Help deciding between these 2 tvs for my bedroom! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 07-27-2010, 02:29 PM - Thread Starter
liquidswordz's Avatar
ok i narrowed it down between these 2 sets and asking for opinions.
http://www.walmart.com/ip/Vizio-E370VL/13904833
http://www.bestbuy.com/site/Sony+-+B...x400&cp=1&lp=1
... my viewing distance is roughly 6.5ft and im stuck between size and overall best. i would spend a little more if theres a tv well worth it but i am trying for around $500-$550. Any help would be appreciated
liquidswordz is offline
post #2 of 9 Old 07-27-2010, 02:47 PM
Steve S's Avatar
Liked: 46
A bit of a stretch but excellent value for money:
http://www.bestbuy.com/site/Panasoni...0LCD&cp=1&lp=1
Panasonics have very good pq and reliability and generally less gaming lag than other brands, if that's a concern. Their IPS panels have better off-angle performance, and it's bigger than either of the sets you list.
Steve S.
Steve S is offline
post #3 of 9 Old 07-27-2010, 02:56 PM - Thread Starter
im just thinking thats a little too big for my room and the distance im viewing it at
post #4 of 9 Old 07-27-2010, 03:03 PM
ShaqDan's Avatar
If number of HDMI inputs does not matter (or the lack of a universal remote), I'd go with the Vizio simply because it is 5" bigger. I happen to have one of these in my bedroom and it's perfect. I seriously doubt you'll be able to tell much of a difference in picture quality between the 2 tvs, so why not get the bigger screen?
Of course, if you plan on hooking up several things to it without going through a receiver, you may want to consider the Bravia, since it has 4 HDMI inputs. I'd say everything else is pretty much a wash.
ShaqDan is offline
post #5 of 9 Old 07-27-2010, 03:08 PM
DJTraveler's Avatar
I would go with the bigger 37'' tv. Yes, the Sony may have slighter better picture quality, but you will have a more enjoyable viewing experience with the larger screen.
DJTraveler is offline
post #6 of 9 Old 07-27-2010, 03:23 PM - Thread Starter
is the picture quality between the 2 negligable? i know the bigger screen may sound better but will i be just as satisfied with the vizio?
post #7 of 9 Old 07-27-2010, 03:47 PM
BoilerJim's Avatar
Quoted: 55 Post(s)
Liked: 118
Perhaps you should look at both of them and let your eyes decide rather than a bunch of strangers on this Forum. It's nice to get advice from others, but the ultimate decision is yours and yours alone.
BoilerJim is offline
post #8 of 9 Old 07-27-2010, 03:58 PM - Thread Starter
well i went to see them both in stores but its not like they had them hooked up to a bluray movie which could of made me decide easier. also, i hear the 401 model is a costco exclusive. i checked the website and couldnt find it so what does the 401 model have over the 400?
post #9 of 9 Old 07-27-2010, 03:59 PM
ShaqDan's Avatar
Go with the Vizio!
ShaqDan is offline
Reply LCD Flat Panel Displays
