Official Sony Internet TV (NSX-DDGT1) Thread - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 39 Old 04-07-2012, 08:55 PM
shibez's Avatar
Quoted: 32 Post(s)
i plugged in the cnet settings....havent used the tv with a bluray yet just OTA HD and Standard Cable. basically same settings with a few tweaks sometimes i use warm 1.
Picture Mode Cinema
--Detailed settings sub-menu
Backlight: 5
Picture: 71
Brightness: 57
Color: 58
Hue: 0
Color Temperature: Warm 2
Sharpness: 0
Noise Reduction: Auto(because im not using a cable box)
MPEG Noise Reduction: Off
CineMotion: Auto
--Advanced settings
Black Corrector: Off
Adv. Contrast Enhancer: Low
Gamma: -1
Live Color: Off
--White Balance
R-Gain: 0
G-Gain: 0
B-Gain: -19
R-Bias: 0
G-Bias: 0
B-Bias: 2
--Screen adjustments sub-menu--
Wide Mode: Full
Auto Wide: Off
4:3 Default: Off [grayed out]
Display Area:
Auto setting: un-checked
Manual setting: Full pixel
Screen position: [grayed out]
Vertical size: [grayed out]
Proud Owner of 55EG9100
shibez is offline
post #32 of 39 Old 04-08-2012, 11:33 AM
walford's Avatar
Your local HD stations available OTA should also be avalable with your standard cable since it is your TV tuner that determines what unencrypted HD channels you can tune.
If a HD LCD/LED TV does not list the refresh rate as 120Hz, or 240Hz in the specs then it is 60Hz in North America.
walford is offline
post #33 of 39 Old 04-11-2012, 07:48 PM
shibez's Avatar
Quoted: 32 Post(s)
I am pleased with these settings...FANTASTIC on HD and even good on SD content
Picture Mode Cinema
Backlight: 10
Picture: 77
Brightness: 53
Color: 50
Hue: 0
Sharpness: 5
Noise Reduction: Auto(because im not using a cable box) Off for bluray and dig cable/sat
CineMotion: Auto
--Advanced settings
Gamma: -1
Live Color: Off
--White Balance
R-Gain: 0
G-Gain: 0
B-Gain: -19
R-Bias: 0
G-Bias: 0
B-Bias: 3
Wide Mode: Full
Auto Wide: Off
Display Area:
shibez is offline
post #34 of 39 Old 04-27-2012, 03:57 PM
badwilly's Avatar
Since the TV updated to the newest software it now won't update apps. When I go into Google Play and then My Apps. I have apps that need updating. I tell it to update and I get a message that "com.android.vending" has stopped unexpectedly. It forces me to select the "Force Stop" button. Same thing happens if I try to download an app. Any ideas? I have power failed the TV but no fix. I have the Sony 32" Google TV.
Cheers
Willy
badwilly is offline
post #35 of 39 Old 05-03-2012, 07:04 PM
shibez's Avatar
Quoted: 32 Post(s)
i would do a factory reset on the tv.
shibez is offline
post #36 of 39 Old 05-03-2012, 07:26 PM
walford's Avatar
Did Sony automatically update the software on your TV.? If not are you sure that the update you applied applies to your TV's serial number since not all updates to a model apply to all serial numbers of the model.
walford is offline
post #37 of 39 Old 05-04-2012, 03:15 PM
badwilly's Avatar
The TV automatically one day said a update was available. I'm assuming it must be going to Sony for the update. Any idea how to do a factory reset?
Cheers
Willy
badwilly is offline
post #38 of 39 Old 05-09-2012, 07:09 AM
shibez's Avatar
Quoted: 32 Post(s)
Goto settings then goto Privacy and safety then goto Factory reset.
shibez is offline
post #39 of 39 Old 09-26-2012, 10:21 AM
jimsfield's Avatar
Does anyone know how to change the User Agent to Custom Agent? I found it in the menu but don't know how to enter the new code. I'm trying to change it so I can watch HULU.
jimsfield is offline
Reply LCD Flat Panel Displays
