Vizio xvt3d554sv - Page 34 - AVS Forum | Home Theater Discussions And Reviews
post #991 of 1675 Old 08-14-2011, 06:31 AM
Jim Noyd's Avatar
Originally Posted by WoodRow13 View Post
bump
set Adaptive Luma = Off
-Jim Noyd
Noyd Communications Inc.
Representing VIZIO, DVDO,
Luxury Technology Show,
Kimber Kable, Krell
Jim Noyd is offline
post #992 of 1675 Old 08-14-2011, 08:50 AM
MacdaddyPS's Avatar
How can u watch anything with a backlight setting of 50??
Are u watching in a pre Jurassic cave somewhere 40 miles below the surface where no light from the surface reaches down?
Got my backlight on 80 something.
50? Really?
MacdaddyPS is offline
post #993 of 1675 Old 08-14-2011, 09:26 AM
heisman's Avatar
50? Really?
Don't forget your sunglasses and your SPF 15.
heisman is offline
post #994 of 1675 Old 08-14-2011, 09:37 AM
WoodRow13's Avatar
50? Really?
I was just going off of cesdaniels settings. Does anyone else care to post their settings? Thanks
WoodRow13 is offline
post #995 of 1675 Old 08-14-2011, 08:57 PM
kkrueger's Avatar
Originally Posted by toolwarrior View Post
This may or may not help diagnose this problem. I have had my 554 for 3 weeks now and it has never shut down like this. The one thing I never did that most of you probably have is allow the TV to sync up with my WiFi. I wanted to add that parameter about a month after having the set to make sure that there were no auto shut-downs without the ability for the apps to come into play.
I didn't connect mine wirelessly, either. It is connected via ethernet, though, and I did fiddle around with the apps quite a bit when I first got the TV. No shutdowns so far since I pitched all of the apps.
kkrueger is offline
post #996 of 1675 Old 08-14-2011, 10:17 PM
toolwarrior's Avatar
Originally Posted by kkrueger View Post
I didn't connect my wirelessly, either. It is connected via ethernet, though, and I did fiddle around with the apps quite a bit when I first got the TV. No shutdowns so far since I pitched all of the apps.
I just brought the wireless online today. The only one I have tried to use is Facebook. Pretty limited. I was disappointed. Get this..... the TV paused and downloaded 33 updates. Wonder what the heck that was.
kkrueger, who do you have your HD service with?
toolwarrior is offline
post #997 of 1675 Old 08-14-2011, 10:47 PM
kkrueger's Avatar
I get my HD over the air through a Home Theater PC. No cable or satellite. Besides that I have a Roku 2 for Netflix and Amazon streaming and a Panasonic BDT110 for Blu-Ray.
kkrueger is offline
post #998 of 1675 Old 08-15-2011, 05:05 AM
WoodRow13's Avatar
csedaniel
Thanks for all your work on this TV. Few questions...
Are these settings you gave for regular TV [all day] or just for movies?
I'm using the setting below.
It seems when I watch a light (white) background it looks a little fuzzy. And blacks letters are also fuzzy.
Darker backgrounds look great. I mainly watch sports so would you recommend these setting or something different? I noticed they have specific settings for football, baseball, etc. Have you ever tested those settings? Or should I just use football settings for football then baseball for baseball etc.? The main issue is the white background needs to be better. Thanks for you help.
Settings:
Movie
Backlight = 50
Brightness = 45
Contrast = 50
Color = 39
Tint = 0
Sharpness = 5
Color Temperature = Normal
Red Gain = 130
Green Gain = 120
Blue Gain = 123
Red Offset = 111
Green Offset = 110
Blue Offset 131
Noise Reduction = Off
Color Enhancement = Off
Adaptive Luma = Low
Smart Dimming = On
Ambient Light Senor = Off
Can anybody post there regular TV settings.
post #999 of 1675 Old 08-15-2011, 08:19 PM
kkrueger's Avatar
Is anyone here using their XVT with the Panasonic BDT110 Blu-Ray player? Playing 3D content works fine, but if I try the 2D to 3D conversion mode, the screen goes blank and the TV says "No Input". I bypassed my Onkyo receiver to verify that it wasn't part of the problem. My BDT110 firmware is 1.68 and my XVT3D474SV firmware is VIZIO_XP 1.28.0.2. If someone with the same configuration could report their results with 2D to 3D conversion, I would appreciate it.
kkrueger is offline
post #1000 of 1675 Old 08-16-2011, 06:08 AM
pcanman79's Avatar
Just wanted to let everyone know that the upgrade is still being pushed out, I received it yesterday. Can confirm Blockbuster, netflix upgrade, and usb media (Pictures and music I believe).
pcanman79 is offline
post #1001 of 1675 Old 08-16-2011, 06:24 AM
willybguy's Avatar
what about audio return channel (ARC) and did the upgrade interfere with your WiFi connection? Are you still able to connect via WiFi?
willybguy is offline
post #1002 of 1675 Old 08-16-2011, 07:47 AM
SurfingMatt27's Avatar
Quoted: 13 Post(s)
What about the 47" xvt3d474sv, is the upgrade available with that too now?
SurfingMatt27 is offline
post #1003 of 1675 Old 08-16-2011, 08:01 AM
chico_pr's Avatar
Hi guys, I'm considering the XVT3d474sv. I'd like to know the good and the bad of this tv.
I'm more concerned in 2d image quality and clouding/flashlighting.
I appreciate your honest opinion. Thanks!
chico_pr is offline
post #1004 of 1675 Old 08-16-2011, 09:55 AM
pcanman79's Avatar
I do not use ARC so I cannot attest to that, but my WIFI connection is rock steady with netflix.
post #1005 of 1675 Old 08-16-2011, 11:18 AM
lancer1991's Avatar
Is all I need to do is register my TV on the Vizio site for the upgrade to eventually make it out? I went there last night and did the registration, just didn't know if there was something else that was suppose to be done. I'm hard wired to my network.
lancer1991 is offline
post #1006 of 1675 Old 08-16-2011, 12:48 PM
Burnerbum's Avatar
I wonder what Vizio is doing. This weekend I had 34 new widgets on the 553, giving it a total of 20 pages of widgets to choose from including Blockbuster, Hulu Plus, Showtime, etc.
On the 554 there are 9 pages of widgets. They are NOT updating anything on this set.
Burnerbum is offline
post #1007 of 1675 Old 08-16-2011, 01:11 PM
willybguy's Avatar
Vizio has said the update is organized by serial number. When they first began pushing some owners reported a WiFi bug. It's disappointing to hear the 553 has double the number of widgets and the 554 upgrade seems sporadic at best.
post #1008 of 1675 Old 08-16-2011, 06:07 PM
Burnerbum's Avatar
The widgets don't come through with the FW, they are just added so I don't understand why the 554 isn't getting them. Right now the only one I use is Netflix but I'm looking for a replacement for it. So, other than Video Streaming I don't use them anyway. It's just the fact that it seems like the 554 has been forgotten as far as support. If it wasn't for the Glossy Screen I wouldn't have bought it. The 553 is great but I like the other screen. I've tried the 3D and I'm not impressed, with any of the sets.
post #1009 of 1675 Old 08-16-2011, 07:19 PM
Not sure about the 47. I got the 55 and I really like it. I kind of stole it for the price IMHO. I also got a couple pairs of the 3d glasses for free. I am pretty picky and I have not seen any clouding or flashlighting, but then I would not expect this with a full array LED backlight. Good luck. I don't think you would be disappointed if you got the 47 at all.
post #1010 of 1675 Old 08-16-2011, 08:19 PM
lancer1991's Avatar
Slightly OT, but where and how does everyone store these non-foldable Vizio 3D glasses? I snagged 4 from Sam's and may get another 2, but didn't know they didn't fold up until after opening package.
post #1011 of 1675 Old 08-16-2011, 09:50 PM
ReSultZ's Avatar
Quoted: 95 Post(s)
Liked: 47
Hooked the tv up to my wifi network and its been a few days...and no update I'm about to say **** it as this tv is very buggy when hooked to the net.
ReSultZ is offline
post #1012 of 1675 Old 08-17-2011, 06:32 AM
MacdaddyPS's Avatar
After having suffered with a lot of video stutter/frame dropping, I finally stopped it by turning off smooth motion effect and film detection mode to off.
But I liked using some smooth motion effect!-Damn Damn!
You guys think I have something defective in the set? This is my second one, first was returned for random shutdowns.
It's always something in my quest for semi
Perfection.
post #1013 of 1675 Old 08-17-2011, 07:33 AM
Quoted: 13 Post(s)
Does this tv 47" or 55" support 1:1 pixel mapping with no overscan? I ask because i just got the 47" version delivered today this morning at around 8:30am and upon reading the owners manual nothing of any refferance to 1:1 pixel mapping turned up.
I really hope it has it otherwise this brand new tv is going back and i'll look into another brand because i hate overscan.
post #1014 of 1675 Old 08-17-2011, 10:46 AM
naustin's Avatar
Quoted: 418 Post(s)
Liked: 190
Dunno.... since there are no official 554 Reviews. The 553 is very similar so check out some of those online reviews. Good luck
naustin is online now
post #1015 of 1675 Old 08-17-2011, 12:15 PM
kkrueger's Avatar
I hooked my 47" up to my HTPC and I didn't have to make any adjustments to see the full desktop. It seemed to fit perfectly. With my 5 year old 37" Sharp, I had to adjust my desktop size to avoid overscan.
kkrueger is offline
post #1016 of 1675 Old 08-17-2011, 02:33 PM
Quoted: 13 Post(s)
nevermind i found it, for 1:1 pixel mapping it seems "Normal" is the 1:1 mode and "Wide" is the typical 2-5% overscan.
all is well now .
post #1017 of 1675 Old 08-17-2011, 03:26 PM
willybguy's Avatar
Several other owners have reported new widgets only come with new firmware; I'm not clear on how new widgets would "appear" without a FW upgrade - they're not native software, they have to be added somehow.
post #1018 of 1675 Old 08-17-2011, 04:44 PM
Burnerbum's Avatar
Well, I keep getting new Widgets on the 553 and no new FW updates. It just says when I bring up the widgets X number have been added. I'm sure if they were sending a new FW the Version no. would change.
post #1019 of 1675 Old 08-17-2011, 07:32 PM
Perfection.
Mac - I received a response back from Directv on this issue. I am not sure what to make of it because my original request was to comment on the issue with respect to 2D not 3D, but note the response:
Subject
Directv compatibility with Vizio XVT3D554
Discussion Thread
Response Via Email(Barbara R (ID 402850)) - 08/16/2011 01:24 PM
Dear Mr. Beacon,
Thank you for writing. I understand your concerns with the compatibility of our service with a specific model TV. I can certainly address your concerns for this today.
Based on the information you provided, I have researched this and was unable to find any known issues between a Vizio XVT3D554 TV and our services. With the 2D and 3D programming available this is something that would be based on settings or software on the TV. The specifics for this service available with us is available at directv.com/3d. This provides details on how the service is provided and the recommended compatible TV's for this service.
Our standard programming as well as high definition service is provided as an all digital signal for our customers. This provides an exceptional viewing experience for all programming genre's to fill every need for your viewing. We do have some great options available for customers signing up with service at this time. We would like to discuss the many options with you so we can get you set up to begin enjoying the great service we have to offer. Please call 1-800-347-3288 and speak with one of our Direct Sales specialists.
Thank you again for writing Mr. Beacon.
Sincerely,
DIRECTV Resolution Specialist
post #1020 of 1675 Old 08-18-2011, 06:26 AM
Burnerbum's Avatar
Sincerely,
Sounds more like a canned Sales Pitch to me than an answer to your question.
What DVR do you have? I have the HR22 and as I occasionally get a little stuttering it's not enough to cause a problem. It's only on certain SD programming. My 553 also has it occasionally too but as I said not frequent and not a problem.
I do get blocking on some of the HD channels but that is the signal not the TV. Is there a certain channel that you get it and particular program. If so, I would be glad to tune to it and see if I have a problem.
My stuttering was much worse when I had Comcast Cable so it must be the signal being sent to us.
My settings are:
Smooth Motion High
Real Cinema Smooth
Noise Reduction Off
Film Mode Auto
Reply LCD Flat Panel Displays
Vizio , Vizio Xvt3d554sv 55 Inch 1080p 480hz 3d Led Hdtv With Full Array Truled Smart Dimming And Vizio Inte , Led Hdtv
