Official Sony HX929 Owner's thread (46HX929, 55HX929, 65HX929) No Price Talk - Page 101 - AVS Forum | Home Theater Discussions And Reviews
 8Likes
post #3001 of 15695 Old 06-16-2011, 09:59 AM
ejb2227's Avatar
got my 55hx929 from crutchfield this morning. i should have been more careful inspecting the box, because after signing for it I noticed there was a 'drop n tell' device on one side that looks triggered.
haven't opened it up yet to setup, i'm hoping everything will be fine when i setup tonight. either way i've passed it on to crutchfield
ejb2227 is offline
post #3002 of 15695 Old 06-16-2011, 10:32 AM
Do-It-Yourself's Avatar
Location: In a house far away from you creeps (hopefully)
Liked: 24
Originally Posted by InsidiousFix View Post
I had those other 3d options on mine prior to the firmware update. I used it to look at some stereoscopic "things" i found online. :P
That's odd, I never had those options before the update.
Do-It-Yourself is offline
post #3003 of 15695 Old 06-16-2011, 10:39 AM
JamE55's Avatar
How exactly does that "Drop N Tell" device work?
JamE55 is offline
post #3004 of 15695 Old 06-16-2011, 10:48 AM
ejb2227's Avatar
not positive, but it looks like both sides start red, and if the package is shocked enough, some die must be released which turns the arrows blue. there are 2 sentences on a sticker next to it explaining it which i cut out in the picture
ejb2227 is offline
post #3005 of 15695 Old 06-16-2011, 11:45 AM
Gillietalls's Avatar
Quoted: 797 Post(s)
Liked: 673
This thread is whack! If this is supposed to be the best led this year & the blacks are so Kuro-esque, why aren't more pictures being posted? The Kuro has its on pictures thread! Lets see how this tv compares.... And yes this is a challenge to all the owner!!!
LG 65EF9500, LG 55E6, Samsung 55HU9000 (sek-3500), LG 55UB8200
2 Samsung UBD-K8500s, WD 4TB NAS
Nvidia Shield, Wii U, Playstation 3
Gillietalls is offline
post #3006 of 15695 Old 06-16-2011, 12:15 PM
Viper2847's Avatar
What would you guys say about buyng an extended warranty? Do you really need to worry?
Viper2847 is offline
post #3007 of 15695 Old 06-16-2011, 12:24 PM
IMRIZZO's Avatar
Quoted: 44 Post(s)
Liked: 125
Outta the box: uncalibrated
LG OLED 55B6P~Oppo UDP203~SonyXBR929~Denon 3311~Mirage V2 SPK-SYS w/ S10 SW~ DVP5000~Harmony1100
Optimum via SA8300-HDDVR
IMRIZZO is offline
post #3008 of 15695 Old 06-16-2011, 12:30 PM
Allan1paxton's Avatar
Looks good!........that bodes well for post tweaking :-D think I will get this TV, extra cost be damned! Sorry Panasonic maybe when I'm upgrading again in 5 years time!!
Allan1paxton is offline
post #3009 of 15695 Old 06-16-2011, 12:46 PM
RadTech51's Avatar
Quoted: 83 Post(s)
Liked: 168
Yep and Only if Panasonic fixes the Fluctuating Brightness issue.
Sharp Elite PRO- 70X5FD
Pioneer Elite VSX- 52 (A/V receiver)
Pioneer Elite BDP3FD (Blu-Ray) Player
Surround sound system: B&W (2) CM8's, (1) CENTER CHANNEL, (2) CM1 BOOKSHELF MONITORS's, (1) ASW10CM ACTIVE SUBWOOFER.
RadTech51 is offline
post #3010 of 15695 Old 06-16-2011, 12:50 PM
Truer words have never been spoken!!
post #3011 of 15695 Old 06-16-2011, 12:58 PM
Eternal Noob's Avatar
Originally Posted by IMRIZZO View Post
My 46" 929 arrived this afternoon outta the box very nice a few minor adjustments I'm going to let it run for a few days to run in the pixels before I do a WOW calibration. But, out of the box, extremely nice it certainly give my XBR8 a run for the money. BTW I'm convinced that the PQ on the 46" model excels vs the 55" and probaly the 65" which I attribute to the sma number of Zones on all models so the tighter grid on the 46" allows for better lighting control.
Hi Rizzo,
Man, it's great to see you on here, and many congratulations on the new 46HX929! By any chance, would you be able/willing to hook it up to a computer and check the number of zones using the "mouse test?" (or has someone else already done this??) The idea is, you put up a totally black image on the computer that fills the screen, and then slowly move the PC's mouse pointer across the screen, first horizontally and then vertically, to count the number of zones on each axis. When the pointer reaches a new zone, you should see it light up just a little bit and the zone just left also should darken a little bit. This test definitely is best performed in a very dark room (you know--nighttime, window blinds down, all lights off, etc.). For but only for the purposes of the test, it might even be useful to set brightness to an improperly low level, contrast to an improperly high level, and max out on the backlight. That's what I did with my locally dimmed Samsungs, anyway, and it worked like a charm.
-Noob
Eternal Noob is offline
post #3012 of 15695 Old 06-16-2011, 01:16 PM
Granzon's Avatar
Originally Posted by Eternal Noob View Post
Hi Rizzo,
72 zones for my 46"
Granzon is offline
post #3013 of 15695 Old 06-16-2011, 01:38 PM
InsidiousFix's Avatar
Originally Posted by Granzon
72 zones for my 46"
Well, there goes Rizzos idea he had convinced himself of. 72 zones on the 46 and I counted 105 on my 55 inch. So the PQ can't be attributed to more compacted zones. Not sure why people on this thread ,say things they aren't sure of,as uf they were well researched fact.
I'm still considering swapping out my 55 for a 65 when it comes out later this year. All this talk if less zones on the larger sets made me second guess that idea. But now I'm back on board since that is a bunch if nonsense.
Originally posted that I counted 112. Was just going off memory. Scrolled back through to my post and saw I was off by 7. So instead of 112 zones on the 55, it's 105. But still more than the 46 inch.
InsidiousFix is offline
post #3014 of 15695 Old 06-16-2011, 01:51 PM
Jasonjo's Avatar
Seems quite a lot of the UK guys are starting to get their HX923 screens now, but all of them so far have had the dreaded "crease" or dark vertical line down the edge of the screen about 1cm in...not looking good
Any more of you guys seen this?
Jasonjo is offline
post #3015 of 15695 Old 06-16-2011, 01:55 PM
Phil Tomaskovic's Avatar
Quoted: 119 Post(s)
Liked: 27
FYI, a Sony rep replied to my post on their support forum regarding wireless adapter fails to connect if the SSID is not broadcast. He said that the issue will be sent to engineering for analysis. The thread was then locked from further posts (a number of other people replied with the same problem on other sets). So not sure if we will get a fix in the future but Sony now knows about it.
Phil Tomaskovic
Phil Tomaskovic is online now
post #3016 of 15695 Old 06-16-2011, 01:56 PM
RadTech51's Avatar
Quoted: 83 Post(s)
Liked: 168
Well, there goes Rizzos idea he had convinced himself of. 72 zones on the 46 and I counted 112 on my 55 inch. So the PQ can't be attributed to more compacted zones. Not sure why people on this thread ,say things they aren't sure of,as uf they were well researched fact.
I'm still considering swapping out my 55 for a 65 when it comes out later this year. All this talk if less zones on the larger sets made me second guess that idea. Bit now I'm back on board since that is a bunch if nonsense.
+1
Have any idea when we will be able to order the 65? Mabye we can order it in July with an Aug release date?
post #3017 of 15695 Old 06-16-2011, 02:04 PM
Originally Posted by RadTech51 View Post
+1
I was told by my store that they are looking at an October release. I know you can pre order. A retailer in Ohio on this thread has a good deal for the 65.:-)
post #3018 of 15695 Old 06-16-2011, 02:08 PM
RadTech51's Avatar
Quoted: 83 Post(s)
Liked: 168
October release date?
Well I guess good things come to those who Waite. Any idea why it's taking them so long? I herd a rumor it was because of the Gorilla Glass?
post #3019 of 15695 Old 06-16-2011, 02:12 PM
I have not heard official reasons. The only thing I keep hearing is that delays are cause of the earthquake/tsunami. But who knows if that's just some retailer using news he knows everyone is familiar with to answer a question he doesn't really know the answer to. But it makes a certain amount of sense.
post #3020 of 15695 Old 06-16-2011, 02:21 PM
RadTech51's Avatar
Quoted: 83 Post(s)
Liked: 168
Did that retailer in Ohio or anyone else find out how much they expect the 65 to go for?
post #3021 of 15695 Old 06-16-2011, 02:49 PM
MUGEN's Avatar
Quoted: 43 Post(s)
Liked: 29
Originally Posted by honda steffen View Post
no, the backlight is on and not at max.
The first deliverys are out for germany - and it seems that there are many problems with the screen. Also with a strange "stripe or band" in the right and left side on the screen.
Quality problems???
Thanks for posting this info.
Here's an image from that German forum about the crease problem. I have the same thing and have to wait another 2 weeks for a new tv (6 weeks total for this purchase). A guy from the store came over and took pictures of this crease that will be sent to SONY.
And here's a cut away of the tv. Notice the plastic strip that goes around the tv screen.
MUGEN is offline
post #3022 of 15695 Old 06-16-2011, 02:54 PM
GPtimes2's Avatar
It would be nice/appreciated if someone would start an owners thread for this tv down in the 3D display forum.
It would be a great service to those that rank 3D a big part of their decision (as in, sony crosstalk verses panny flucuating brightness) in purchasing.
Thanks in advance!
GPtimes2 is offline
post #3023 of 15695 Old 06-16-2011, 03:06 PM
RadTech51's Avatar
Quoted: 83 Post(s)
Liked: 168
Thanks in advance!
I saw the 3D on the 55HX929 in the Sony store last weekend and I thought it looked amazing. I thought it had slightly better pop and clarity then the VT30, probaly due to the 929's brighter screen and deeper blacks. However the VT30 does an amazing job with 3D and I had no complaints.
post #3024 of 15695 Old 06-16-2011, 03:14 PM
Tyrindor's Avatar
Quoted: 1343 Post(s)
Liked: 656
I'm pretty sure it's normal and is due to backlighting. However unless that picture is making that seem way more obvious.. that's about 400% worse than mine. I've never noticed mine, unless I get up out of my chair.. put on a solid image.. and then stand at a angle about a foot from the screen. As you can see from the pics you can barely see it on the closeup of the corner, however my camera masks it. I would say it's about 2-3x more noticable IRL than my pics show. Still have never noticed it without a solid image on the screen and standing near the TV. Would not be surprised if what you are experiencing is normal and your replacement does the same. It's light leakage from the backlight.
On a side note, does anyone else have a noticable banding line around 40% up the TV (slightly below the middle), that goes across the entire screen? Usually only noticable on lighter colored pans, but it's pretty obvious when you see it.
Tyrindor is online now
post #3025 of 15695 Old 06-16-2011, 03:34 PM
RadTech51's Avatar
Quoted: 83 Post(s)
Liked: 168
Originally Posted by Tyrindor View Post
I'm pretty sure it's normal and is due to backlighting. However unless that picture is making that seem way more obvious.. that's about 400% worse than mine. I've never noticed mine, unless I get up out of my chair.. put on a solid image.. and then stand at a angle about a foot from the screen. As you can see from the pics you can barely see it on the closeup of the corner.
Try using a green picture slide, I'm told our eyes are more likely to see defects in this color spectrum.
post #3026 of 15695 Old 06-16-2011, 03:36 PM
Originally Posted by Granzon View Post
72 zones for my 46"
Thanks much, Granzon. What sort of grid was it, then? Are we talking 9x8, I suppose?
Well, this is very odd, then. Ordinarily, these thing have even numbers of zones, as they're on grids. What sort of grid did you get? It cannot possibly be an 11x5 grid, can it?? I would expect that to look very strange, with few halos and little shadow detail loss horizontally, but lots of both vertically. Is that what you got?? 11x5?
-Noob
post #3027 of 15695 Old 06-16-2011, 03:45 PM
Tyrindor's Avatar
Liked: 656
It's pretty much the same in green, maybe even better. I will say that it's much more obvious in person than my pictures show. That may be because of my camera. I can see it pretty easily from 3-4 feet away with a solid image in real life but i've never noticed it in anything. I can even see it at 6-7 feet if I stare for it with a solid image up. As picky as I am, i've never noticed this before so I think people are just being extremely picky and expecting perfect.
The guy's picture is definitely worse than mine.. after looking at it more i'd say it's about 2x more noticable, not the original 4x I said. It's definitely there, but i'm pretty sure its a normal issue as it's the same thing all around the edge of the TV. It's too hard to compare with photos. I'm sure it's just more noticable on their screenshot because the TV is in torchmode or has it's backlight up. Mine is on minimum.
Look at the D8000, it has the same thing going on, but it's noticable during normal viewing because it's so bad. I think people exchanging their sets for this issue will get a set that does the same. Compared to the D8000's light leakage.. it's NOTHING.
There are much more noticable things on my HX929 than that:
1) Blooming. <-Normal
2) Banding bar about 40% up the screen. <-Normal????
post #3028 of 15695 Old 06-16-2011, 03:51 PM
7x15
post #3029 of 15695 Old 06-16-2011, 03:58 PM
IMRIZZO's Avatar
Quoted: 44 Post(s)
Liked: 125
Hi Rizzo,
Sorry, I don't have a mouse, I have a finger pad. I've made many attempts to wean this info from some higher up-powers at Sony (through Robert @ VE) and they are extremely tight lipped about this info.
IMRIZZO is offline
post #3030 of 15695 Old 06-16-2011, 04:03 PM
I visually checked this on my set. Counted 7 down the side and 15 across the bottom. So unless they are putting uneven amounts through the middle then it's 105 on the 55 inch. But if they were for some reason putting uneven zones, then the 46 would theoretically be the same way.
Reply LCD Flat Panel Displays
Sony Bravia Xbr65hx929 65 Inch 1080p 3d Local Dimming Led Hdtv With Built In Wifi Black , Sony Bravia Xbr55hx929 55 Inch 1080p 3d Local Dimming Led Hdtv With Built In Wi Fi Black , Sony Bravia Xbr46hx929 46 Inch 3d Local Dimming Led Hdtv , Displays
