Mitsubishi LT-40133 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 07-11-2010, 01:34 PM - Thread Starter
crazy4mopar's Avatar
Hi
I have a Mitsubishi LT-40133, I just started getting a bunch of colored lines on the right side of the TV! the strip of lines are about 4" wide here is a picture. The lines show up with or without any inputs
Any idea what could be wrong?
Is this TV worth fixing??
crazy4mopar is offline
post #2 of 6 Old 07-12-2010, 08:09 AM
darstr's Avatar
Unless it is under warr. I would get a new TV. You have a bad panel
darstr is offline
post #3 of 6 Old 10-12-2011, 10:39 AM
silvermaxd's Avatar
mine is doing the same thing....goes away after it warms up....plan on getting a vizio soon...I'm done with mitsubishi....this is the second TV with them and the last
Steve R.
silvermaxd is offline
post #4 of 6 Old 10-12-2011, 10:58 AM
BoilerJim's Avatar
Quoted: 55 Post(s)
Liked: 118
This model and all Mitsubishi LCDs have been discontinued.
BoilerJim is offline
post #5 of 6 Old 10-12-2011, 10:58 AM
FadedMaster's Avatar
Before you get a Vizio, read some of the posts on here about them. It seems they've been in some hot water lately for offering no support and saying that their TVs are unrepairable.
Smile. :)
FadedMaster is offline
post #6 of 6 Old 02-01-2013, 11:26 AM
Kenchen's Avatar
I have now got the exact same problem with the same TV. Did you get it fixed? If so what did it cost and what was actually wrong with it? Any help would be appreciated.
Kenchen is offline
Reply LCD Flat Panel Displays
