Official LG xxLD550 xxLD520 xxLD650 Owners Thread - Page 161 - AVS Forum | Home Theater Discussions And Reviews
 5Likes
post #4801 of 5112 Old 11-28-2011, 08:56 AM
Otto Pylot's Avatar
Quoted: 1368 Post(s)
Liked: 854
Originally Posted by Dabois09 View Post
Did any of you download the USB update for the LD520? I did and haven't noticed any changes really (slow motion face thing still happens when watching NFL network or anything with a lot of face time). This TV just doesn't seem to handle 60hz motion very well for whatever reason, almost as if it's required to have TruMotion enabled to get rid of some blur that you don't see on other TV's 60hz models?
I have been trying for some time to get from the technicians in Korea (via the LG support site) what exactly that update does. The only thing I've been able to get so far is that it "enchances picture quality" which is too vague for me to apply an update if I don't know what it is supposed to correct. I don't apply updated unless it corrects a problem that I know I have. It could make things worse if the "problem" doesn't exist in the first place. I don't notice any of the issues that you do so either my LD520 doesn't have that, or I can't see it, either way, I'm good.
Otto Pylot is offline
post #4802 of 5112 Old 11-28-2011, 07:12 PM
Dabois09's Avatar
Quoted: 270 Post(s)
Liked: 75
Originally Posted by Phase700B View Post
The xxLD520 models are 120HZ units. Don't see how 60HZ enters into it. Myself and others have no issues with "face" smearing on our xxld520 and xxld550 models. More likely you are seeing compression artifacts form a cable provider, although you do not state your signal source for NFL.
It seems as if their face is lagging (frame rate)? This issue has been reported many times before in this thread so surely you know which issue specifically I'm referencing. I know what the advertised artificial refresh rate of my television is *with TruMotion enabled . . . I'm saying without it enabled it doesn't seem to handle motion at 60hz as well as a 60hz TV does, make sense? My point is this TV HAS TO have TruMotion enabled to get rid of some of the blur that standard 60hz TVs do away with.
Also why does this TV have soo many issues with communicating with devices (Xbox 360's, DVD Players, Cable Boxes) when other TV's (some even cheaper) have no issue with none of the above? I love the color accuracy of this TV when you get it dialed in, but outside of that the picture has a slight blur to it and just lacks that HD pop. . .
I used to have a good set of settings before I reset my TV (when applying Firmware update). What are the max safe levels to have this TV at for an extended period of time? When I play 360 I prefer my backlight to be around the 60-70 range as I play in a well lit room.
Dabois09 is offline
post #4803 of 5112 Old 11-28-2011, 10:42 PM
Otto Pylot's Avatar
Liked: 854
I
Maybe you just got a bad set. My 47LD520 has been fine and plays very nicely with my BD player and the AppleTV2 (as well as the Wii and the MacBookPro). I have seen very little blur at all (almost non-existant) whether TruMotion is on or off. I have to admit I like a little SOE so I use it, except for movies.
post #4804 of 5112 Old 12-03-2011, 07:56 PM
vizionblind's Avatar
any recommended calibration settings for a Wii on the 42ld520?
vizionblind is offline
post #4805 of 5112 Old 12-04-2011, 12:37 AM
Otto Pylot's Avatar
Liked: 854
Just use one of the presets, Game or Cinema and tweak to your liking. Or calibrate your set and use those settings. Using someone else's settings can get you started but each set is unique based on the component tolerances, your viewing environment, whether you use a bias light or not, etc.
post #4806 of 5112 Old 12-07-2011, 03:20 PM
martyac's Avatar
Otto, Phase, or CrossFit
Roughly a bajillion pages back there was mention of the LG BD630 blu ray player. I was just wondering how it has been performing for CrossFit. I have been in the market for a player and Amazon has the LG BD630 for $59 with free prime shipping.
I want something that loads fast and jives well with my 520, will the LG BD630 fit the bill or are there better choices around that price point.
martyac is offline
post #4807 of 5112 Old 12-07-2011, 03:49 PM - Thread Starter
Phase700B's Avatar
Liked: 25
I think Crossfit actually got a Panasonic, but the LG BD630 will work great with the SimpLink LG has. You can also use the Panasonic models well with the LG. . . ie the BT210, BT310, etc.
But for the money the LF BD630 ain't bad. Just be carefull with firmware updates. I wouldn't do them at all unless you are using the NetCast stuff. Even then, some have had issues with the firmware updates. If all you want ot do is play Blu-ray movies, it should look great1t and work well with your LG TV.
Phase700B is offline
post #4808 of 5112 Old 12-09-2011, 01:33 PM
Dabois09's Avatar
Quoted: 270 Post(s)
Liked: 75
Phase, care to point me in the direction with your most updated settings? After moving my TV into an area with more natural light (and a reflection 'window') it greatly improved the quality of my picture for whatever reason. . . anything I can do to combat this and enjoy it in a dark environment?
Dabois09 is offline
post #4809 of 5112 Old 12-09-2011, 02:09 PM - Thread Starter
Phase700B's Avatar
Liked: 25
The amount of (or lack of) ambient light will make the picture look better or worse since your eyes adapt to it.
Not sure what model you have or what inputs you are using. But the two best settings are these I've included. Note, You can use the Cinema within a "range" of adjust and still get pretty decent PQ. Try it and then only adjust Brightness, Contrast, and Back light and Color in that order to get the amount of light out of the picture that you want. Stay within the ranges in the Cinema listing.
Then there is the Djams setting list. Otherwise, the ones in Post #1 are "the final settings".
LG XXLD550 HDMI CINEMA (User) PICTURE 12-2-2011 Medium Usable Range.txt 0.912109375k . file
Djams 47LD520 TXT BRITE DAYTIME Setting 75% Saturation- 5-11-11.txt 1.1162109375k . file
File Type: txt LG XXLD550 HDMI CINEMA (User) PICTURE 12-2-2011 Medium Usable Range.txt (934 Bytes, 53 views)
post #4810 of 5112 Old 12-11-2011, 06:38 PM
koolG6's Avatar
Originally Posted by Otto Pylot View Post
You can use Phase's settings which are at the beginning of this thread to get you started or search djams. As far as the AVS HD709 disk goes, if memory serves me correctly (which isn't always the case) there are a couple different formats of the file that, depending on your platform, you need to burn the disk image to a DVD but it will play on a BD player. Someone else will have to chime in here on the correct one to use and burn.
I find djams settings look great on my set but I usually watch my movies in evening with minimal light.... Would it be best to just turn down the backlight because I find it looks a little too bight for me especially in the evening....
koolG6 is offline
post #4811 of 5112 Old 12-11-2011, 07:02 PM - Thread Starter
Phase700B's Avatar
Liked: 25
First try setting the Energy Saving to "Minimum, You can always turn down the back light as it will only slightly affect white balance. You can also turn both Brightness and Contrast down some too. But you want to make sure you don't loose detail in shadowy or dark areas of the TV.
Energy Saving cuts back light down about 15% in each step.
post #4812 of 5112 Old 12-11-2011, 07:40 PM
Otto Pylot's Avatar
Liked: 854
Hey martyac. I eventually bought the Panasonic BDT-210. It's 2D-3D so I can't use the 3D aspect with my LD520 (don't really care for 3D anyway) but it plays very well with my 520. I bought it a quite a few months ago for 150 so you can probably find it online for much less than that. It has built-in WiFi if that's important which works well for what I need it to do. Loading BD's is not bad at all and it has all of the current a/v formats. I really like it.
post #4813 of 5112 Old 12-11-2011, 10:06 PM
koolG6's Avatar
Just making sure but W in the fourth spot on the 47ld520 means it is an S-ips panel correct???
koolG6 is offline
post #4814 of 5112 Old 12-11-2011, 10:56 PM
Otto Pylot's Avatar
Liked: 854
Yes. I have the 47LD520, with a "W" in the fourth position of the product code and it is indeed an S-IPS panel (confirmed via the loupe test).
post #4815 of 5112 Old 12-12-2011, 09:03 AM
Otto Pylot's Avatar
Liked: 854
Just another thought. Take a look at Post #2 in this thread. It has some info regarding Q&A about picture adjusts and a recommended reference movie summary. Also, the use of a "bias light" placed and used behind the TV at night really helps picture quality and eases eye strain. It is usually best to watch TV at night with soft, indirect lighting in the room rather than completely dark. I know many folks like the dramatic effect of an all dark room, but a small 13 watt compact florescent bulb in an unobtrusive lamp hidden behind the TV really is nice. The light should be placed so it illuminates the wall and ceiling area behind the TV. Most people find that it improves things immensely!
Hey Chief, I think you responded to the wrong person
post #4816 of 5112 Old 12-12-2011, 09:57 AM - Thread Starter
Phase700B's Avatar
Liked: 25
post #4817 of 5112 Old 12-12-2011, 09:58 AM - Thread Starter
Phase700B's Avatar
Liked: 25
Yup. . . . deleted!
post #4818 of 5112 Old 12-23-2011, 05:50 PM
VBB
VBB's Avatar
Quoted: 1009 Post(s)
Liked: 861
VBB is offline
post #4819 of 5112 Old 12-23-2011, 07:15 PM
djams's Avatar
Originally Posted by VBB View Post
Happy Holidays, fellas! Hope all is well
Hello Henry!
Happy Holidays to you and your recently expanded family as well!
Hope all is well with y'all
djams is offline
post #4820 of 5112 Old 12-23-2011, 07:23 PM
Otto Pylot's Avatar
Liked: 854
Dewd! Where ya been? Nice to see you here. I hope all is well with you and yours and that you have a very nice holiday.
post #4821 of 5112 Old 12-23-2011, 08:29 PM - Thread Starter
Phase700B's Avatar
Liked: 25
Hello Henry. ..
Yes, best to you and yours this holiday season! Regards from the mid-west!
Go Packers. . . hope they do well the next 2 games.
post #4822 of 5112 Old 12-24-2011, 02:14 PM - Thread Starter
Phase700B's Avatar
Liked: 25
So, had some time this afternoon and put Sea Biscuit on the 42LD550 . . . it't my primary reference disc you know. Thought I would check it and also check gray scale with HD709. Not going to. . . . nope. After almost 18 months this TV is gorgeous! Such natural and deep colors, almost 3D like picture at times, clear clean and pure looking black & White stills in the movie. Skin tones are just superb. All different shades of reds, green fresh grass, violet/purple, vibrant orange, warm earth tone browns and umbers.
Nope, it doesn't need a thing! Sit back, relax. . . . . and pick out some movies for the lazy holiday viewing after visitors have left. Some afternoon footbal on Sunday. Life Is Good. . . . yup!
post #4823 of 5112 Old 12-31-2011, 08:40 PM
123Michael5321's Avatar
Forgive me, but I'm new to AVS Forum, so I'm not quite sure where to ask this -
I'm in need of a new tv. The set in my bedroom (an old, non-HD, cathode tube dinosaur of a tv) gave up the ghost the other day.
My neighbor is moving out-of-state next week. He mentioned to me that he was looking to sell a number of items he doesn't want to transport to his new home. One item is a tv which I know he bought only about 6 months ago. It's an LG 46LD550 46" LCD 1080p 120hz HDTV. He wants $359 for it.
The tv seems to have good reviews, and at six months of age it's not like it's near the end of its usable life or anything. I figure I'll put it in my living room, and move the tv currently in my living room (a 32" LCD HDTV) to my bedroom. Frankly, 32" has long struck me as a little small for my living room; moving up to 46" appeals to me. But 32" seems like an okay size for my bedroom tv.
I've never purchased a used tv before. Does $359 sound like a good deal for this tv? Any advice would be welcome.
Michael
123Michael5321 is offline
post #4824 of 5112 Old 12-31-2011, 10:58 PM - Thread Starter
Phase700B's Avatar
Liked: 25
$359? Okay. . . not $350 or $360? Well, it;s a pretty good TV, will likely have a VA LCD panel. Did you see it with any program material , Blu-ray ,etc?
I would check the hours of use. Just hit Menu , the RED button on the remote,and scroll down to Product/Service and hit Enter. It should have at least 08.02.16 Software Version too. Check the Model /Type also.
If it has less than 1,800 hours or so I guess not a bad price. The VA panel is not known for best black level or off angle viewing, but many other name brand TVS use it also.
The 46LD550 is a 2010 model and question 6 mo. old. That would be June and the 2011 LK series was out for several months before that.
post #4825 of 5112 Old 01-01-2012, 03:09 AM
thegam3's Avatar
Quoted: 18 Post(s)
$359? Okay. . . not $350 or $360? .
lololollol
thegam3 is offline
post #4826 of 5112 Old 01-01-2012, 12:44 PM
blarsonjr's Avatar
So today I come home from church to hear this started happening on the TV about 2 hours ago. It has been running flawlessly since I got it in Oct.
The picture gets lines in it and you can see shadows of what is on the bottom of the screen now on the top.
I've unplugged it and left off for about 10 minutes, doing same. Right now it's off, I've reseated every input cable, even though it is occurring in multiple HDMI inputs, (I haven't tried component yet.)
Any ideas ?
I guess I should be buying the 5 yr warranty.
blarsonjr is offline
post #4827 of 5112 Old 01-01-2012, 05:11 PM
blarsonjr's Avatar
They had me do a hard reset, which is pulling the plug, holding the power button for 30 seconds and plugging back in. Still had problem.
Total time from dial to hang up. 25 min.
Any words of wisdom to watch for w/ the tech?
post #4828 of 5112 Old 01-02-2012, 01:21 PM
blarsonjr's Avatar
The repair vendor called, they want to order parts before they arrive. That's good. I had to "explain" what is happening. They were not interested in me sending a picture of the screen which might have given them a clue. Also I stated I wanted the same panel if that needed to be replaced. He stated I would get the only panel that would fit, blah blah blah. They called back asking for the product code because there are different versions. Which is exactly what I tried telling him already.
post #4829 of 5112 Old 01-02-2012, 07:18 PM
gdubs23's Avatar
Alright, I am a complete noob to AV type things, but I just recently bought the LG 42LK520.
I have tried to find the best settings for this things, but I honestly don't understand what most of it means. The room is usually pretty bright and I use the tv for sports and gaming (xbox) mostly. All things are hooked up using HDMI. Any help would be great with some adjustments to make to make fast motion as smooth as possible.
gdubs23 is offline
post #4830 of 5112 Old 01-02-2012, 08:00 PM
blarsonjr's Avatar
Hi and welcome,
I'm a newb w/ this TV as well but grew up in a home w/ a TV engineer (ABC TV) so I grew up expecting a pretty decent picture on my home set.
Post 4809 above by Phase has some nice settings. Search the thread for calibration or settings you'll find others. You don't have to know what it all means, just what you like. The Expert modes give you the most control but you can also just adjust the existing standard, etc to get what you like.
With the fast motion, I experimented w/ Trumotion settings. I found for setting Trumotion hockey was the best and once I had it set for hockey I liked it for all other sports, even soccer when panning. For tru motion w/ Blu Rays etc....I've experimented w/ the True Cinema setting, which curiously lately I haven't been able to touch. It's greyed out so I have to see what I did to cause that.
Bob
Reply LCD Flat Panel Displays
