Sharp LC-C5277UN - Input Problems - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 08-03-2010, 07:27 PM - Thread Starter
sumx4192's Avatar
I have the TV mentioned in the thread title. I currently have 3 HDMI devices that were all working fine. I had a blu-ray player to input 7, HD set top box to input 8, and Xbox360 to input 9.
I've recently run into a problem that it seems like only one input is working (input 8 on the screen) but it only works with a cable plugged into input 7!
I have unplugged every device. I then plugged one device into input 7 and then switched the inputs on my television. The only time I receive signal, it is when the television is set to input 8 even though no cable is plugged into input 8! As it stands, the signal is fine that does make it through on 8, but it seems as though I can't use any of my other inputs. Help!
sumx4192 is offline
post #2 of 2 Old 08-04-2010, 09:49 AM - Thread Starter
sumx4192's Avatar
anyone have any thoughts? No email back from Sharp yet...
sumx4192 is offline
Reply LCD Flat Panel Displays
