New Sony NX710 and NX810 models - Page 7 - AVS Forum | Home Theater Discussions And Reviews
Old 10-07-2010, 02:54 PM
zoro's Avatar
Quoted: 224 Post(s)
Liked: 41
Originally Posted by franknbean View Post
Zoro
I have the NX801 re-read my post I would like to upgrade to the NX810 before my 90 day exchange runs out.
my bad! sorry! too late at night.
what size 810 they have in store? They were selling 60 inch for 2.99K
zoro is offline
Old 10-07-2010, 04:56 PM
Do-It-Yourself's Avatar
Location: In a house far away from you creeps (hopefully)
Liked: 24
Originally Posted by John Carmichael View Post
I can't find a photograph of the REAR SIDE of the 55NX810 anywhere!
Because I want to install it IN WALL with a decorative wood frame (like a painting) and it needs proper ventilation and has limited space, I need to see where the air vents are located and also want to see the rear connector panel. A good photograph of the side connector panel would also be helpful.
Maybe one of you guys who is waiting for their new set to arrive could take the time to photograph the REAR and SIDES before you hang it on your wall.
While I don't have an exact model representation, most televisions will have air vents on the same place. Particular to each model/brand.
Here is an example of how it would look like on the NX810:
Panel controls are on the right side. Input is on the left side.
Do-It-Yourself is offline
Old 10-07-2010, 06:11 PM
franknbean's Avatar
Zoro
I have the 60" NX801 and would love to see a 60NX810 on the floor at costco within 15 days!!! Yes, the 60" was 3K
franknbean is offline
Old 10-07-2010, 08:10 PM
zoro's Avatar
Quoted: 224 Post(s)
Liked: 41
Zoro
Is it 801 or 810 for 3k are u confirming ? I thought yours was 2500? Ofcourse for 500 more 810 is no brainer did u see Any size 810 @ Costco?
zoro is offline
Old 10-07-2010, 08:24 PM
JoeSony's Avatar
Quoted: 53 Post(s)
Liked: 30
3k for the 60" NX810 would be a shocker, must be the 801.
JoeSony is offline
Old 10-07-2010, 09:28 PM
gerhardb's Avatar
I got my NX810 last weekend for $2500, including tax, with a BSPS570, and 3D emitter kit with Alice in Wonderland / 2 - 3D glasses.
That was a 46 inch model...
gerhardb is offline
Old 10-07-2010, 09:34 PM
zoro's Avatar
Quoted: 224 Post(s)
Liked: 41
Was that from Costco? I would like 52 or 55 to upgrade my bedroom 46 inch xbr3 that I love
zoro is offline
Old 10-08-2010, 12:34 AM
MTech8's Avatar
Costco's inventory varies from store to store.
In LA area, I saw the 60" NX801 for $2999, while in Orange County, they had the 55" NX710 for $1699.
MTech8 is offline
Old 10-08-2010, 01:19 AM
franknbean's Avatar
Sorry to mislead everyone. I bought a 60NX801 about 2 1/2 months ago for 3K. I have about 2 weeks to take advantage of Costco's 90 day return policy and get the 60NX810 if they put it on their floor. I have no idea what the new 60NX810 will cost but I'm willing to upgrade to it.
Old 10-08-2010, 02:42 AM
zoro's Avatar
Quoted: 224 Post(s)
Liked: 41
is 801 same sa hx 800, or 901?
zoro is offline
Old 10-09-2010, 08:44 AM
MTech8's Avatar
This was from another thread that was originally posted by xxrando. I found it very helpful in helping me decide on which Sony TV to buy.
Originally Posted by xxrando
Here's the major differences I've seen published, not including some minor differences in depth, power consumption, and warranty duration.
NX810 = NX800 + Dynamic edgelit + opticontrast + 3D ready + intelligent presence sensor
LX900 = NX810 - Dynamic edgelit + built-in 3D transmitter + 2 pair 3D glasses
HX909 = NX810 - Dynamic edgelit + Dynamic backlit - intelligent presence sensor - widgets - wifi
HX800 = NX810 - Monolithic design - opticontrast - widgets - intelligent presence sensor - wifi + deep black panel
Better to worst depends on which features are important to you. From a PQ standpoint, the consensus is probably as below though disagreements do exist.
HX909 > NX810 > HX800 > LX900 > NX800
http://www.avsforum.com/avs-vb/showthread.php?t=1272545
MTech8 is offline
Old 10-09-2010, 11:20 AM
zoro's Avatar
Quoted: 224 Post(s)
Liked: 41
Mtech I agree 100% on your post and classification
zoro is offline
Old 10-09-2010, 11:36 PM
Joe Jensen's Avatar
Quoted: 12 Post(s)
Liked: 26
I have my 60" NX810 now. The industrial design is not the same as the HX909 and LX900. No glass screen and no metal trim around the edge. Definitely a plastic front screen which is a disappointment but not a show stopper. The picture so far is great but the contrast does drop some off axis. On axis it's amazing.
Also, as I expected the built in speakers are all but useless.
Joe Jensen is offline
Old 10-10-2010, 10:05 AM
vladi123456's Avatar
Is it still monolith design though? Just with plastic instead of glass?
And that may or may not be a good thing - how much does this TV weigh? As far as I recall - HX909 and LX900 are both pretty heavy due to glass....
vladi123456 is offline
Old 10-10-2010, 10:27 AM
cmeinck's Avatar
Quoted: 34 Post(s)
It weights 86 pounds. It's lighter than my 52" Bravia XBR3.
cmeinck is offline
Old 10-10-2010, 10:37 AM
Joe Jensen's Avatar
Quoted: 12 Post(s)
Liked: 26
It's a little lighter then the others. It's still a monolith, but plastic is pretty easy to scratch. A wife who dusts a lot with a dust rag and who dusts the plastic front will create a haze over time. I should have waited to see one in person. I called Sony Style and they told me it had a glass front. If I knew it had plastic I would have gone with the LX900..joe
Old 10-10-2010, 11:07 AM
beinstein's Avatar
Folks
I have a new KDL60NX810 and sure it is glass not plastic covering the front of the panel
It may feel like plastic on the edge since it is so smooth- but if you tap it with a metal object it has that ping you only get from glass
It also attracts fingerprints like only glass can!
beinstein is offline
Old 10-10-2010, 11:10 AM
beinstein's Avatar
I wonder is this was what they were advertising as an NX810 but posted reviews from months before the NX810 were even announced.
I wondered what they would be actually shipping to buyers- I guess now we know
Old 10-10-2010, 11:40 AM
Liked: 24
Originally Posted by beinstein View Post
Folks
It would make it soooooooo much easier to clean the screen! Windex huh?
Old 10-10-2010, 04:27 PM
covet's Avatar
Actually, it's not a glass or plastic (although I myself would call it a plastic). It's a composite.
And yes it attracts fingerprints like no ones business (why the heck you touching it? Except of course when you're messing with 3D, reach your hand out and don't realize how close the TV is...) and I would definitely not use Windex on it. Tried that, bad experience. Dry cloths only.
covet is offline
Old 10-10-2010, 05:25 PM
If a 60 inch TV weighs only 86 pounds - it doesn't seem like it's glass - with glass it should be heavier. I thought the whole purpose of glass was to make the picture pop more - so does NX810 have more pop than LX900, for instance?
And also, what is composite??
Old 10-10-2010, 05:40 PM
covet's Avatar
A composite is a mixture of a bunch of stuff to make something else. :P
Plywood is considered a composite, for example. The "glass" screen on my iPhone 4 is also a composite.
If it was just glass, you'd get all the "wonderful" reflection properties of glass.
I did call Sony today, and they told me "it's not glass or plastic". I still personally call it a plastic though.
Also, if anyone's looked at their NX810 from a way off angle while it's off, they'll notice the screen isn't completely flat (smooth?). Not glass unless they're using 1870 technology to make the stuff.
I've never seen an NX810 and LX900 side by side so I can't make an honest opinion between the two but I liked the specs of the NX810 enough that I bought one of them instead of an LX900.
If you look at some of the pics ppl have posted of the 810 you'll see that rainbow effect from the material on the front of the TV. Glass doesn't do that, it's a result of whatever stuff Sony mixed together to make the anti-glare stuff that's covering the front of the TV.
Just to mention it, if I tap on the screen of my iPhone 4, and the TV. It makes the same sound. The glass covering the photos in my house, windows, etc all sound much different.
covet is offline
Old 10-10-2010, 07:11 PM
chiptouz's Avatar
Quoted: 27 Post(s)
Liked: 59
I bought monster screen cleaner and had no ill effects to the screen. I had major fingerprints when we put it together and on the stand. Football has never looked better. I love this TV.
I have the Denon 3808 ci also. I was wondering if you could buy a newer version of a 3d Bluray player that had 7.1 outputs like my BDP-S550 has? Use the HDMI from the dvd to the TV with the preouts to the amp? Would that work?
Argyl Home Theater - Indefinitely Delayed
My Movie Library - and still growing!
Family Room: Sharp LC-80uq17u + Denon 4520ci + Oppo 93, Speakers: C: Polk CSi-A6, F(L+R): Polk Rti-A7, S(R+RS) Polk TC60i, Sub: HSU – VTF3-MK4
chiptouz is offline
Old 10-10-2010, 11:16 PM
daijoubu's Avatar
It is definately glass with a layer of anti reflective film. The feeling that you get when touching is from the anti reflective film, thus why the plasticky feeling. Look closely at the edges and you can see the a layer on top of glass. Everything else under the layer is glass. It can crack if hit with enough force, so don't find it out the hard way.
daijoubu is offline
Old 10-11-2010, 04:11 PM
beinstein's Avatar
sorry- couldn't resist..
It appears the Iphone4 may be glass after all:
http://www.cnn.com/2010/TECH/mobile/....html?hpt=Sbin
apparently there is a problem with it cracking
Old 10-12-2010, 04:52 PM
orbidia's Avatar
The Sony NX710 is listed on SonyStyle Canada and Asia but the US only has NX810.
Does anyone know if the NX710 will eventually be sold in the US?
orbidia is offline
Old 10-12-2010, 05:08 PM
MTech8's Avatar
I am 99% that I saw the NX710 (or similar model being sold at Costco). I stopped by a Costco in Irvine, CA to see if they had the NX801 in-stock. I almost pulled the trigger on that unit cuz they had a special where they threw in a home theater system. They didn't have it, but had a 55 inch NX710. I'm pretty sure it was the NX710 because it had the monolithic styling, plus it claimed to have 240mhz refresh rate.
I ended up going with the NX810 because I wanted a 60" screen, plus wanted the anti-reflective coating. 3D is just a bonus.
MTech8 is offline
Old 10-12-2010, 05:22 PM
hughh's Avatar
Quoted: 34 Post(s)
Liked: 39
They have people already with EX710 in that topic here on AVS. One of them already had to replace it due to an apparent defective panel.
hughh is offline
Old 10-12-2010, 07:06 PM
zoro's Avatar
Quoted: 224 Post(s)
Liked: 41
From costco or where?
zoro is offline
Old 10-13-2010, 08:10 AM
hughh's Avatar
Quoted: 34 Post(s)
Liked: 39
Best Buy.
hughh is offline
