What TV Has The Best ( Pixels Per Inch/Pixel Density ) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 12-10-2010, 01:34 AM - Thread Starter
gumbaz's Avatar
What LED TV Has The Best ( Pixels Per Inch/Pixel Density )..?
gumbaz is offline
post #2 of 14 Old 12-10-2010, 02:07 AM
mattkillahd's Avatar
all 1080p tvs have the same amount of pixels by definition given that 1080p tvs sold are in 16x9 format. 1080 x 1920 = 2073600 pixels. the smaller the tv the denser the pixels.
mattkillahd is offline
post #3 of 14 Old 12-10-2010, 05:26 AM
serialmike's Avatar
Dot pitch of a plasma is much much less than an lcd. I dont remember the numbers I posted a while back about this. Though that is the reason that a plasma has a much softer picture and isnt as good for gaming and PC application.
serialmike is offline
post #4 of 14 Old 12-10-2010, 05:35 AM
davegow's Avatar
Location: In the glorious open countryside of Eastern Ontario.
When I first got interested in HDTV 6 years ago I found the primers offered by places like CNET and Howstuffworks quite useful to learn the basics.
davegow is offline
post #5 of 14 Old 12-13-2010, 06:15 PM - Thread Starter
gumbaz's Avatar
is there anyway of knowing if a TV packs is pixels closer together that the others..?
or do ya just gotta bring a Magnifier Glass and scrutinize the hell outa diff sets..?
gumbaz is offline
post #6 of 14 Old 12-13-2010, 08:16 PM
sjetski71's Avatar
I don't think you're getting it, simple mathematics mate:
1920 x 1080 = 2,073,600 pixels total.
So the smaller the 1080P screen, the smaller the pixels, and NO they cannot be more tightly packed within a given screen size.
You ought to be researching other criteria, so leave the magnifying glass at home
sjetski71 is offline
post #7 of 14 Old 12-14-2010, 12:02 AM
specuvestor's Avatar
The smaller the screen, the higher the pixel per inch (ppi) if that is what you are asking, given same 1080 resolution
specuvestor is offline
post #8 of 14 Old 12-14-2010, 12:32 AM
undecided's Avatar
Quoted: 123 Post(s)
Liked: 80
As others have said the answer is the smallest true 1080P TV you can find - but why the question? What size TV makes sense and what you can resolve is dependent on how close you sit to the TV - see this for a viewing distance calculator which shows 'Viewing Distances Based on Visual Acuity' http://myhometheater.homestead.com/v...alculator.html
Care to explain this? Not sure how dot pitch is relevant here?
undecided is offline
post #9 of 14 Old 12-14-2010, 07:05 AM
8mile13's Avatar
Quoted: 1479 Post(s)
Liked: 825
Wide Hex Ultra Extended Grphics Array can support a resolution up to 7680x4800 (37 000 000 pixels) assuming a 16:10 aspect ratio http://en.wikipedia.org/wiki/Graphic...ay_resolutions
8mile13 is offline
post #10 of 14 Old 12-14-2010, 05:04 PM
davegow's Avatar
Well yes there are huge commercial displays that can cost hundreds of thousands of dollars and require special video to run. Such displays have a lot of pixels. But somehow I doubt this was what the original poster was talking about.
davegow is offline
post #11 of 14 Old 12-14-2010, 08:19 PM
PlasmaPZ80U's Avatar
Quoted: 1960 Post(s)
Liked: 559
probably a 32" unless there are smaller 1080p TVs (not monitors)
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Cambridge S20 Surrounds, Rythmik LV12R; PS4, Xbox One, Xfinity X1 (CI CXD01ANI)
PlasmaPZ80U is offline
post #12 of 14 Old 12-14-2010, 08:44 PM
mdavej's Avatar
Quoted: 2125 Post(s)
Liked: 940
HERE it is (458 pixels per inch). Not sure if it's LED, but it probably is.
mdavej is offline
post #13 of 14 Old 12-14-2010, 09:45 PM
undecided's Avatar
Quoted: 123 Post(s)
Liked: 80
But not probably the most pixels per inch compared to a small 1080P display.......
But again I am not sure why the original question?
post #14 of 14 Old 12-15-2010, 01:15 PM
Mark_Likes_Games's Avatar
Quoted: 31 Post(s)
Well.... If you consider the iPhone 4 a "TV" I think it's around 350 ppi.
It would be amazing if they made large panels with pixels that small...wow.
How DARE you question my ignorance!?!
Mark_Likes_Games is offline
Reply LCD Flat Panel Displays
