Official Sony Bravia KDL NX810 owners' thread (60NX810, 55NX810, 46NX810) - Page 221 - AVS Forum | Home Theater Discussions And Reviews
 5Likes
post #6601 of 6689 Old 10-20-2013, 04:44 PM
abredt's Avatar
Suddenly, I am unable to connect to the internet for Netflix, YouTube, etc. It worked a few days ago.
I get to Network Setup is now complete and the 3 OKs. When I select OK, it sys "Configuration failed while connecting. There is no link. Please check the cables." (There are no cables - it's wireless.)
I've not changed anything in my setup. I've tried everything - reset TV, reset cable modem and router...
Could there have been a software update that is causing it?
Any ideas? cb
abredt is offline
post #6602 of 6689 Old 10-21-2013, 06:07 PM
abredt's Avatar
Originally Posted by MrEastSide View Post
Try resetting your modem... routers as well, if you have any. Not sure what to suggest on the TV side of things, but many connection problems can be resolved by resetting modems and routers.
Sent via Samsung Galaxy S3
What worked for me was unplugging the power cord from the TV then reset cable modem and router.
cb
abredt is offline
post #6603 of 6689 Old 02-09-2014, 08:40 AM
steel916's Avatar
I have been using a screen cleaner ordered from Monoprice and it has been working fine for last few times. I was trying to clean my screen yesterday and it left the screen with very bad streaks. It looks like it took the coating off the gorilla glass in some parts. Would anyone know what I can do to get rid of this? TIA for any help. I have tried plain water mixed with vinegar, ammonia free glass cleaner to no avail. I am attaching a picture for reference.
steel916 is offline
post #6604 of 6689 Old 02-09-2014, 06:13 PM
djbluemax1's Avatar
Quoted: 54 Post(s)
Liked: 300
Yikes! There's really not much you can do. That definitely looks like you took some of the coating off. If you DID take part of the coating off, you have 2 options, leave it, or take the rest of it off so it looks even. You'll get more glare though.
I think even the manual warns against using anything but a soft cloth dampened slightly with water.
For future reference (and other TV owners), the safest way to clean a modern TV screen is to use a soft brush first (or blower brush like the ones made for camera lenses) if there's a decent amount of dust. For fingerprints/smudges, use a clean microfiber cloth dampened slightly with distilled water (no contaminants to leave a residue). If you have a Zero Water pitcher, filtered water that measures '0' to 6ppm is also pretty contaminant free.
Never scrub hard. It can take the coating off. Never wash the screen cleaning cloth in a washing machine or use laundry detergent. Many laundry detergents have additives that will leave a residue on the cloth that can cause streaks or even scratches.
If necessary, hand wash the cleaning cloth with a small amount of blue Dawn dishwashing liquid and drip dry.
Max
djbluemax1 is offline
post #6605 of 6689 Old 03-22-2014, 07:51 PM
cabletvsucks's Avatar
So after 3 years just wondering how the Sony NX810 is holding up for you people? Mine is still great, but never did use the 3D much, so waste of money IMO.
THks
cabletvsucks is offline
post #6606 of 6689 Old 03-23-2014, 07:27 AM
jugger's Avatar
Liked: 55
THks
Mine is holding up very well (knock on wood) and it has survived moving to three different locations. No problems at all and I do use the 3D
RC-64 Center, RF-7 Fronts, RF-82 Sides, RW-12D, QTY=2, RSW-15, RS-52ii Rears, Pioneer SC-1522-K, Panasonic 65VT60, 65"
jugger is offline
post #6607 of 6689 Old 03-24-2014, 11:24 AM
That's great, I see no reduction in the LEd colors after 3 years either.
post #6608 of 6689 Old 03-24-2014, 04:25 PM
Do-It-Yourself's Avatar
Location: In a house far away from you creeps (hopefully)
Liked: 24
Mine looks great along with the bunchin (or however you spell it) stand. I still think it's one of the nicest TV's around tongue.gif
Do-It-Yourself is offline
post #6609 of 6689 Old 04-13-2014, 12:35 PM
chiptouz's Avatar
Quoted: 27 Post(s)
Liked: 59
So I am thinking about selling mine and buying an 80" how much do you think is reasonable? Amazon is showing used from about $1650 and up.
Argyl Home Theater - Indefinitely Delayed
My Movie Library - and still growing!
Family Room: Sharp LC-80uq17u + Denon 4520ci + Oppo 203, Speakers: C: Polk CSi-A6, F(L+R): Polk Rti-A7, S(R+RS) Polk TC60i, Sub: HSU – VTF3-MK4
chiptouz is offline
post #6610 of 6689 Old 04-14-2014, 05:48 AM
jugger's Avatar
Liked: 55
I had looked into this as well and was very surprised to see how much these were selling for. I don't think this is true but almost seems as if there is a demand for them still like collectors items. You could try $1,600 but I have a feeling it will never sell for that. If I knew nothing about the TV I would not pay more than $500.
jugger is offline
post #6611 of 6689 Old 04-29-2014, 05:55 AM
agni1's Avatar
Hi,
I have KDL55NX810 - automatically rebooting after few seconds of display, it appears that power supply problem and many of them ran into same issue. I am trying to open the back cover removed all the back side screws somewhere is still holding, is there a latch or something?
Thanks and appreciate your input.
agni1 is offline
post #6612 of 6689 Old 06-06-2014, 05:17 PM
mattdub1's Avatar
Quoted: 166 Post(s)
Hey guys hoping you can help. I have an nx810 55 inch. I noticed that when I get up close during playback or when its in the Eco standby mode (switch on right lower back side is on) but the TV is off, there's a buzzing sort of power noise. Is this electric buzz sound normal when the TV is on or when its off in standby mode?
mattdub1 is offline
post #6613 of 6689 Old 06-21-2014, 08:20 PM
jamesgf's Avatar
Originally Posted by agni1 View Post
Hi,
On my 52nx800 you remove the 6 total along each side, two near the bottom mount, the 4 wall mount screws, and
2 more near the input panel. Then just pull from the bottom up and it will pop off, take a bit of force and makes a popping sound as you release the clips/tabs.
For those of you with a 2 blink led code, or random resets or other power board codes, here is a common fix that worked for my set when the power board went down.
2 blinks indicates power board fault. I fixed my board by replacing MOSFETs q6101 and q6102 (replacement part FQPF9N50CF 9 amp, 500 volt can be ordered via mouser) and fusible resistor r6536 (0.47 ohm. 1/2 watt ordered from amazon) on the power board. The MOSFETs fail and the resistor blows to protect the rest of the circuit. This fix works on ex500, ex600, nx800 series sets and others, and is a common failure, the board locations and numbering will be different for other power boards but the same parts fail on many of these sets.
jamesgf is offline
post #6614 of 6689 Old 06-22-2014, 06:18 PM
sbx007's Avatar
My 60nx810 is still going strong. I paid a boatload for it so it better. Plus I have te3h 5 year warranty so 1 year to go. Not much in the way of 3-D for my taste so never use it.
It was just great watching avatar, the demo and couple other things. ESPN 3d was ok while it lasted. The active glasses are uncomfortable and lousy. Hard to watch anything for more than 10 minutes. I wear glasses so its really hard to watch. It came with the TV...I would have bought the TV w/o 3-d if that's how it came.
beinstein likes this.
60nx810 | htfs-470 | BX-58 | PS3 | SA 8300HD STB
Visit our settings page:
(SETTINGS ONLY!!) Sony Bravia KDL NX810 @ http://www.avsforum.com/avs-vb/showthread.php?t=1312645
sbx007 is offline
post #6615 of 6689 Old 07-31-2014, 03:57 PM
Liked: 0
Thumbs down Network Selection Limited
I was looking at my network selections on the TV and noticed that almost all of the selections were Sony Entertainment based or the generic network sites for social media. I linked with the Sony tech group on the web site, and asked how I could add my own selections. To my amazement the tech said I couldn't change the selections. I couldn't add any .tv selections I wanted and that was the limitation of the product. I'm wondering if there is a consumer rights issue here? Sony has basically prevented me from looking at other web tv selections except their own! What gives here?
Tartan10 is offline
post #6616 of 6689 Old 08-13-2014, 09:35 PM
Lippertize's Avatar
Quoted: 29 Post(s)
Liked: 29
Any ideas? cb
I had an similar issue, but then even though I could update content, the TV Guide feature would show 'no data' I did a factory reset which is as follows:
Step 1
Press the "Power" button on your set's remote control. Wait a few seconds for the picture to appear.
Step 2
Press and hold the up arrow on the remote control. This button is located close to the middle of the remote surrounding the "Enter" button. Simultaneously press and hold the "Power" button.
Step 3
Continue to press and hold the "Power" and up-arrow buttons while the television turns itself off and then back on. Release the buttons after the set reboots.
You will need to reprogram your channels, settings, etc, but it solved this problem for me. TV Guide works fine now. Other than that issue, my 46 NX810 still looks amazing after 3 years. Beautiful picture. Beautiful TV.
I hope this helps. Good luck,
Jon
•Sony XBR-65X930D 4K HDR TV
•Sony UBP-X800 UHD Blu-ray player
•Sony STR-DA5800ES A/V Amp
•NHT SuperOne (Frt L+R) + NHT SuperCenter (Ctr)
•NHT SuperZero (Frt Height L+R)(Sur L+R)
•NHT SW-2P with NHT MA-1 mono Amp (Sub)
Lippertize is offline
post #6617 of 6689 Old 08-16-2014, 09:58 AM
friendlyviper's Avatar
SO now Sony, DirecTV and Imax are no longer supporting the 3D channel. Would have been nice to have had all the 3D movies that have come out play on that Channel. Maybe then the viewership would have been higher.............. Just sayin.......
Knowledge is free.
libenter festum super illos qui imperarent nobis.     The Addams Family
friendlyviper is offline
post #6618 of 6689 Old 08-18-2014, 07:17 AM
agni1's Avatar
Thank you. I have called local technician to open the back cover. Problem was with main board, I have purchased at shopjimmy and replaced. It is working fine.
agni1 is offline
post #6619 of 6689 Old 08-18-2014, 11:47 AM
BriS2K's Avatar
Sony's monolithic is aesthetically the best looking tv of all time...they needs to bring it back in their new sets.
I'm planning to upgrade to the Sharp 80" but man their designs really have much to desire...
Sony 75W850C 1080p LED
Pioneer Kuro 5010FD 1080p plasma
BriS2K is offline
post #6620 of 6689 Old 08-22-2014, 08:20 AM
shdwghst457's Avatar
Liked: 0
Is the stand model SU46NX1? I bought that for my 46NX810 but it doesn't at all line up with the TV; I deduced that it was only for the NX800 rather than the 810. Sucks, I was really excited to have that stand. I think it's still in my garage, if there's a way to make it work. It did nick the bottom of the front of my beautiful monolithic surface though, was never thrilled about that. Constant reminder.
shdwghst457 is offline
post #6621 of 6689 Old 09-14-2014, 07:11 PM
TallPaul7's Avatar
THks
my NX810 is still going great. remember you have to do preventative maintenance to keep these TV's trouble free. I talked to a guy who repairs these and he says the main problem is dust accumulating on the inside. Every year or so you have to take off the back and vacuum it out. I know its a PITA to take the back off. I posted the link to the service manual to show how to do it in this thread. If your TV malfunctions more than likely its the main board. Also check the power board for bulging caps. If you are handy with a multimeter the service manual tells what voltages the power board are suppose to put out
TallPaul7 is offline
post #6622 of 6689 Old 09-18-2014, 12:21 PM
djbluemax1's Avatar
Quoted: 54 Post(s)
Liked: 300
Where can we find the service manual?
Max
post #6623 of 6689 Old 09-18-2014, 07:38 PM
TallPaul7's Avatar
post #6624 of 6689 Old 10-02-2014, 02:03 PM
joe01880's Avatar
Quoted: 34 Post(s)
THks
My 46NX810 is working great. It's still got one of the best PQ I have ever seen on a TV. I did notice we just got an update. It's now Pkg 5.054 I haven't noted any real changes in anything.
I still use my TV's 3D capabilities, I buy almost every new 3D offering available. I just added "Transformers, Age of Extinction" and "Captain America, Winter Solider" to my collection.
Tron and World War Z are must see's on these TV's especially if you have a nice sound system.
I miss Tribune
joe01880 is online now
post #6625 of 6689 Old 11-06-2014, 07:56 PM
TallPaul7's Avatar
the latest 5.054 update seems to be some copy protection crap. now certain mp3's I bought off iTunes won't play from a flash drive. but they play fine through my Panasonic blu-ray player
post #6626 of 6689 Old 11-23-2014, 06:34 AM
Liked: 0
3D Inconsistencies
I recently bought a Bravia KDLNX810 and some 3D Blu-rays look great, and others have ghosting/crosstalk issues that make them unwatchable.
I'm using a Sony TMR-BR100 3D Sync Transmitter, and I've tried with three different types of 3D glasses.
Sony TDG-BR250/B
PlayStation 3 3D Glasses
XPAND X105-IR-X1
The Sony TDG-BR250/B's were pretty bad since they're not polarized and crosstalk would really be bad if you tilted your head. The Playstation 3 glasses were pretty good until my dog got a hold of them, and now the XPAND seem to work great for a few movies, but not others.
I'm using a Son BDP-S590 Blu-ray Player and all of my software on the TV seems to be up to date.
The Lego Movie and Transformers: Age of Extinction look great, but Brave, Titanic and IMAX: Space Station have so much ghosting/crosstalk, they're unwatchable. I've tried adjusting pretty much all of the settings on the TV, including the 3d Depth Adjustment. Sometimes setting it to -1 helps a bit for certain, but with Brave, anytime there's something in the background that's black, white and/or gray, the ghosting is awful.
Thanks for any help in advance, but does anyone have any suggestions?
Baltimore514 is offline
post #6627 of 6689 Old 11-30-2014, 10:48 AM
TallPaul7's Avatar
buy another set of the PlayStation glasses and get rid of the dog
post #6628 of 6689 Old 12-08-2014, 12:39 PM
mattdub1's Avatar
Quoted: 166 Post(s)
Can anyone tell me if they have a gap between the glass panel and the plastic back cover that's slightly larger near the right rear controls? I noticed the gap seems so be bigger here and there are 3 black sticky things in the gap. Pic attached
You can see the black sticky stuff in the middle of the vertical silver line in the gap.
ID:	408969   Click image for larger version
mattdub1 is offline
post #6629 of 6689 Old 12-17-2014, 06:06 AM
mattdub1's Avatar
Quoted: 166 Post(s)
Anybody?
mattdub1 is offline
post #6630 of 6689 Old 01-01-2015, 09:58 AM
joe01880's Avatar
Quoted: 34 Post(s)
Sometime over the last few weeks we got another Firmware update. My NX now shows us on PKG5.060AAS.
I have noticed a few additions under Video and everything is loading MUCH faster than before this update. I think that's a very good thing and also a great thing that 3 years out Sony is still supporting Firmware updates for this model TV.
Interestingly, the Drivers website at Sony only shows the last update being PKG5.054AAS so .060 must have been very new. So far the only thing I have noticed are onboard apps such as Amazon are loading a whole lot faster, Netflix looks to have a new design as well, maybe YouTube too. I don't use the onboard apps much as I have a TiVo Roamio Pro and mostly use that or my Roku3.
Let me know if y'all notice anything new or different please.
The "Insert Link" feature does not seem to be working so if you want to go to the 46NX810 drivers page here's the address;
http://esupport.sony.com/US/p/model-...d#/downloadTab
I miss Tribune
Reply LCD Flat Panel Displays
Sony Bravia Kdl60nx810 60 Inch 1080p 240 Hz 3d Ready Led Hdtv Black , Sony Bravia Kdl55nx810 55 Inch 1080p 240 Hz 3d Ready Led Hdtv , Sony Bravia Kdl46nx810 46 Inch 1080p 240 Hz 3d Ready Led Hdtv Black , Sony Bravia Xbr52hx909 52 Lcd Tv Direct Led , Sony 60 Inch 3d Led Hdtv Xbr60lx900
