Official Vizio XVT3SV Series NO PRICE or Coupon talk - Page 156 - AVS Forum | Home Theater Discussions And Reviews
post #4651 of 4754 Old 01-29-2012, 05:36 PM
8traxrule's Avatar
I'm not sure if it would be possible to capture the effect on camera, especially for video posted on the internet. I've never seen internet video be able to handle 30 frames per second anyways. The best bet is to keep looking for points on easily-available discs which trigger this behavior so that hopefully someone at the company can get ahold of that disc and duplicate the effect there.
8traxrule is offline
post #4652 of 4754 Old 01-29-2012, 05:46 PM
lmitche's Avatar
It also appears that the CEC settings have a bug. I can't get the CEC device control on/off setting to stick to off during a power-off, power-on cycle on my xvt 553. Can anyone else confirm this problem?
This problem means that my harmony remote and the xvt553 both power on my attached pioneer receiver. This leads to random states where once the sequence is complete the receiver may be on or off. I used to set the cec setting in the vizio to off to avoid this. It no longer works.
lmitche is offline
post #4653 of 4754 Old 01-30-2012, 11:59 AM
rkodey's Avatar
I'm not sure if I'm seeing the same as the rest of you. The stuttering I'm seeing is almost like a drop in frames-per-second that you'd get playing a complex game. The video doesn't break up or anything, but the motion just isn't as fluid as I'd expect.
Is that what others are seeing? Or, do you get actual pauses or breaks in the video?
rkodey is offline
post #4654 of 4754 Old 01-30-2012, 01:23 PM
8traxrule's Avatar
No pauses on mine, just odd-looking motion. Some movies have scenes like that on purpose, which is why I wasn't sure if it was a malfunction right away. You can tell it is though if you watch something you've already seen many times before, or can pause and re-play to see the effect go away. I'll try to post movies I've seen it on- latest was "Hangover Part 2" on Blu-Ray, happened only once during a straight play-through but is repeatable. Happens roughly from 14 to 25 minutes in- when they go to the airport there's a slow-motion shot then the weird motion on the TV gets triggered for about 10 minutes until a scene where they're by an elevator at the party then the motion goes back to normal for the rest of the movie. There's something early on that's triggering the TV, since if you skip too far past the airport scene the TV will behave normally.
If anyone else notices this on a specific movie, please mention it here and I will check it out on my system if I have it. (Please specify format, though again I've seen this happen on laserdiscs too which of course are analog.)
Just got an email from Vizio saying I need to call a different number since I have the warranty, so will do that ASAP.
post #4655 of 4754 Old 01-30-2012, 08:46 PM
JohnSac's Avatar
You are correct. This is exactly what I see as well. Just used "stuttering" for a lack of a better word. Just funky/non-fluid motion. I called Vizio again. I think we all need to continue to keep bugging them about this so they know its an issue. I think the problem is that someone without a keen eye my not notice or know that it is the TV.
JohnSac is offline
post #4656 of 4754 Old 01-30-2012, 10:53 PM
8traxrule's Avatar
Didn't have time to call today, but I found yet ANOTHER problem- when playing PAL DVDs, they somehow force the TV into smooth motion! This was on my modified Toshiba HD-A30 HD-DVD player. It sends out PAL natively through its HDMI output, which my TV can display usually at the right frame rate but not this time. I know PAL film transfers are sped up a bit, but they haven't looked like video before.
Anyone else who's been having this problem should check any PAL DVDs if they have them.
post #4657 of 4754 Old 02-01-2012, 01:24 PM
rvpjr's Avatar
I have the same problem. I would describe it as fuzzy choppiness. My TV looks like sharpness is lost and the same can be said about motion while this is happening.
I can stop his problem by hitting the menu button. This seems to reset whatever the problem is until it starts again, which is pretty frequently.
It barely happens at all with the smooth motion is set to low.
This seems to have started recently.
I get hdtv signal by antenna if it matters.
I have a 473 which is out of warranty so if this isn't some weird firmware problem I will have to get it fixed eventually.
If anyone could shed some light on how much this will cost to fix, that would be great.
Thanks in advance.
rvpjr is offline
post #4658 of 4754 Old 02-01-2012, 02:05 PM
8traxrule's Avatar
I started a new thread yesterday about the motion problem, so please re-post your problem there to keep the thread on top and hopefully get the attention of the people responsible. You shouldn't have to pay to fix something that was the result of a firmware update sent by the company- they could've done it just to sell more warranties! After this experience, whatever TV I get next likely won't have any internet apps unless it can have firmware manually applied to it. I'd be better off with a TV with no internet connection and using a Roku box or something for the internet stuff. Besides, those are easier to replace once they get obsolete.
post #4659 of 4754 Old 02-01-2012, 04:33 PM
Burnerbum's Avatar
I've had my 553 disconnected from the internet for the past 3 months, I don't use the apps so I guess I'll keep it that way after reading about the latest FW. I have media players I use for media and internet. Although, my brother has the same set and his updated a while back and he said he hasn't had any problems.
I don't understand Vizio with their FW. Users should be able to update if and when they want and be able to go back if there is a problem.
And for them to make someone prove they are still in warranty for a FW update is unbelievable.
Burnerbum is offline
post #4660 of 4754 Old 02-02-2012, 06:15 PM
drunkmunk's Avatar
This is the same as what I am getting. It happens while watching HD cable, mkv playback from a WDTV and bluray on a ps3. I can make it stop by pausing and restarting the video. It is really annoying
drunkmunk is offline
post #4661 of 4754 Old 02-06-2012, 10:14 PM
Rhombus7's Avatar
Originally Posted by lokilarry View Post
Hmm! I have been having stuttering issues as well on my 552 since the update. I thought it was the source material. It doesn't happen on Blu-rays, but does on Netflix streaming and television broadcast (antenna) HD and SD.
My 553 updated oh, 1 to 1.5 months back and since has had jittery video and this green horizontal line that pops up and disappears quickly always in the same location about 1/3 of the way down from the top. Only happens in Neflix...and seems to happen a LOT more with 4:3 aspect ratio films. If I pause and rewind to play the same section over again it doesn't repeat. I've tried searching and searching Google to see if this could be a Neflix issue...with no success. I'm glad (ok, not glad we're all having problems with otherwise perfectly good TVs) that I found these comments and I'm not going crazy.
Does anyone else get the magically appearing and disappearing green horizontal line along with the stuttering video?
Rhombus7 is offline
post #4662 of 4754 Old 02-07-2012, 01:54 AM
8traxrule's Avatar
Haven't gotten the green line, but found out yesterday it's forcing the smooth motion not only on my PAL DVDs but also on some cartoon shows on Netflix and Vudu. Check out the opening of any episode of Archie's Funhouse, Ghostbusters, or Fat Albert. Doesn't do it on all 4x3 standard-def material, so don't know what the deal is here. Funny since I tried playing with the smooth motion on some online video a while ago and couldn't get it to look like video then.
post #4663 of 4754 Old 02-07-2012, 01:40 PM
csjyokel's Avatar
Glad I found this thread. Add me to the stuttering issue list.... I knew I wasn't crazy! I found ESPN, or any channel with scrolling text at the bottom, to be the most obvious way to see this issue. Its definitely on all sources, so I will be joining the crowd by contacting Vizio.
csjyokel is offline
post #4664 of 4754 Old 02-07-2012, 07:04 PM
sazaks's Avatar
I wonder if it has anything to do with people's picture settings because my set has been flawless. In fact, the halo effect on dark scenes is almost non exists with the latest firmware.
They've also improved the CEC functionality.My Onkyo AVR now powers on with the tv and the volume level of the receiver is displayed on screen.
sazaks is offline
post #4665 of 4754 Old 02-08-2012, 12:40 AM
8traxrule's Avatar
I don't use smart-dimming because it completely cuts the backlight whenever the picture goes to black or close to it- it looks the same as the TV being powered off, there should always be SOME sort of light on the screen whenever there's a picture on it! (As I mentioned before, when I complained to Vizio about this they didn't seem to understand, and they ended up unnecessarily replacing the whole TV!) The haloing effect was annoying too but not as much as this.
I made sure I got a receiver that did NOT display the volume level onscreen whenever turning it up or down, that would annoy the hell out of me too.
post #4666 of 4754 Old 02-08-2012, 08:46 AM
cawgijoe's Avatar
The whole point of the smart-dimming feature is to increase the contrast and produce fantastic black levels. This is a big selling point for LCD/LED fully backlit TV's with local dimming.
cawgijoe is offline
post #4667 of 4754 Old 02-08-2012, 09:39 AM
Burnerbum's Avatar
The Vizio Logo in the front is white when the TV is on and Orange when it's off. That should be clear enough. Without smart dimming the blacks would look gray.
post #4668 of 4754 Old 02-08-2012, 06:29 PM
8traxrule's Avatar
Not on mine- I put black tape over it so it won't annoy me!
What this thing does with "smart dimming" is the equivalent of turning the sound completely off during any silent portions.
THIS is why the current way it works is wrong: http://www.youtube.com/watch?v=2FooNiB2coc
When there's credits on the screen, the background has a bit of grey. It HAS to, that's the nature of how the picture is! When the credits fade out, the background goes completely out, only to pop back on again when the next credit fades up. Also look what it does at the 2:36 mark as the scene pans over a black wall. It's just silly.
post #4669 of 4754 Old 02-08-2012, 07:17 PM
Rhombus7's Avatar
Is yours a local dimming set? The video is weird and your explanation of there always needing to be grey on the screen is also weird. My TV would only turn on a few local dimming zones to light up the text. The rest of the screen would remain off and completely black. In that manner the effect is not as strange as shown in your video. Your video shows the entire screen lighting up when only a few zones in the center are needed to light up the text.
Rhombus7 is offline
post #4670 of 4754 Old 02-08-2012, 07:21 PM
Rhombus7's Avatar
I checked my settings after reading this to see if the update had somehow overridden my settings. Nope, everything is the same as I've been using for the last 1.5 years (CNET settings with all smoothing features turned off). Started after the update and only does it in Netflix. Luckily I have 6 months of my Costco warranty left to see where this goes.
Rhombus7 is offline
post #4671 of 4754 Old 02-08-2012, 08:21 PM
cschang's Avatar
Quoted: 134 Post(s)
Liked: 171
I think my 553 did an update this evening.....
The version of firmware says VIZIO_C7.0.1.S
Although that looks like what others have, as I got an update last month, but did not check the version. So maybe it just rebooted.
-curtis
Owner of Wavecrest Audio
Volunteer Mod at the Ascend Acoustics Forum
Like all things on the Internet, do your research, as forums have a good amount of misinformation.
Help beat breast cancer!
cschang is offline
post #4672 of 4754 Old 02-09-2012, 01:25 AM
8traxrule's Avatar
That's the same firmware mine has. You'll know when the firmware updates because when you turn the TV on, the screen will go black except for a display on the left saying something like "Please wait while we install a firmware update." The Widget Gallery can update too but that doesn't affect the firmware and doesn't make as prominent a display when it does that; if the TV reboots while it's on it's likely just run into a glitch or something.
post #4673 of 4754 Old 02-09-2012, 01:28 AM
8traxrule's Avatar
I turned the brightness up in that video so the effect would show on camera, but it does that when set darker also. If you have it set so low that there's zero background on black credits then it's really too dark, even a projected film will have some film grain or what-not in that area.
post #4674 of 4754 Old 02-09-2012, 09:01 AM
wrxlvr's Avatar
Quoted: 17 Post(s)
During startup (during the Vizio apps screen), I have a patch of pink dots in the upper third of the screen, so I guess this TV is going back for exchange.
Same model though since I REALLY like it, and the dots aren't visible during TV viewing or anything else.
I haven't hooked it up to the internet yet either since I saw some people were having issues with the latest firmware. Should I try updating firmware first to see if it solves the pink dots issue? Should I not update to this firmware at all, and just wait to update until a new firmware comes out?
Update: Vizio customer support (which was really helpful) suggested trying the firmware update (since at least one of the firmware updates has changed the splash screen on startup) to rule out that it's a problem with the startup screen image. Worth a shot to save the hassle of reboxing it up and exchanging it.
wrxlvr is offline
post #4675 of 4754 Old 02-09-2012, 03:30 PM
jgsouthard's Avatar
My XVT553SV also has firmware C7.0.1.0S, but it did that update on December 28, 2011 (about 5-6 weeks ago). After that, our problem with video freezing and spontaneous reboots started for the first time (never before that, and we've been using the TV for over a year). So I think this firmware made the problem worse, not better.
Ever since soon after we got the TV, we've had the HDMI handshake problem during warm up. For the first five minutes or so on 1080i or 1080p sources the screen is heavily pixelated. After the warm up period it stabilizes and is fine after that. It also does it on 720p sources, but the effect is much less noticable (more like "swigglies" in high contrast edges).
Both the HDMI handshake problem and the freeze/reboot problem are related to cold startup. The reboots occur very frequently (maybe 1 out of 3 times we turn on the TV), but always during the first minute or two of use. It seems to occur most frequently on 1080i/p sources during the handshake pixelation period, making me think that the two issues are somewhat related.
I'm still hoping for another firmware update that addresses these issues.
The wide viewing angle and matte-finish low glare display are key priorities for where we use this TV, so we'd really like to keep this thing working. But right now, I'd have a hard time buying another Vizio.
jgsouthard is offline
post #4676 of 4754 Old 02-10-2012, 11:06 AM
TomCat's Avatar
...What this thing does with "smart dimming" is the equivalent of turning the sound completely off during any silent portions.
You may be among a small minority that finds this to be problematic. If so, smart dimming just isn't for you, just like some are irked by smooth motion. Turn it off, and it won't bug you.
"Turning the entire screen off" when there is nothing in the video seems perfectly natural to me. The reason that the higher absolute black level of CFL LCDs is annoying compared to local dimming LEDs or plasmas is exactly because they display a level of grey when there is no video. That is not something you see in nature, so it takes you out of the concept of suspending disbelief that what you are seeing is real and not just lighted pixels, while having a proper absolute black level (which local dimming simulates pretty well) is not as annoying, because it doesn't.
For instance if I see a wide shot of a full moon, local dimming might put a bit of a halo around the moon, but at least the dark area of the picture does not look artificially bright. To me, that is preferable, and probably to many others, which is why local dimming exists; to improve the viewing experience.
And anyone who ever owned an old Trinitron-tube Sony (or basically any good TV properly adjusted from the 70's to the 2000's) knows that it is natural for the screen to go completely black when black is what is being broadcast. My 7-year old niece complained that our kitchen TV kept "going on and off", but that was because she had never seen a TV that didn't keep some grey on the screen when there was a dip to black between commercials. That was some time ago; she's 36 now. And the reason why was a combination of a dark piece of glass over the tube along with great DC restoration, and these were aspects introduced by Sony that every single other TV manufacturer soon mimicked, so dipping to full black is much more ubiquitous than it is weird.
You will see that gating artifact when the screen goes completely black, and maybe they should learn to ramp that gate to make it more natural, but most of us really have no complaints. After owning this set I wouldn't think of buying one without local dimming. I think its a great feature and that Vizio's implementation if it is pretty spectacular.
There's no place like 127.0.0.1
TomCat is offline
post #4677 of 4754 Old 02-10-2012, 11:12 AM
Burnerbum's Avatar
Is there anyway to configure the router to block the Vizio from downloading new FW and still be able to use the apps. Right now I'm still with the previous FW and have my TV disconnected from the Internet.
post #4678 of 4754 Old 02-10-2012, 11:22 AM
TomCat's Avatar
While I agree with "weird", I think that more than just a few zones light up if there is video only in one place. Those of us with DirecTV DVRs can easily demonstrate this by simply pausing video long enough for the screen saver to come on.
The new HD screen saver does have a halo around it, but that is actually part of the graphic and should be there, local dimming or not. But this screen saver is a logo that traverses the entire screen like a Pong or BrickBreaker object, and it is clear that even when it is on the far side of the screen, that the near side of the screen is partly lit by the local dimming effect. The level of black ramps down smoothly in all directions from wherever the logo happens to be, and ramps back up as the logo approaches that area.
I assume that this is on purpose and if they did it more severely it would begin to annoy most of us, and would REALLY annoy 8trax.
Bottom line, it's a workaround, not a full fix of the higher absolute black level for LCDs. It works beautifully in most situations, such as when you are watching a scene with real video in it. It can be a little artifacty for credits and dips to black between scenes, but to me that's a small price to pay for the benefits it brings most of the time.
Its immature, fairly new technology. It will only get better. And of course more dimming zones will allow for a better affect. I have heard that Viz sets have from 80 to 128 zones, but I recently heard they only have 32 zones (that may be for edge-lit). Fewer zones means the ramp must be less steep meaning it will be less effective than it would with more zones, for the rare instances that seem to be irking some of us.
TomCat is offline
post #4679 of 4754 Old 02-10-2012, 12:31 PM
8traxrule's Avatar
What if your eyes automatically closed whenever you were in a dark place?
I worked for many years as a theater film projectionist, so another effect I would compare this to would be shutting the "dowser" on the projector every time there was a black picture. If the smart-dimming didn't do that I'd be happy with it, since it does improve the black levels but that effect is just to annoying to tolerate. They should have at least put in an option to have it always leave some backlight partially on. It was certainly not very smart of Vizio to replace an entire TV when I complained about this; they should have known this was how all their TVs were programmed to work.
Meanwhile still waiting to get my frame rate fixed, warranty people still have a new board on order though I think a flash-drive with the old firmware on it would probably work and be a lot less trouble for everyone involved. Wonder what they'll do if they replace the board then the current firmware forces itself on it and the problem comes back?
post #4680 of 4754 Old 02-10-2012, 03:00 PM
Burnerbum's Avatar
Whats the difference, black is black. Would you rather see gray? Oh wait, someday you will, have you heard of Cataracts?
I like the way it works, when watching SD programs I would rather see black bars instead of gray bars and great blacks with videos.
I have the 553 and 554 and think they both very good sets.
Reply LCD Flat Panel Displays
