, but was wondering if anyone has an opinion on the optimal settings for this TV.
dpacattack is offline
post #5 of 8 Old 07-26-2010, 06:18 PM
pballbeast's Avatar
Same here
pballbeast is offline
post #6 of 8 Old 02-19-2011, 10:59 AM
rf0t0's Avatar
would help here as well
rf0t0 is offline
post #7 of 8 Old 05-04-2011, 07:42 AM
beerisgood's Avatar
I recently purchased the E470VL. Great picture, but when I went thru the menu settings & more specifically the help menu & info page, under Vertical Resolution it says "60". Does this mean its not 120Hz?
(Iwas watching Bluray hooked up via HDMI)
beerisgood is offline
post #8 of 8 Old 07-08-2011, 07:02 AM
eeee87's Avatar
I would like this info as well...
eeee87 is offline
Reply LCD Flat Panel Displays
