Official LG 47LW5600/55LW5600 "Passive 3D" Owners Thread - Page 275 - AVS Forum | Home Theater Discussions And Reviews
 18Likes
post #8221 of 8318 Old 05-01-2014, 02:41 PM
Black Maiden's Avatar
Mish mosh of formats, but the one I tested was an mp4 that I recorded on my samsung gs3. I uploaded the rest of my home movies some that were recorded in .mov and some in lack. Some work some don't, I suspect I'll just have to convert them all to a single format. But regardless I'm getting no thumbnails at all.
I have the Synology ds214se so no PLex or xmbc and such for me. Don't really need that either, dlna should suffice.
Black Maiden is offline
post #8222 of 8318 Old 05-02-2014, 12:55 AM
RonAlam's Avatar
Quoted: 12 Post(s)
Liked: 30
try converting to MKV using makeMKV.
RonAlam is offline
post #8223 of 8318 Old 05-07-2014, 07:03 PM
rocamoya's Avatar
Hello guys.. Anyone know how can i select lenguague on mkv files when playing via DLNA or Plex medialink? I can only change lenguague when i play files from usb frown.gif.
Thanks in advance for any help... And sorry for my bad english.
rocamoya is offline
post #8224 of 8318 Old 05-11-2014, 07:22 AM
phuonguy's Avatar
Hi Guys,
When I turned on my LG 55LW5600, I see only the LG logo and life's good image and the clock display, and it stays there. I did the reset by holding the power button for 30 sec and press all the buttons on the remote but the TV never turn on or display any pictures.
Did some research and bought the powerboard. I just replaced it today and I still have the same issue. Will that be an issue with the main board? I am tempting to buy it and replace it. The board price is from 100 to 370.00, not sure why.
When I opened the 55lw5600, i saw only 2 boards, the power board and the main board, is there a TCON board for this TV and where do i find it?
phuonguy is offline
post #8225 of 8318 Old 05-30-2014, 06:50 PM
leem6453's Avatar
47LW5600 owner here. After a lightning storm, all my HDMI ports went out. I've tried everything (different cables, reset, etc), but nothing. Now I'm using component video, but I'd really like to eventually get the HDMI ports working again. Has anyone changed out the main board themselves? Any suggestions on where to buy one for a good price? Appreciate the help.
leem6453 is offline
post #8226 of 8318 Old 05-30-2014, 08:40 PM
trx250r87's Avatar
Look on ebay. It looks like they go for around $120-$130. Mine was swapped under warranty right after I bought the TV. It was pretty easy.
Sent from my SCH-I545L using Tapatalk
trx250r87 is offline
post #8227 of 8318 Old 05-31-2014, 12:52 PM
leem6453's Avatar
Thanks for the tip. There was one for $128...I talked him down to $110. Should have it in a few days. It looks pretty easy to replace...I just want to make sure I ground myself. I might pick up some rubber gloves. I'll let you guys know how it goes. Wish me luck.
leem6453 is offline
post #8228 of 8318 Old 06-04-2014, 04:42 PM
leem6453's Avatar
I replaced the mainboard on my TV and guess what...it worked! I made a little Youtube video chronicling my progress.
https://www.youtube.com/watch?v=epG1MT4wqbg
leem6453 is offline
post #8229 of 8318 Old 06-04-2014, 07:07 PM
keb33509's Avatar
Quoted: 16 Post(s)
Glad to hear it!
keb33509 is offline
post #8230 of 8318 Old 07-07-2014, 04:00 PM
Pats & Sox fan's Avatar
I am sorry if this has been covered already, but I am struggling to find the solution in this forum (very large thread). I have the 55LW5600 and want to enable surround sound pass through on the optical audio out rather than using HDMI. I believe this is possible in the service menu and I am able to access the menu. Much thanks in advance for your help.
Pats & Sox fan is offline
post #8231 of 8318 Old 07-20-2014, 08:44 AM
Liked: 0
External Speaker setting?
I've been searching in this thread and couldn't find an answer so I hope someone can help me. I just bought a soundbar. Finally got sick of the internal speakers on my 55LW5600 after 2 years. The problem is that I can't get the sound to come out of the external speakers. I bought a Speakercraft CS3. Had the optical connected to optical. Tried connecting the digital audio decoder to see if that was the issue. Came to the conclusion the soundbar isn't the problem. It's the tv. I'm updated to the most current firmware.
Went on the LG site and it says to to change the speaker output to "external" but that isn't coming up as a choice in my Audio Setup options on the tv. Why can't I see this? Where is this option hiding??
GagdetQueen is offline
post #8232 of 8318 Old 07-20-2014, 01:55 PM
keb33509's Avatar
Quoted: 16 Post(s)
Did you try turning ARC on?
keb33509 is offline
post #8233 of 8318 Old 07-25-2014, 05:56 PM
swanlee's Avatar
Quoted: 394 Post(s)
Liked: 213
Anyone remember how to edit the thx bright (user) setting? When I bought the tv I got in the service and enabled the thx options and at the time I remember you had to select the thx option and hit some kind of remote code to allow the thx setting to be edited. I know the code to get in the service menu but cant remember the code to edit that setting.
swanlee is offline
post #8234 of 8318 Old 07-26-2014, 08:54 AM
keb33509's Avatar
Quoted: 16 Post(s)
Change it from 0 to 1. 1 means enabled when next to the setting.
keb33509 is offline
post #8235 of 8318 Old 07-28-2014, 05:48 AM
swanlee's Avatar
Quoted: 394 Post(s)
Liked: 213
I know how to enable the THX option in the service menu, after you enable is their is a second code you can put into if you select the THX user option in the menu that allows you to customize the entire THX setting. That is the code I cannot remember.
swanlee is offline
post #8236 of 8318 Old 07-31-2014, 03:02 PM
HowlinWolf's Avatar
How can I enable the surround sound to come out of the hdmi cable? I swear I had this working before, but I could be mistaken.
I have the HDMI cable connected to port 1 (the one that says ARC), the other end goes to my A/V receiver.
On the TV, I have the TV speaker off, ARC mode on, and AV Sync on.
When I go into the TV premium menu and watch something on Vudu, Amazon, Netflix, etc, I can see it just fine but I can't hear anything.
If I connect it to a different input on my A/V receiver, I still can't hear anything. Even on the inputs that I currently have my Directv receiver connected to, or my bluray player connected to. The audio works just fine on those. I can disconnect one, connect the TV to the now open port, and get no audio.
When I do an audio test from the TV menu, I get audio from the TV speaker.
Is there a way too make this work? Am I missing some setting somewhere, or is this supposed to work the way I have it?
HowlinWolf is offline
post #8237 of 8318 Old 07-31-2014, 07:55 PM
keb33509's Avatar
Quoted: 16 Post(s)
Do you have simplink enabled? Mine works just fine with ARC, but for 5.1 I had to do the service menu hack.
keb33509 is offline
post #8238 of 8318 Old 08-01-2014, 07:18 AM
Sven37's Avatar
Sorry to ask this question, but does your receiver support ARC? Certain AVRs only support ARC on certain inputs. In fact, my Dad has an AVR that doesn't support ARC at all. Make sure you have the HDMI on ARC enabled connections at both ends, and like keb33509 said, make sure you use the simplink menu to ensure it works properly.
I'm not home, but if I remember correctly when you are in a premium app like Netflix, you press the Q Menu button on the remote and go to audio and select HT Speaker.
Sven37 is offline
post #8239 of 8318 Old 08-01-2014, 07:58 AM
HowlinWolf's Avatar
Where can I check the simplink setting? I see AV sync is on, not sure where to check for simplink, I can't find it.
How do I do the service menu hack? I have the service menu app and know how to get there, but how do I enable the surround over HDMI once there?
I connected a fiber optic cable and got audio for Amazon, Vudu, Netflix, etc working that way, but I'd still like to figure out why it doesn't work over HDMI if possible.
Edited to add:
ARC on my A/V receiver is on. And I'm not able to get 7.1 surround from a fiber optic cable. It's limited to either 5.1 or 6.1 through the fiber optic cable and can only get 7.1 through HDMI, so I really need to get that working.
post #8240 of 8318 Old 08-04-2014, 02:02 PM
Sven37's Avatar
I'll have to check when I get home, but there is a specific SIMPLINK button on the bottom right of the remote. Check that and get back to us. If I remember to check when I'm home tonight I'll report back.
Sven37 is offline
post #8241 of 8318 Old 08-05-2014, 02:28 PM
Sven37's Avatar
HowlinWolf - I looked into it this morning. If you hit Q Menu while in a premium app such as Netflix or Amazon, then in the menu that pops up go to Set Audio, then change it to HT Speaker and you should be good. If you are not in an app, for example on HDMI 1, press the Simplink button and make sure on the Simplink menu simplink is ON at the top and then at the bottom select the speaker to HT speaker.
I hope that makes sense.....
Sven37 is offline
post #8242 of 8318 Old 08-06-2014, 05:48 PM
Sgooter's Avatar
Quoted: 107 Post(s)
Liked: 87
Just want to say that I've had the 47" model since Feb 2012, and it's still superb! After about a month, I went into the service menu and activated the THX modes (Bright Room), made a few PQ tweaks, and I have not touched anything since. Most of the time, I watch a 65" Panny plasma in the downstairs family room, but the PQ of this 47" LG always impresses me - one of the best buys I've ever made. Enjoy yours!
Taranteacher likes this.
Please enter password to view this signature.
Sgooter is offline
post #8243 of 8318 Old 08-06-2014, 05:51 PM
fafrd's Avatar
Quoted: 14 Post(s)
Liked: 2611
Is this how you get into the Service Menu?
fafrd is online now
post #8244 of 8318 Old 08-06-2014, 06:22 PM
Sven37's Avatar
No, That was in regards to HowlinWolf's issue with getting audio sent back over hdmi to his AVR using ARC\Simplink.
Sven37 is offline
post #8245 of 8318 Old 08-06-2014, 06:27 PM
fafrd's Avatar
Quoted: 14 Post(s)
Liked: 2611
OK - thanks. Are there easy instructions for how to enter the service menu of the LG L5600?
fafrd is online now
post #8246 of 8318 Old 09-05-2014, 10:51 AM
ludespeedny's Avatar
Quoted: 28 Post(s)
I have the 47" and it is no longer powering on, I get the light that goes to blue, but no display. Anyone else have this issue?
ludespeedny is offline
post #8247 of 8318 Old 09-05-2014, 02:13 PM
Sgooter's Avatar
Quoted: 107 Post(s)
Liked: 87
Are you getting any audio from any of the channels?
Have you tried a hard reset?:
Unplug TV and wait til the light (red, white, or blue) goes out.
Depress and hold the power button on TV for at least 30 seconds, then release.
Plug in TV and see if it will fully power up.
If not, then you may have a bad Main board or bad power supply.
Sgooter is offline
post #8248 of 8318 Old 09-05-2014, 03:56 PM
Quoted: 28 Post(s)
Just tried that and no sound or display on the lcd. I tried hooking up a bd player playing audio and tried switching input but got nothing.
post #8249 of 8318 Old 09-05-2014, 07:11 PM
Quoted: 28 Post(s)
I tested the voltages on this board: https://picasaweb.google.com/lh/phot...eat=directlink
and most were close enough to spec. The 12v were about 11.9 the 3.5v were about 3.45 and the 24v was about 24.4. So it would seem like the power board is ok.
What do I check next?
post #8250 of 8318 Old 11-08-2014, 04:57 PM
fafrd's Avatar
Quoted: 14 Post(s)
Liked: 2611
Does anyone know which settings the 55LW5600 uses when using the smart TV functions (Amazon or Netflix)? I thought it would be TV but it seems that is not the case. How do you change settings for viewing Amazon or Netflix?
fafrd is online now
Reply LCD Flat Panel Displays
Lg Infinia 47lw5600 47 Inch Cinema 3d 1080p 120 Hz Led Lcd Hdtv , Lg Infinia 55lw5600 55 Inch Cinema 3d Led Lcd Hdtv , Led Hdtv , Lcd Hdtv
