How i can resolve this... - AVS Forum | Home Theater Discussions And Reviews
Old 12-20-2010, 03:43 PM - Thread Starter
will1983's Avatar
How i can clean this dust inside my 42" lcd panel? also i can see a ccfl lamp ghosting effect... i am sure that my tv have a lot of dust between the lcd and the ccfl lamp assembly. anyone have an idea how i can clean this ?
thanks
will1983 is offline
Old 12-20-2010, 04:13 PM
Tpcorr's Avatar
Will, are you sure that's dust, and not the sparkles effect caused by a bad hdmi cable?
Tom
Tpcorr is offline
Old 12-20-2010, 05:47 PM - Thread Starter
will1983's Avatar
no, its the sparkle effect from the ps3 background... look at the bottom, its not a dark spot, its like dust.
will1983 is offline
