NTSC to Pal Switch toshiba - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 02-16-2011, 07:27 AM - Thread Starter
dante78's Avatar
Hello together,
I have just moved from Germany to the USA. And bought from a colleague, a Toshiba regaza 40XV645U.
I am using a german Panasonic DVD-Player. Both are connected both via HDMI.
Both System are linked, so I can hear music, voices and so on, but my problem is, the picture is missing only black.
I guess, there is anything about pal and ntsc but I am not sure...
Does anybody know a switch or setting, to solve the problem?
Thanks in advance
Andre
dante78 is offline
post #2 of 2 Old 02-16-2011, 08:41 AM
8mile13's Avatar
Quoted: 1517 Post(s)
Liked: 852
I'd say move on,get yourself a blurayplayer and dvd's will look better.
You might own a lot of Pal dvd's,when your Regaza not supports Pal it won't work also your dvd-player should be universal.
Its not all bad ,you no longer have to deal with nachsychronisirung.
Here is a recent pal/nsct thread http://www.avsforum.com/avs-vb/showt...212&highlight= .
8mile13 is offline
Reply LCD Flat Panel Displays
