Official Sony XBR LX900 Owners' Thread (60LX900, 52LX900, 46LX900, 40LX900) - Page 16 - AVS Forum | Home Theater Discussions And Reviews
post #451 of 516 Old 09-27-2011, 01:52 PM
LBJ2's Avatar
Originally Posted by cchrono View Post
My experience has been the same not really any ghosting at all and if there is its usually on lower quality source material like Comcast 3d channel or on demand
Thanks. You may be right about the 3D source--I know any 3D I watch from Youtube is pretty bad. However, any 3D from Bluray, Directv, or streaming is pretty darn good on this TV for my eyes.
Once I discovered the 3D video adjustments on the LX and my blu-ray player, it got even better!
LB
LBJ2 is offline
post #452 of 516 Old 09-28-2011, 10:26 AM
LBJ2's Avatar
Some more good news--Sony added CinemaNow to our LX900 streaming video apps menu ! I just saw it today on the video menu ( you have to scroll down a bit to find it--just after the Style.com app). Thanks Sony!
P.S. Can we also have Vudu on the LX900 too ?
LB
LBJ2 is offline
post #453 of 516 Old 09-28-2011, 12:56 PM
iamthehunter's Avatar
source material is key. last years football was not "unwatchable" but ghosting was real bad in certain views. much improved this year and available content is growing. i expect 3D content will continue to improve as screen size increases. sony has been pretty good with release of fw updates for the LX900 and 3D too.
iamthehunter is offline
post #454 of 516 Old 10-04-2011, 06:01 AM
brooks2's Avatar
LBJ2, just curious what adjustments did you make on the LX900 to improve the 3D video ??
TNX
brooks2 is offline
post #455 of 516 Old 10-05-2011, 07:23 AM
LBJ2's Avatar
TNX
Hello. I was referring to the 3D menu itself. When I first bought this TV, I didn't realize I was able to adjust the 3D effect or 3D glasses brightness. Depending upon the 3D content these adjustments can be dramatic--enabling that "reach into your room" effect.
LB
LBJ2 is offline
post #456 of 516 Old 10-06-2011, 05:19 AM
brooks2's Avatar
Thanks LBJ2, I know I have tweaked my settings and am quite satisfied.
brooks2 is offline
post #457 of 516 Old 10-08-2011, 03:19 PM
LBJ2's Avatar
Check your 3D Sony Experience App on the LX900. Looks like Sony has loaded a few more 3D movie clips/trailers to include several from the latest Harry Potter film. Enjoy
LB
LBJ2 is offline
post #458 of 516 Old 11-13-2011, 09:01 AM
jcord51's Avatar
These samples look great compared to some other sampled 3D clips. Hope they provide more!
jcord51 is offline
post #459 of 516 Old 11-15-2011, 12:09 PM
Daz-man's Avatar
Anyone have their tv turn off then back on again by itself?
Daz-man is offline
post #460 of 516 Old 11-15-2011, 02:14 PM
No issues with anything on this set. I did have an On/Off issue with a Samsung LNT4069 but it wound up being the STB (Direct)
post #461 of 516 Old 11-16-2011, 11:13 AM
TheMoose's Avatar
there is a setting that will turn off the TV if it thinks no one is in room
"Racing is........Life.......Everything before & after is just waiting"
TheMoose is offline
post #462 of 516 Old 11-16-2011, 12:17 PM
jcord51's Avatar
It has happened to me, once or twice. It has not happened in months.
jcord51 is offline
post #463 of 516 Old 11-16-2011, 12:19 PM
jcord51's Avatar
I disconnected this setting.
jcord51 is offline
post #464 of 516 Old 11-16-2011, 12:32 PM
Daz-man's Avatar
I forgot about that one, thanks.
Daz-man is offline
post #465 of 516 Old 11-17-2011, 06:17 AM
brooks2's Avatar
I also have the setting turned off and it has happened three times in the last 6 months. Kinda irritating.
brooks2 is offline
post #466 of 516 Old 11-17-2011, 06:29 AM
LBJ2's Avatar
Hello. Try turning off the Presence Sensor on the TV. When the sensor is set to Medium, or High the TV will turn itself off if it does not detect any movement in its field-of-view--even if you are sitting in front of the TV but not moving e.g. asleep or sitting very still for several minutes. (I keep mine set to Low and that seems to work out fine for me )
LB
LBJ2 is offline
post #467 of 516 Old 11-17-2011, 07:27 AM
jcord51's Avatar
Same here, as far as how often it occurs . When it happens my wife always blames me! You always worry of a problem because the warranty is only a year. To think that the XBR was always Sony's top and had the better warranty.
I truly love the picture quality on this set, I have the 60" version (fully calibrated) and can not see it getting any better. Only negative is the sound quality, which forced me to use a sound bar.
jcord51 is offline
post #468 of 516 Old 11-17-2011, 10:17 AM
TheMoose's Avatar
Ha!
No TV I've ever seen has anything but crappy audio!
TheMoose is offline
post #469 of 516 Old 11-17-2011, 12:31 PM
Daz-man's Avatar
I just talked my brother-in-law into buying one and it's happening to him! Presence sensor is off and it's happened to me twice before shutting it off. Time will tell.
Daz-man is offline
post #470 of 516 Old 11-17-2011, 03:12 PM
LBJ2's Avatar
Hmmmm. My Lx900 has never turned off unexpectedly nor have I heard of this from others over the last year or so. I wonder if there is some other setting that needs to be set as well...I have my Presence Sensor set to "mild"
Other settings to check on the home menu under PREFERENCES/ECO:
Power Saving : Off
Idle TV Standby: Off
Auto Shut Off: See the note-I leave this setting "On"
Check your setting for " Distant Alert" too. ( this kicks in if a small child is standing too close to the TV screen)
LB
LBJ2 is offline
post #471 of 516 Old 11-17-2011, 03:18 PM
LBJ2's Avatar
Ha!
I agree--these new TVs are so slim and trim I doubt there is much room to include any type of quality sound/speakers. I would recommend an external sound system for any of these new slim LED models Sony/Panasonic/Samsung/LG/etc. Even the most modestly priced sound bar will provide a better sound experience ( than the internal speakers) to match the excellent PQ of these new LEDs.
LB
LBJ2 is offline
post #472 of 516 Old 11-18-2011, 03:40 AM
Daz-man's Avatar
Power Saving : Off
I'll give it a try thanks.
Daz-man is offline
post #473 of 516 Old 11-25-2011, 06:14 PM
T100's Avatar
Quoted: 31 Post(s)
Liked: 25
Anyone get ISF Calibrated yet or get a nice calibration yet xbr-60lx900?
T100 is offline
post #474 of 516 Old 11-25-2011, 06:26 PM
T100's Avatar
Quoted: 31 Post(s)
Liked: 25
Is it possible for this to get skipe update ?
T100 is offline
post #475 of 516 Old 11-25-2011, 10:08 PM
salin235's Avatar
Is this tv worth buying? I am looking at a 40"..
salin235 is offline
post #476 of 516 Old 11-26-2011, 04:25 AM
LBJ2's Avatar
Try these professional settings for the LX900 both 3D and 2D here:
http://www.hometheater.com/content/s...-hdtv-settings
LB
LBJ2 is offline
post #477 of 516 Old 11-26-2011, 04:25 AM
LBJ2's Avatar
No Skype on the 2010 Sony TVs.
LB
LBJ2 is offline
post #478 of 516 Old 11-27-2011, 05:50 AM
LBJ2's Avatar
This TV was Sony's XBR or top-of-the-line for 2010 ( now discontinued) . I think the TV has excellent 2D and 3D PQ and even though I paid way too much for the set in 2010, I still very happy with it.
LB
LBJ2 is offline
post #479 of 516 Old 11-29-2011, 05:08 AM
Daz-man's Avatar
Have to agree. Bought a 52" for $1999.00 with a free PS3 and I love it. This tv is right up there with the NX I just received.
Daz-man is offline
post #480 of 516 Old 11-30-2011, 10:20 AM
Daz-man's Avatar
What do you guys have the backlight set at. Mine is at 7 using settings on here, but I have power saving off. May mess with this setting.
Scene-general
Picture mode-standard
Backlight-8
Picture-95
Brightness-46
Color-52
Hue-0
Color temp-warm 2
Sharpness-11
Noise reduction-off
Mpeg-off
Motionflow-smooth
Cinemotion-auto 2
Black corrector- low
Advanced contrast enhancer-low
Gamma-+2
Auto light limiter-off
Clear white- off
Live color-off
Power saving- off
Presence- off
Light sensor- off
Daz-man is offline
Reply LCD Flat Panel Displays
