Samsung C6xxx Firmware question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-15-2010, 03:22 PM - Thread Starter
A-Dev's Avatar
Considering there isn't to much difference between the 300, 400 and 500 other then the internet@TV, apps and a few technical features. Would the firmware from the 400/500 install successfully on the 300?
Basically what I'm asking is if these sets are that similar why doesn't the 300 come with internet@tv and apps? Is it just a Samsung price point thing?
Would you be able to gain features if a 300 was flashed with 400/500 firmware?
A-Dev is offline
post #2 of 4 Old 12-15-2010, 10:08 PM - Thread Starter
A-Dev's Avatar
anyone? not even a "no, not possible?"
A-Dev is offline
post #3 of 4 Old 12-16-2010, 07:44 AM
mes444's Avatar
Firmware is tv specific. You should use only the one offered for your tv. Installing other firmware can ruin your tv.
mes444 is offline
post #4 of 4 Old 12-16-2010, 05:45 PM
FlatPanelMan's Avatar
check Samsung website for available firmware updates for your model. It will only install the firmware for you model.
FlatPanelMan is offline
Reply LCD Flat Panel Displays
