Official LG 47LW5600/55LW5600 "Passive 3D" Owners Thread - Page 278 - AVS Forum | Home Theater Discussions And Reviews
 19Likes
post #8311 of 8326 Old 11-24-2016, 12:25 AM
Liked: 0
I should also include...
I can't believe how many people have issues like this with their 5 year old LG TV. There should be some type of recall. I can't imagine that many good bad by the same problem after only 5 years and from a legitimate manufacturer.
dnickel1901 is offline
post #8312 of 8326 Old 11-24-2016, 08:02 PM
Maniac1's Avatar
wont connect to internet, any suggestions?
Mine suddenly quit connecting to the internet. it says failed to connect can not connect with a name server
home network is available. check with the dns server address and contact the internet provider. It finds my wifi connection fine and enters password. Any ideas? thanks. I found nothing in search
Don
Maniac1 is offline
post #8313 of 8326 Old 11-25-2016, 02:48 AM
Sgooter's Avatar
Quoted: 130 Post(s)
Liked: 102
Don
Have you tried rebooting your router, then trying to connect the TV to the router and internet?
Please enter password to view this signature.
Sgooter is offline
post #8314 of 8326 Old 11-25-2016, 04:53 AM
PrimeTime's Avatar
Quoted: 588 Post(s)
Liked: 289
Originally Posted by dnickel1901 View Post
I assume the main board and the bad power is an expensive fix - bummer, because I really did love the tv, but it is probably not worth the expense.
Any other ideas?
We have the 55LW5300 which is basically the same TV. Purchased in 2012. Around 2014 it died, no logo, nada. Since you're occasionally getting a LG logo, I would suspect the power supply board, which I replaced on mine (uses the same power supply board, IIRC).
I laid it flat on the bed, face down, unscrewed the back cover, and there are two large boards -- power supply and main. Marked all of the connections, pulled them and found a replacement PS board on Ebay for $85. Got the board, swapped it out, fired it up and everything's been good since then. (Much easier to fix than our old Pioneer 503PU with its Media Center -- gotta be a dozen unobtainable boards going on there.)
PrimeTime is offline
post #8315 of 8326 Old 11-25-2016, 08:30 AM
Maniac1's Avatar
Actually it is a brand new router we are using today so it should be fine. Problem started last week.
Maniac1 is offline
post #8316 of 8326 Old 12-09-2016, 12:35 PM
tbielowicz's Avatar
Quoted: 21 Post(s)
Ok so my 55LW5600 just started having major issues. I blame it on all those talking about their issues on this forum!
All kidding aside, when turned on, it would have black/white squiggly horizontal lines, flash red, green, etc... Then go blank.
I searched the internet and found one potential fix if it is the input board that is having the issue, which seems to be the most common. I think its called the T-com board.
So I followed the directions of removing the board and placing it in the oven at 385 degrees for 10 minutes. Yes, my wife thought that I was insane "baking" the board.
Once cooled down I put the board back in, plugged all cables back in and was ready for the test...
I turned it on and low and behold, it flippin' worked... The oven trick had successfully "reconnected" the issues that the board was experiencing.
Just wanted to pass this along in case any one else is having an issue since it seems to be such a common 5 yr issue. Hopefully I don't have to bake it for some time again.
tbielowicz is offline
post #8317 of 8326 Old 12-28-2016, 11:37 AM
Sgooter's Avatar
Quoted: 130 Post(s)
Liked: 102
Anyone here able to get the Amazon Instant Video app on their LG 47LW5600?
Sgooter is offline
post #8318 of 8326 Old 12-28-2016, 07:01 PM
trx250r87's Avatar
Quoted: 22 Post(s)
I think the Amazon app is no longer supported.
trx250r87 is offline
post #8319 of 8326 Old 02-11-2017, 05:55 AM
Sgooter's Avatar
Quoted: 130 Post(s)
Liked: 102
For about a month now I've had an intermittent video problem with my 47LW5600. About 5-10 minutes after turning the TV on, the video shuts off, but the audio continues to work fine. I then toggle the TV off, then it comes back on normally and both video and audio work fine for the rest of the evening. This has happened randomly about 4 times so far. Also, when the problem occurs the red/white power light is not on. Any ideas?
Status Update 1 May 2017: Unfortunately, the intermittent video problem has gotten worse; more frequent incidents of no video while audio is fine. So, I donated the TV to a local charity - informed them of the problem. Replaced it with a new LG 55UH615A 4K TV from Sam's. PQ not good out of the box, but starting to get better with some settings changes. May look into the service/hidden menu for new discoveries; would be cool if there's a secret THX cinema option in there somewhere.
Good luck folks. From some of the recent posts, it seems this 47LW5600 starts to have problems after 5 yrs.
Sgooter is offline
post #8320 of 8326 Old 05-24-2017, 09:44 AM
billymerritt's Avatar
Quoted: 33 Post(s)
Liked: 27
My 55" still works great but I only use it for OTA and last I checked has over 7,000 hrs.
Bill
billymerritt is offline
post #8321 of 8326 Old 05-24-2017, 10:35 AM
COMPUTIAC's Avatar
How do you check to see how many hours are on it ?
COMPUTIAC is offline
post #8322 of 8326 Old 05-24-2017, 11:33 AM
Quoted: 33 Post(s)
Liked: 27
I think it's in the settings menu then the about menu and TV information.
Bill
post #8323 of 8326 Old 05-24-2017, 11:45 AM
COMPUTIAC's Avatar
Thanks for the reply.
It was under " Product/Service Info." Used Time 46189.
post #8324 of 8326 Old 05-24-2017, 11:50 AM
Quoted: 33 Post(s)
Liked: 27
That's a lot of hours.
Bill
post #8325 of 8326 Old 05-24-2017, 01:02 PM
COMPUTIAC's Avatar
Bought it new Dec. 2011. Still works fine with no problems.
post #8326 of 8326 Old 06-21-2017, 12:44 AM
Black Maiden's Avatar
Bought the 55" in Sept 2011. 23,635 hours here, still working as good as the day I got it. That said I never used the smart TV functions aside from maybe a week when I used the Netflix app because I didn't have HD tv service yet. Its just too damned slow and clunky. I use a Roku3 for all that stuff. Im not interested in getting another TV any time soon to replace it. I can easily see myself using this for another 5-6 years easily.
COMPUTIAC likes this.
Black Maiden is offline
Reply LCD Flat Panel Displays
Lg Infinia 47lw5600 47 Inch Cinema 3d 1080p 120 Hz Led Lcd Hdtv , Lg Infinia 55lw5600 55 Inch Cinema 3d Led Lcd Hdtv , Led Hdtv , Lcd Hdtv
