Why Am I Still Getting Motion Blur On 120hz - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 11-27-2010, 11:38 AM - Thread Starter
Donovan_McSwaGG's Avatar
So I have this model tv right here (http://www.amazon.com/Sony-BRAVIA-50...0886302&sr=8-1)
I'm noticing when I play games on my PS3 (connected via hdmi/Comcast also connected hdmi) that Im getting motion blur,When watching TV I don't notice any motion blur at all
Should I be worried that its an issue with the TV?
Ive had many problems with a previous model of Sony Bravia that after 3 different problems with that TV concerning an audio issue they finally sent me a different model which happens to be the one listed above and would hate to have to call again and say theres an issue when theres really not.
Donovan_McSwaGG is offline
post #2 of 12 Old 11-27-2010, 04:30 PM
walford's Avatar
Does your TV have a game mode? If yes are you using it?
walford is offline
post #3 of 12 Old 11-27-2010, 06:38 PM - Thread Starter
Yes sir......They have two Game modes-Standard & Original... Occurs in both..
Best way to describe is like this, In a FPS such as COD Black ops if Im facing a light object with a black/dark backround and I have the character jump the light and dark object will "smear" a little
Or another example is with NHL 11... When playing your guy has a red dimaond over his head ala sims......Well this bright red object will trail as you skate on the bright white ice...
Sorry if none of that makes sense but its the most accurate way to describe it
post #4 of 12 Old 11-28-2010, 05:25 AM
walford's Avatar
You are getting ghosting due to the high contrast not motion blur.
What are your backlight and brightness settings? If not about 50% try lowering them.
walford is offline
post #5 of 12 Old 11-28-2010, 05:39 AM
VarmintCong's Avatar
Doesn't game mode disable motion interpolation, which is what eliminates blur on LCDs?
VarmintCong is offline
post #6 of 12 Old 11-28-2010, 11:36 AM - Thread Starter
Might be a dumb question but what's the difference between motion blur and ghosting??
Is motion blur more of a smear look abs ghosting is a trailing effect.. I will try lowering brightness and contrast when I get home
post #7 of 12 Old 11-28-2010, 11:56 AM
MJDDawg's Avatar
How are your PS3's video output and display settings set up?
Under your "Display Settings" on the XMB main screen, for video output try selecting all options (480p, 720p, 1080i and 1080p) to ensure your games are being output at their native resolution.
Other settings you can fart around with: RGB Full Range on my set-up is set to "Full", but I like deep blacks. You could set to "Limited" to lighten it up. Super White is set to "On", and Deep Color is set to "Automatic". Experiment with these last ones till you find the settings you like.
MJDDawg is offline
post #8 of 12 Old 11-28-2010, 12:50 PM
walford's Avatar
Yes, And ghosting can be caused when the an exteamly bright part of a scene for one eye crosstalks with an image for the other eye when the shutter is not compeltly opaque for the closed eye. So on an LCD TV reducing the backlighting and /or brightness setting can reduce this. Reducing the contrast setting does not normally make any difference.
walford is offline
post #9 of 12 Old 11-28-2010, 08:38 PM - Thread Starter
So minimal ghosting on a Lcd is normal and not cause for concern then?
post #10 of 12 Old 11-28-2010, 10:50 PM
Nielo TM's Avatar
It is difficult to remove blur on LCDs due to slow pixel response and high-hold time. As walford suggested, lower the backlight to match your experiment and at night, lower it to 120/130 cd.m2.
Also, when you use Game Mode, MCFI is disabled, which means the performance of the set becomes identical to a 60Hz display.
Finally, the majority of PS3 and X360 titles have built-in blur and most of them are rendered in 30fps.
Nielo TM is offline
post #11 of 12 Old 11-28-2010, 11:03 PM
Nielo TM's Avatar
that's normal for an S-PVA pannel. Among all the LCD modes, S-PVA has the lowest pixel response (especially between light and dark tones). You just have to adopt to it.
Again its normal for S-PVA.
If you're seriously bothered by such issues, you could try A-MVA or IPS panel.
Nielo TM is offline
post #12 of 12 Old 11-28-2010, 11:06 PM
Nielo TM's Avatar
Blur is when the moving image isn't clear, which is caused by high hold time. Lowering the backlight does help to reduce to an extend.
Ghosting is caused by low pixel response and overdrive. You may notice black or white trailing behind moving objects and one set of colors bleeding into another during motion and such.
Nielo TM is offline
Reply LCD Flat Panel Displays
