Which Samsung HDTV's support Audio Return Channel? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 09-25-2010, 12:05 PM - Thread Starter
gamermwm's Avatar
Quoted: 83 Post(s)
Liked: 93
I'm just wondering which Samsung HDTV's support ARC? Is it only the 3D one's?
I have a LN46C630 which I believe came out this year and was wondering if it supported HDMI 1.4 so I could use ARC
What is the meaning of life?
www.iamsecond.com/films
gamermwm is offline
post #2 of 6 Old 09-25-2010, 01:46 PM
westa6969's Avatar
Quoted: 398 Post(s)
Liked: 415
I believe the HDMI ports must be certified as ARC compliant for it to work.
The trick is figuring out which TV's possess ARC Compliant HDMI Ports besides 3D TV's and they don't have to identify them as such.
Samsung 75HU8550w/SEK-3500-UHDVideoPk, 65F8000, 60D8000, 40HU6350, Philips Folio Soundbar
XBoxOne/360, FPS's Borderlands 1/2, EDF 2017/2025, Halo's
westa6969 is offline
post #3 of 6 Old 10-29-2010, 01:05 PM
junkmail's Avatar
No, the LN46C630 does not have audio return channel because it's HDMI 1.3. You need HDMI 1.4 (3D capable with ARC)... See wikipedia: http://en.wikipedia.org/wiki/HDMI
junkmail is offline
post #4 of 6 Old 10-01-2011, 06:38 PM
Whio's Avatar
Although its a year since this question was posted, someone else might hit on it. Hence this post.
I recently bought a Samsung UA40D5000 (Series 5 LED) and couldn't get ARC to work to my Onkyo AVR.
However, you can find "Tech Specs" for each model on samsung.com (find the model, click the Tech Specs tab) and they are, at time of writing quite specific about ARC under the heading "Features" - for my model, no HDMI 1.4 ARC.
For the Series 6 40" LED, ARC is supported. I haven't compared a lot of Samsung models but I suspect that ARC is supported from Series 6 on.
Whio is offline
post #5 of 6 Old 11-30-2013, 11:08 AM
jrfitzny's Avatar
I just bought a 6200 series samsung 55"; it does not support HDMI-ARC :(
Thinking about returning it for one with that capability.
jrfitzny is offline
post #6 of 6 Old 07-23-2014, 12:37 PM
Liked: 0
No ARC on Samsung UN55H6203
Brand new Samsung UN55H6203 55 inch TV
Brand new Samsung HW-H450 Wireless Audio Soundbar
Who would guess that they don't play nice? The TV's HDMI doesn't support "audio return channel" (ARC). Are you kidding me?? This feature is part of HDMI 1.4 from 2009. Why would Samsung release a TV in 2014 without ARC? Best workaround is to use TOSLINK to connect them.
jtayl22 is offline
Reply LCD Flat Panel Displays
Samsung Ln46c630 46 Inch 1080p 120 Hz Lcd Hdtv Black
