Green Tint across all connections (pics) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 08-27-2010, 10:59 AM - Thread Starter
TheGM10's Avatar
Vizio 32" LCD. The TV is functional, although everything appears green on the screen. It is not a connection problem, as the issue translates across multiple inputs. Pictures of two different inputs (one a cable input and the other a computer, although it does the green thing across all of the inputs) are attached below.
TheGM10 is offline
post #2 of 6 Old 08-28-2010, 02:54 PM - Thread Starter
TheGM10's Avatar
Anyone?
TheGM10 is offline
post #3 of 6 Old 08-28-2010, 04:38 PM
BoilerJim's Avatar
Quoted: 56 Post(s)
Liked: 118
It would REALLY be nice to have more information... what model of VIZIO is it, how old, how long has it been doing this, is it intermittant or all of the time, etc., etc.
BoilerJim is offline
post #4 of 6 Old 08-28-2010, 05:24 PM
gagit811's Avatar
Quoted: 37 Post(s)
Liked: 37
you are in the matrix. I couldn't tell you whats up, have you checked your tint color settings?
gagit811 is offline
post #5 of 6 Old 08-28-2010, 06:41 PM
westa6969's Avatar
Quoted: 398 Post(s)
Liked: 418
I've had this happen in the past and here is one cause.
I've had this occur in the past and it was caused by the RED Component not being seated properly and without the RED of the RGB you get an all green tint with the RGB Component. It happened with my Xbox Component and I played a new game and thought it just had a Green tint until I observed blood wasn't even red and I had no RED = Green Tint.
Reseat your connections firmly --- Are you using HDMI or Component?
Does your panel remote have a factory reset?
Does the event replicate if you change out with different functional source connections?
What colors are missing?
Samsung 75HU8550w/SEK-3500-UHDVideoPk, 65F8000, 60D8000, 40HU6350, Philips Folio Soundbar
XBoxOne/360, FPS's Borderlands 1/2, EDF 2017/2025, Halo's
westa6969 is offline
post #6 of 6 Old 08-29-2010, 12:36 AM
Extreme_Boky's Avatar
If it happens across all inputs -> replace AV processor board.
Good luck.
Boky
Extreme_Boky is offline
Reply LCD Flat Panel Displays
