I need help with new Samsung LN40C630 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 09-15-2010, 12:52 AM - Thread Starter
pinkmadsama's Avatar
Hi, I just bought the Samsung LN40C630 and it is brand new. I've plugged it in and plugged in an antenna into the TV, but for some reason, when I turn on the television, it just plays a little intro sound, the screen then flashes a dark blue for about a second, then the screen goes blank, even though the TV is still on. Why is this happening?? Any help would be appreciated!
Brian
pinkmadsama is offline
post #2 of 5 Old 09-15-2010, 04:29 AM
EG3
EG3's Avatar
After the screen goes blank, hit the menu button and verify that the menu comes up. If that works, try switching inputs with the source button. If you get no menus or any kind of on-screen display, your set is defective.
EG3 is offline
post #3 of 5 Old 09-15-2010, 03:48 PM - Thread Starter
Yeah, nothing comes up. I figured it was defective. I'm gonna request a technician...Thanks for the Help! =]
post #4 of 5 Old 09-15-2010, 05:13 PM
mes444's Avatar
You should return it rather than try to get it repaired. Why have them open and poke around inside a brand new tv when you can just exchange it for a functioning unit.
mes444 is offline
post #5 of 5 Old 09-15-2010, 08:10 PM - Thread Starter
Ohhhh because I bought it on eBay... at least the TV is still covered under warranty so the repair service is free. Who knows, they might even replace my TV (hopefully)
Reply LCD Flat Panel Displays
