What is happening to my tv?! Green light leak? - AVS Forum | Home Theater Discussions And Reviews
Old 01-13-2011, 12:04 PM - Thread Starter
kganti1's Avatar
This has been happening to my tv (Samsung LN32B460) for sometime, but now it seems to be getting worse! This green light occurs on all the inputs (I only have hdmi connected devices), and is sometimes even visible over color pictures though black is when its most apparent.
I took it to Best Buy within the 1 yr warranty and Samsung said there was no problem with the tv. The tv is still fairly new. I think I bought it in May 2009, and I have probably only watched about 100 hours of tv/bluray. It's a bedroom tv so it doesn't get much usage.
Is this something that can be fixed? Is it even economically feasible to fix? I'd hate to have to buy another tv, but it's really annoying!
Thanks everyone!
kganti1 is offline
Old 01-13-2011, 12:08 PM - Thread Starter
kganti1's Avatar
kganti1 is offline
Old 01-14-2011, 10:29 AM - Thread Starter
kganti1's Avatar
bump.
Anyone have an idea of what this is or if it can be repaired?
kganti1 is offline
Old 01-19-2011, 02:13 PM - Thread Starter
kganti1's Avatar
One last bump. Can anyone help out? Thanks!
kganti1 is offline
Old 01-19-2011, 02:21 PM
mes444's Avatar
Check the link below. It has pics of problems with LCDs and causes. I don't see the exact thing you show but a few are similar and point to a bad panel? Check it out and maybe one of the pics will be close enuf for a possible solution:
http://www.lcdparts.net/howto/symptom.aspx
mes444 is offline
Old 01-19-2011, 02:31 PM - Thread Starter
kganti1's Avatar
Is it maybe a bad CCFL?
kganti1 is offline
