Samsung Panel Version Thread - Page 38 - AVS Forum
AVS Forum > Display Devices > LCD Flat Panel Displays > Samsung Panel Version Thread
Brian-L's Avatar Brian-L
08:19 PM Liked: 10
post #1111 of 1124
12-16-2014 | Posts: 7
Originally Posted by sumguy91 View Post
According to samsungparts.com all of those are Samsung panels.
Where do you find this info on that website? I did a few searches and don't see it. I'm only interested in finding out about code UF05.
dubwoofer's Avatar dubwoofer
11:25 PM Liked: 11
post #1112 of 1124
12-16-2014 | Posts: 27
My local best buy has the UN32EH5000FXZA (32" 1080p non smart)...All boxes were version UU02, and research indicates they are Samsung panels
perka2
12:40 PM Liked: 0
post #1113 of 1124
Yesterday | Posts: 6
Can anyone help me? I messed up in the service menu and changed the TYPE setting. The label says ue46es6100wxxn version 01. I removed the backcover where the label says LE460CSM-C1. Which type should i choose in service menu?
Otto Pylot's Avatar Otto Pylot
01:06 PM Liked: 281
post #1114 of 1124
Yesterday | Posts: 7,685
Another reason to stay out of the SM. If your pq or any of the controls you are supposed to have aren't affected, I'd just leave it.
perka2
01:14 PM Liked: 0
post #1115 of 1124
I think the picture has degraded in quality otherwise everything works fine.
03:50 PM Liked: 281
post #1116 of 1124
Service Menu codes, for the most part, are set-specific. IOW, they are set at the factory based on the component tolerances, etc of the tv at time of qc. They can not be reset using the normal "reset tv" command. I'm not sure what the TYPE setting is related to. It could be just the panel but there may be other settings related to that panel which are specific. If you can find a service manual for your exact model, there may be instructions in there on what your TYPE is supposed to be and how to change it.
perka2
04:01 PM Liked: 0
post #1117 of 1124
Ok thanks have been looking for the service manual without any luck.
pilotart's Avatar pilotart
05:37 PM Liked: 59
post #1118 of 1124
Yesterday | Posts: 243
You shoud find it on this site:
http://www.servicemanuals.net/Servic...1/results.aspxhttp://www.servicemanuals.net/Servic...1/results.aspx
Download or Hard Copy or contact them if you can't pick one.
Good Luck and take great care,
Art
Tzu
05:59 PM Liked: 0
post #1119 of 1124
I purchased the UN40EH5000 on Black Friday weekend. Here's what I got from the service menu.
Version No: UF04
MFD: January 3, 2014
Type: 40A6AF1D
I was told by a Best Buy manager that Samsung doesn't make panels in the 46" model television. I don't think that's true, but I'm not an expert either so I'm open to the possibility I'm wrong.
07:05 PM Liked: 281
post #1120 of 1124
Version No: UF04
Type: 40A6AF1D
BB is clueless. I wouldn't trust anything that a salesman has to say. Black Friday deals are always suspicious imo. If you like the pq then it doesn't matter who made the panel.
Tzu
07:46 PM Liked: 0
post #1121 of 1124
That's cool, and I would tend to agree, but I'd still like to know what I paid for. I deem that type of information important or I wouldn't be here in the first place.
08:08 PM Liked: 59
post #1122 of 1124
Version No: UF04
Type: 40A6AF1D
Looks to me like Samsung made your panel, just Google:
Version No: UF04
and you will get details.
As Otto just said, it's all about how YOU LIKE IT. Settings can likely enhance your experience for you and enjoy your TV.
Art
10:07 PM Liked: 281
post #1123 of 1124
From what I've been able to determine, the price is not dependent on the panel, it's what ever they have in stock or have pre-ordered for production expectations.
perka2
01:46 PM Liked: 0
post #1124 of 1124
Today | Posts: 6
Hi again. Could anyone help identify my panel. I have a ue46es6100wxxn. Version 01. The label behind the back cover says le460csm-c1. Thanks in advance.
Tags: <<. , Samsung , Samsung Ln46a850 46 Inch 1080p 120hz Lcd Hdtv With Red Touch Of Color , Samsung Un55c6300 55 Inch Led Hdtv
Reply LCD Flat Panel Displays
Subscribe to this Thread
Powered by vBadvanced CMPS v3.2.3
