Samsung Panel Version Thread - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 118Likes
post #181 of 2036 Old 09-02-2013, 04:25 PM
Otto Pylot's Avatar
Quoted: 1356 Post(s)
Liked: 852
Originally Posted by jazzmaster221 View Post
WHAT'S AMAZING IS THAT OTA antenna on cbs and vhf hd channels has a better pic then hd cable
That's because OTA typically has less compression than cable/sat channels and thus better pq (depending on your area and all the other caveats for OTA). Very little to do with the type of panel.
Otto Pylot is offline
post #182 of 2036 Old 09-02-2013, 09:22 PM
Zaz3's Avatar
Hi, i'm from Perú. I have a problem, i bought a UN50F5500 Version No: AH02 and it came with a 1 pixel dead. The store going to change it for the same model, but are there only 2 options: Panel AH02 or CH02. Which one do i choose?
I know that the TS01 is the best panel, but that panel doesn't exist for the UN50F5500.
Greetings from Perú and thanks for the help.
Zaz3 is offline
post #183 of 2036 Old 09-03-2013, 11:16 AM
PlasmaPZ80U's Avatar
Quoted: 1961 Post(s)
Liked: 559
probably AH02 as it should be somewhat better in terms of viewing angles and blacks at those viewing angles
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Cambridge S20 Surrounds, Rythmik LV12R; PS4, Xbox One, Xfinity X1 (CI CXD01ANI)
PlasmaPZ80U is online now
post #184 of 2036 Old 09-03-2013, 09:38 PM
Zaz3's Avatar
I asked for the CH02. I hope that panel works 100%. If not i ask my money back.
Zaz3 is offline
post #185 of 2036 Old 09-07-2013, 11:14 AM
Jocelyn84's Avatar
Hi! I'm new here, just had a UN46F6300 delivered from Amazon and the model sticker says TU02 for the panel. Anyway, I'm interested if anyone has any knowledge about this panel and whether I should keep it or return it. I assume it's a Samsung, being that it starts with a "T", but thought someone else might know more. Thanks in advance smile.gif
Jocelyn84 is offline
post #186 of 2036 Old 09-07-2013, 11:52 AM
Liked: 559
TH0x and TS0x have been confirmed as Samsung panels... Txxx in general should be Samsung panels, but you may need to check the service menu home screen to be 100% sure (which requires opening and turning on the TV)
post #187 of 2036 Old 09-07-2013, 01:15 PM
Jocelyn84's Avatar
Thank You! It says 46A1AF0S and I believe the A after the 46 means it's a Samsung. I was amazed when I first turned it on and it has much better viewing angles than my last TV (LG). Anyway, I'm happy with my TV biggrin.gif
post #188 of 2036 Old 09-07-2013, 02:56 PM
Liked: 559
yeah the first letter (A in your case) indicates it's indeed a Samsung panel
one of the advantages of the Samsung panel (S-PVA) is better viewing angles vs. the other VA types (MVA based like A-MVA and S-MVA)
post #189 of 2036 Old 09-07-2013, 06:42 PM
Otto Pylot's Avatar
Liked: 852
As long as you are happy with your tv, that's really all that matters. FWIW, I have an LG with the S-IPS panel and when we bought the Samsung (S-PVA panel) for my son, and compared them side by side, the LG was noticeably better in off-axis viewing, etc. However, the Samsung did provide very nice default pq (as far as my son was concerned) so it was a good selection. The LG is calibrated, the Samsung is not (even tho that has nothing to do with off-axis viewing).
post #190 of 2036 Old 09-08-2013, 09:51 AM
Liked: 559
when you say the LG was better in terms of viewing angles, do you mean horizontally or overall?
post #191 of 2036 Old 09-08-2013, 12:33 PM
Justincase1004's Avatar
Were you able to pull the numbers from the Service menu on the NH02?
Justincase1004 is offline
post #192 of 2036 Old 09-08-2013, 12:36 PM
Originally Posted by threadl0ck View Post
Hi, first post here.
I picked up a UN50F6350 at Costco a few weeks ago, and the sticker on the box claims it is a NH-02 panel. I don't know how to tell if it's IPS, PVA, MVA, or whatever. I tried to look it up on the Sears part site, and found a listing for Samsung Model #UN50F6300AFXZA-NH02 which indicates a panel part # BN95-01098A. I can't seem to find a reference to this part number anywhere else online. (Too new, perhaps?)
This is my first flat-panel TV. So far I am very happy with it. To me, the off-axis viewing and blacks are quite acceptable. Haven't noticed any flashlighting or ghosting issues. I did adjust some of the color calibration settings, and I think the PQ is pretty good overall.
Disclaimer: I am not a certified videophile, so maybe I do not know everything to look for. If anyone wants to suggest specific things to watch out for, I will try to check those and report back.
post #193 of 2036 Old 09-08-2013, 02:13 PM
jazzmaster221's Avatar
MY panel is NH02 SM... 50plafos i'm happy with the viewing angle very slight color wash out at maximum angle ..no clouding at all
jazzmaster221 is offline
post #194 of 2036 Old 09-09-2013, 12:11 PM
threadl0ck's Avatar
I did pull those, but I don't have them with me at the moment. I'll try and retrieve them and post later.
I am very happy with the PQ on this set so far. (Disclaimer: I don't watch this TV from crazy angles.)
threadl0ck is offline
post #195 of 2036 Old 09-09-2013, 08:47 PM
Ravina's Avatar
Guys - how do you tell if the light leak is excessive. I see light shooting from the corners a lot and also the edges. What would be optimal settings to reduce that. I am afraid that my settings are causing it. Want to be sure before I exchange again.
Ravina is offline
post #196 of 2036 Old 09-13-2013, 10:56 PM
snorge's Avatar
Quoted: 154 Post(s)
Liked: 39
Hmm I just bought a UN40F6300 from Best Buy. I checked the the boxes on the floor and they were labeled either TS01 or TU02. I didn't find this page until a few minutes ago so I went with TS01 thinking it was the only Samsung panel but now I see they both are. Since TS01 has been around a long time I wonder if TU02 is a newer improved version? Hopefully not else I'll be debating on swapping it lol.
snorge is offline
post #197 of 2036 Old 09-14-2013, 10:03 AM
Otto Pylot's Avatar
Liked: 852
Just watch the tv for awhile and use it how you want to. If it meets your needs then it's a moot point.
post #198 of 2036 Old 09-14-2013, 10:36 AM
Liked: 559
it's really a roll of the dice, but that being said the difference between two Samsung panels should be much smaller than the difference between different panel makes/types altogether
post #199 of 2036 Old 09-14-2013, 10:38 AM
Liked: 559
good point, as long as there are no distracting issues or glaring flaws (that are not typical for LED-LCDs in this price range)
post #200 of 2036 Old 09-14-2013, 11:29 AM
Ravina's Avatar
I have switched 4 TVs and can not find a ts01 panel. I have tried 2 TD02 panels and tons of light leaking all along corners and edges. I'm now onto MD01 panel, is that a samsung panel? Anyone know what MD01 is? Maybe here in canada we don't has TS or US panels?
Ravina is offline
post #201 of 2036 Old 09-14-2013, 01:47 PM
Mike99's Avatar
Quoted: 133 Post(s)
Liked: 63
From what I've been reading it appears specific sizes use specific panel types. IOW a 50" my not use a Samsung panel but the 46" will. Perhaps the size that you are looking at is not made with a Samsung panel.
Mike99 is offline
post #202 of 2036 Old 09-14-2013, 03:33 PM
Ravina's Avatar
Mine is the un65f8000 (in canada). It's seems many here have the TS01.
Ravina is offline
post #203 of 2036 Old 09-14-2013, 09:14 PM
snorge's Avatar
Quoted: 154 Post(s)
Liked: 39
How is it different size tvs can be using the same panel? Does TS01 or whatever you have indicate the type of panel rather than a specific panel part?
snorge is offline
post #204 of 2036 Old 09-15-2013, 12:18 AM
Otto Pylot's Avatar
Liked: 852
TS01 indicates the type of panel, not the part number. Samsung, and other mfrs, use an identification system to specify the type of panel used in their tv's. Panels used depend on availability of specific panels in specific sizes. For example, TS01 for Samsung indicates that the panel used is the S-PVA panel which is made by Samsung. LG, on the other hand, used S-IPS panels in some of their tv which was indicated (at least when I bought mine) by a "W", which was the fourth letter in the complete product code. It can be very daunting to figure out the panel type used in tv's by any mfr unless you can "decode" the product codes, knowing that not all panel types are available for all sizes of tv's.
snorge likes this.
post #205 of 2036 Old 09-15-2013, 12:22 AM
snorge's Avatar
Quoted: 154 Post(s)
Liked: 39
Okay thanks it would be interesting to know what the new TU02 panel is.
snorge is offline
post #206 of 2036 Old 09-15-2013, 09:40 AM
Jocelyn84's Avatar
You saw my other post as well, right? Service menu shows 46A1AF0S, making it a Samsung panel.
Link - http://www.avsforum.com/t/1294904/samsung-panel-version-thread/180#post_23710942
post #207 of 2036 Old 09-15-2013, 10:03 AM
snorge's Avatar
Quoted: 154 Post(s)
Liked: 39
oh yes but I mean the differences between it and TS01. If I have any issues with mine I'll try swapping for one to compare.
snorge is offline
post #208 of 2036 Old 09-15-2013, 11:24 AM
Jocelyn84's Avatar
Oh for comparison!! I've never seen a TS01 panel, so I don't really have much to offer, but do let us know what you think if you try a TU02. I think it looks fantastic, but again I have no TS01 for comparison.
My UN46F6300 actually had a tiny tiny little dot like knick inside the bezel and Amazon refunded me $120 to keep it, so I only paid $630 total ($750 [price match] less $120 refund & no sales tax).
Sent from my SGNote2 using Tapatalk
post #209 of 2036 Old 09-15-2013, 01:10 PM
Otto Pylot's Avatar
Liked: 852
If it's an S-PVA panel (Samsung), in theory there shouldn't be any difference. The letters after "T" may indicate a new panel mfr year. Again, using the LG example, 2010 used a "W" to indicate their S-IPS panel. In 2011 it was a "Y" I think. Same panel, different year.
post #210 of 2036 Old 09-16-2013, 11:06 AM
Liked: 559
there could be differences in black levels/contrast ratios and possibly color too but you won't really know if that's the case unless you try both types and compare them directly
Reply LCD Flat Panel Displays
<<. , Samsung , Samsung Ln46a850 46 Inch 1080p 120hz Lcd Hdtv With Red Touch Of Color , Samsung Un55c6300 55 Inch Led Hdtv
