I need your advice on PC Richards Sony exchange offer is good - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 10-13-2010, 09:01 AM - Thread Starter
DyanCB's Avatar
I own a SONY KDL46XBR5. The screen needs replacing but the part is no longer available. Luckily I did buy the extended warranty. PC Richards is offering me the SONY KDL46EX710 as a replacement.
Is this a reasonable replacement? Now that I need a new TV I started doing some research and there are features on the KDL46NX800 that I like.
Of course, my BR5 is 3 years old so there have been advances since then. But, I spent over 3K for this TV and don't want to settle for less than I have to.
Please know, I am not a gamer. 3D does not mean much to me in higher versions of the TV, ie the HX series.
I would appreciate any advice you can provide. In advance, thanks for your help.
DyanCB is offline
post #2 of 4 Old 10-13-2010, 02:22 PM
detector19's Avatar
If your not in to 3D I'd say the Sony KDL=46NX800 is the way to go...
http://www.sonystyle.com/webapp/wcs/...52921666077681
Sony KDL46HX701
Sony 32S5100
Sony 120 GB PS3 slim
Sony-BDP-N460
Denon- AVR-591
Harmony 880
detector19 is offline
post #3 of 4 Old 10-13-2010, 02:33 PM
loudog2's Avatar
Quoted: 259 Post(s)
Liked: 198
If your looking for equal price paid then go for the 55nx810 or the 46HX909. Both have 3D, but they are going for $3000, which is equal to what you paid for your original.
Sony 940C*Sony HX909*Samsung K8500*Yamaha 3050*klipsch front RP-280's*rear RF-3's*center RP-450C*Sides RP-280's*front heights RP-140's*overhead 5650cii's*SVS-PB2000x4*emotiva XPA-5*Yamaha YSP-1600 sound bar*Sony HT-CT370 sound bar
loudog2 is offline
post #4 of 4 Old 10-29-2010, 06:28 PM
Davenj80's Avatar
Hi, I'm in the same boat as you. I have a SONY KDL46XBR4 and the screen started getting distorted on the right side and luckily I also had purchased the extended warranty through PC Richard. I have them coming to look at it next week and I was wondering how did you make out with your exchange, did you get the one you wanted? If they offer me an exchange for a new one I'm looking at the Sony KDL-52NX800 since its $1899 and I paid $2299 for my XBR4 back in 2007 so I'm hoping that they will go for that. I think that is a fair exchange since the XBR's were high models at the time and the new NX's are comparable. Please let me know how it worked out for you.....Thanks!
Davenj80 is offline
Reply LCD Flat Panel Displays
