Samsung going to the dump or can it be saved? - AVS Forum | Home Theater Discussions And Reviews
Old 03-05-2011, 05:33 PM - Thread Starter
Injected Sin's Avatar
Need some help, my Samsung LN32A300 recently started doing this. I checked all the ribbons and swabbed them with alcohol no change.
Is my LCD going to the dump?
XBL GTÂ vFLOODv
Injected Sin is offline
Old 03-06-2011, 12:28 AM
ChrisW6ATV's Avatar
Does it have the same problem on all inputs, including the built-in tuner (if it has one)?
The problem appears to be in some colors more than others, so it may be repairable. It would not hurt to ask a shop if you have one nearby, or to sell it as-is on Craigslist otherwise.
Chris
"It's [expletive] lame to watch Jaws, a film that uses the 2.40 ratio as well as any ever produced, in the wrong format on HBO." -Steven Soderbergh, Oscar-winning director
ChrisW6ATV is offline
Old 03-06-2011, 04:50 AM - Thread Starter
Yes it does it with all inputs.
XBL GTÂ vFLOODv
Old 02-15-2013, 04:55 AM
orion_134's Avatar
I have the same problem, did you figure it out?
orion_134 is offline
