Official Sony Bravia KDL NX810 owners' thread (60NX810, 55NX810, 46NX810) - Page 222 - AVS | Home Theater Discussions And Reviews
AVS | Home Theater Discussions And Reviews > Display Devices > LCD Flat Panel Displays > Official Sony Bravia KDL NX810 owners' thread (60NX810, 55NX810, 46NX810)
Vidop's Avatar Vidop
12:57 PM Liked: 20
post #6631 of 6652
01-01-2015 | Posts: 321
Originally Posted by mattdub1 View Post
Anybody?
My NX810 has that gap. But, it is VERY TINY. I did not even notice it until I saw this posting.
mattdub1's Avatar mattdub1
03:56 PM Liked: 12
post #6632 of 6652
01-01-2015 | Posts: 133
So is the gap on yours slightly larger on the bottom right corner near the power button? And are you able to see that black bar in the crack in good lighting like my pic shows? Thanks
12:57 PM Liked: 20
post #6633 of 6652
01-02-2015 | Posts: 321
On the right side (power button side), the gap is hardly even 1/16". With BRIGHT lighting, I can see no black bars. On the left side, the gap is also as tiny. But, at the bottom corner, this tiny gap narrows to be absolutely GONE. No gap at all. BTW-the model I have is the 55" version, if that makes any difference.
10:37 PM Liked: 12
post #6634 of 6652
01-02-2015 | Posts: 133
Hmm strange that no one else has this same gap. Thanks for checking. I also have the 55 inch. If anyone else wants to chime in that would be great. Not sure if I'm the only one that has this or if its cause for concern
12:43 PM Liked: 20
post #6635 of 6652
01-03-2015 | Posts: 321
With the PM I just sent you, it appears the "insert image" command doesn't like to attach my photo. I'll try sending it through this forum and see if it works. If it doesn't, let me know what I'm doing wrong/the right way to attach it.
[IMG]gap3a.jpg[/IMG]
06:59 AM Liked: 12
post #6636 of 6652
01-09-2015 | Posts: 133
Hmm yeah the pic isn't coming through still for whatever reason. I'm not sure what the correct steps would be other than attaching the pic..
Blaizon's Avatar Blaizon
12:17 AM Liked: 10
post #6637 of 6652
01-10-2015 | Posts: 16
Originally Posted by joe01880 View Post
Sometime over the last few weeks we got another Firmware update. My NX now shows us on PKG5.060AAS.
I have noticed a few additions under Video and everything is loading MUCH faster than before this update. I think that's a very good thing and also a great thing that 3 years out Sony is still supporting Firmware updates for this model TV.
Interestingly, the Drivers website at Sony only shows the last update being PKG5.054AAS so .060 must have been very new. So far the only thing I have noticed are onboard apps such as Amazon are loading a whole lot faster, Netflix looks to have a new design as well, maybe YouTube too. I don't use the onboard apps much as I have a TiVo Roamio Pro and mostly use that or my Roku3.
Let me know if y'all notice anything new or different please.
The "Insert Link" feature does not seem to be working so if you want to go to the 46NX810 drivers page here's the address;
http://esupport.sony.com/US/p/model-...d#/downloadTab
I'm on fw 060AAS also, but my Netflix interface is the same archaic version as what came with my tv 3 years ago (KDL-55nx810). Can you take a pic of what your Netflix interface looks like?
miggonzmo
09:16 AM Liked: 0
post #6638 of 6652
01-11-2015 | Posts: 1
Hello everyone, I hope you guys are having a fantastic 2015 until now.
I need help with my KDL-60NX810. Here is the problem, the color blue in my TV has a purplish cast on every source (PS4, PS3, PC, using HDMI cable). I have tried every combination of settings with the TV, even playing around with the White Balance and didn't get any positive result.
Has anyone experience this issue before?, is there a fix? or it is just the way blue looks in this TV, I would really appreciate any kind of help.
Thanks in advance.
joe01880's Avatar joe01880
09:59 AM Liked: 11
post #6639 of 6652
01-11-2015 | Posts: 572
Perhaps I am remembering the icon as being different. I dont use the tv apps much. Wasn't the Netflix icon red with white lettering, and now it's white with red lettering? It loaded in 3 seconds where before it took much longer, same with You Tube, 3 seconds.
Sent from my SPH-L720T using Tapatalk
TallPaul7's Avatar TallPaul7
05:54 PM Liked: 11
post #6640 of 6652
01-22-2015 | Posts: 11
Can anyone tell me if they have a gap between the glass panel and the plastic back cover that's slightly larger near the right rear controls? I noticed the gap seems so be bigger here and there are 3 black sticky things in the gap. Pic attached
You can see the black sticky stuff in the middle of the vertical silver line in the gap.
its suppose to be that way. those sticky things are cushions for the glass so it doesn't crack
06:26 PM Liked: 11
post #6641 of 6652
after 3 years the TV did its first reboot for no reason. that means the main board is starting to go. while I'm in there guess I'll replace the capacitors on the power board. main board is $69 http://www.shopjimmy.com/sony-a-1788...buht-board.htm If your TV reboots for no reason more than likely its the main board
07:04 PM Liked: 12
post #6642 of 6652
01-22-2015 | Posts: 133
Thanks for your reply. If that's the case and they are a cushion, then I'm wondering why they are only visible on the lower right near the power switch? Thanks
RVD26's Avatar RVD26
09:10 PM Liked: 12
post #6643 of 6652
01-22-2015 | Posts: 774
My 55NX810 is still holding up well for the most part.
Picture still looks good, never used 3D so I can't comment on that.
The only issue I've had is that occasionally the TV will switch to TV speakers (from external surround speakers) on its own.
Gets kind of annoying at times.
Anyone else experienced this?
09:14 PM Liked: 12
post #6644 of 6652
Might be something in your settings I had this issue until I switched it to fixed source I think. I'd have to check my settings to know for sure which one it was
09:40 PM Liked: 12
post #6645 of 6652
Let me know what the setting is I need to change.
Other than that issue, this is the perfect TV for me right now.
01:25 PM Liked: 12
post #6646 of 6652
01-29-2015 | Posts: 133
Does it happen with a particular source? Are you using HDMI arc or an optical cable to send the sound to your receiver?
01:43 PM Liked: 12
post #6647 of 6652
01-29-2015 | Posts: 774
It happens periodically when I turn the TV (DirecTV box).
Everything is hooked up via HDMI.
Not sure if I am using HDMI arc (not quite sure even what that is).
EDIT: I just changed the option to turn OFF HDMI-control devices.
I'm guessing this is the option?
04:24 PM Liked: 12
post #6648 of 6652
I would try the HDMI control setting to off and see if that helps.
06:18 PM Liked: 12
post #6649 of 6652
I just checked and I have audio out set to fixed in the TV settings. Not sure that will help though as the setting isn't what I thought it was before. Speakers are set to audio system. I would bet it has something to do with the receiver settings. Did turning HDMI control to off fix it?
08:45 AM Liked: 12
post #6650 of 6652
01-30-2015 | Posts: 133
Can anyone comment whether its best to set auto display area to off and full pixel to on for all sources? I noticed with the auto display area turned on it crops part of the pic on my Xbox 360. But it turns on full pixel automatically when I pop a blue ray in and doesn't crop the picture. Why would the auto setting crop the pic on the 360 when its a 1080 source?
03:22 PM Liked: 12
post #6651 of 6652
01-30-2015 | Posts: 774
Not sure if it's been fixed yet.
The problem only happens periodically.
I'll keep checking to see if it happens again.
So far, so good.
07:51 PM Liked: 11
post #6652 of 6652
Today | Posts: 572
The reboot could also have been the tv firmware received an update. Check to see if you got an update. If it did, well there ya go. If it didn't and it doesn't happen again maybe you had a power surge or something.
I keep my receiver hooked up to a, battery back up/surge protector. Better safe than sorry.
Tags: Sony Bravia Kdl60nx810 60 Inch 1080p 240 Hz 3d Ready Led Hdtv Black , Sony Bravia Kdl55nx810 55 Inch 1080p 240 Hz 3d Ready Led Hdtv , Sony Bravia Kdl46nx810 46 Inch 1080p 240 Hz 3d Ready Led Hdtv Black , Sony Bravia Xbr52hx909 52 Lcd Tv Direct Led , Sony 60 Inch 3d Led Hdtv Xbr60lx900
Reply LCD Flat Panel Displays
Subscribe to this Thread
Powered by vBadvanced CMPS v3.2.3
